Old 06-06-2013, 02:40 PM   #21
TerraPhantm
My Ride: M3 & ZHP
Originally Posted by new//M3fan View Post
Hmmm, how would you accomplish this?
I would have to figure out which regions of the flash the stock 0pa and 0das comprise of, then generate Intel-hex files of the appropriate regions from the Alpina dump.
Old 06-07-2013, 05:50 AM   #22
daniel_f.
My Ride: 330iC
mistake
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 06-09-2013, 05:20 PM   #23
daniel_f.
My Ride: 330iC
Just for further reference:
BMW-Scanner is able to read the gearbox No need for soldering
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 06-09-2013, 06:02 PM   #24
TerraPhantm
My Ride: M3 & ZHP
awesome. I'll never have an automatic, but I still would love to take a look at that binary!
Old 06-09-2013, 06:03 PM   #25
always-there
My Ride: 2002 BMW 330I
Deleted forced shifting at ZF5HP19
Originally Posted by shahbaz99 View Post
How is that a good thing? lol, sounds painful
Yea....doesn't seem to be a good thing.
Old 06-09-2013, 06:05 PM   #26
TerraPhantm
My Ride: M3 & ZHP
Not really. In manual mode a transmission should only shift when you command it to. If you're at the limits of grip and the car changes gears mid turn, you'll likely crash.
BMW's SMG and DCT only shift when you tell them to, just like a performance transmission should.
Old 06-10-2013, 12:51 AM   #27
daniel_f.
My Ride: 330iC
the problem is, it can read the file, but unfortunally the bytes in the data section are twisted, so the whole read is useless until you figure out how they were twisted and what you can do to get them right.
it took me the whole weekend to rea-arrange them with massive workload in excel. So before i will upload the file, im flashing a few of my spare tcus and sell as "DF-Motorsport" Units
the maps themself have pretty steep changes no wonder as the torque converter snaps in pretty brutal
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 06-10-2013, 01:33 AM   #28
TerraPhantm
My Ride: M3 & ZHP
I bet I can figure out how to arrange it I imagine you wouldn't have to worry about the first 0x70000 bytes since that's all boot-sector/program data anyway -- I would be surprised if Alpina bothered changing that. Do keep in mind that the actual B3 has a different torque converter. Not sure if the standard one is meant to take that abuse.
Edit: Are you sure the "twisted" data section isn't simply that meant for a different program version?
Old 06-10-2013, 02:48 AM   #29
daniel_f.
My Ride: 330iC
i backtested the twist with a programmer read-out from a tcu with socketed flash vs. the bmw-scanner read from a known file, so i could see what bmw-scanner does.
an indeed, alpina even changed the data in row 0x00000
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 06-10-2013, 03:52 AM   #30
TerraPhantm
My Ride: M3 & ZHP
^ that means they changed the boot sector. Might be impossible to flash via WinKFP then... Kind of like how the CSL DME is in comparison with the standard M3's DME. Don't know why they bothered doing that if the Alpina software isn't even included with the BMWs suites
Old 06-10-2013, 12:58 PM   #31
daniel_f.
My Ride: 330iC
I get a feeling that even if the flash is copied, the tcu doesnt work. everytime i try the modified alpina flash, the tcu isnt recognized at all. if i just change the flash to standart bmw bin, the tcu works flawless...
(edit)
i backtested to convert another bmw-scanner readout from a bmw own file and after the conversion the tcu worked. i then rechecked every step i did with the alpina readout and even recalculated everything in the layout i was using directly before with the bmw file and it didnt worked again, limpmode .
so for now i dont understand exactly why this happens, but i dont see any chance to get a alpina tcu flash to work in an other bmw tcu.
i even wrote the alpina eeprom file from bmw-scanner over the bmw tcu but again, limpmode
right now im even more happy to have spend only 120$ on that tcu and for everyone else: try to get a flash from ESS or Dinan. that seems to be the only solution.
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 06-10-2013, 09:17 PM   #32
TerraPhantm
My Ride: M3 & ZHP
(edit)
Is it recognized by diagnostic software?
Old 06-10-2013, 11:26 PM   #33
daniel_f.
My Ride: 330iC
the alpina unit itself, yes. the bmw unit itself, yes. the bmw unit with the corrected alpina reading, no. the bmw unit with the corrected bmw reading, yes.
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 06-10-2013, 11:50 PM   #34
TerraPhantm
My Ride: M3 & ZHP
Hm. Must be some sort of hardware difference. Is there anything obvious on the PCB?
Old 06-11-2013, 12:14 AM   #35
daniel_f.
My Ride: 330iC
i havent opened to unit.
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 06-11-2013, 01:30 PM   #36
daniel_f.
My Ride: 330iC
So, i opened pandoras box and didnt find any visible differencies, despite that i compared it to an 2 years older tcu. some minor changes due to no longer available hardware components.
thats when i decided that there is only one way to figure out whats going on, so i took my hot air soldering station and with shuddering hands i unsoldered the flash. i took it onto the programmer and the flash was recognized working I read the dump and compared it to my modified bmw-scanner readout and in 32786 rows, there were 4 rows with differencies
I took one of my spare TCUs, flashed the new file, put it in the car and...
working
now its time to delete the VIN in the flash and time for some
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 06-11-2013, 11:24 PM   #37
TerraPhantm
My Ride: M3 & ZHP
Cool --
If you get a chance, can you post a picture of the board? I've never seen a GS8.60.4 board
Old 06-12-2013, 12:09 AM   #38
daniel_f.
My Ride: 330iC
Shure, no problem. i can even take photos of the different versions i found. so far i have found 3 different versions, but they are interchangeable.
whats really annoying is, the gearbox does no downshift at hill descent when braking i guess the alpina has much more engine brake power so its not necessary to downshift
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 06-12-2013, 01:52 AM   #39
TerraPhantm
My Ride: M3 & ZHP
That is odd. The B3 3.4 only has 10:1 compression, so I don't think it would have significantly more engine braking power than a 330.
Just get some paddle shifters and not worry about auto mode
Old 06-12-2013, 02:30 AM   #40
daniel_f.
My Ride: 330iC
indeed, the manual mode makes much more fun with the alpina unit.
Siemens MS42 wiki!
Siemens MS43 wiki!
