Old 08-16-2013, 09:25 AM   #41
saschaplease
My Ride: cars and bikes
I really need this!
saschaplease is offline   Reply With Quote
Old 08-16-2013, 10:36 AM   #42
daniel_f.
My Ride: 330iC
Kein Thema, können uns gerne mal in Köln treffen und Du machst mal ne Probefahrt mit dem EGS
I´m currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 10-28-2013, 01:27 PM   #43
HakenTT
My Ride: 323i with S54
I haven't driven automatic for long time, but what is 'forced shift'? Is this when you are in manual mode if you hit rev limiter EGS forces the shift?
5hp19 is very weak, it blows up the reverse crown even on 2.5L but 5hp18 seems to be much better and stronger.
HakenTT is offline   Reply With Quote
Old 10-29-2013, 01:04 PM   #44
stevenluczynski
My Ride: Is Steel Blue
Deleted forced shifting at ZF5HP19
Yup, it's the car shifting for you when you're in manual mode.
stevenluczynski is online now   Reply With Quote
Old 10-29-2013, 02:45 PM   #45
HakenTT
I did this once, and then raised the rev limit to 7200 then in manual mode when the rev went past 7000 the transmission went into limp mode with a code 'over rev protection'
This means that TCU has to be programmed for higher rev by who?
Old 10-30-2013, 05:33 PM   #46
TerraPhantm
My Ride: M3 & ZHP
He's using the Alpina software, which presumably uses a different/better method to disable the forced upshift. Unfortunately, this flash is not in WinKFP unlike newer Alpina transmission flashes.
