Sponsored by The Tire Rack
Old 06-04-2013, 10:06 PM   #1
steveintheburgh
My Ride: 2004 330Ci
Refinished Style 71s (Polished Lip) DIY Lots of Photos
Finally completed this project.
Paid $100.00 for the set - all 4 were pretty rough, 2 were rashed all the way around.
Maybe $50.00 in supplies including wax and polish for future use.
Plan on 4 hours per wheel
Tools:
Scraper
8mm Triple Square Socket - don't skimp on this...the screws are really tight and you don't need any stripping going on.
Socket Wrench (I used a breaker bar too)
Rubber Mallet
Fine File
Cloth wheel w/ drill attachment for polishing
Supplies:
Simple Green or equivalent
Klean-Strip Peeler Basecoat and Clearcoat Remover
WD-40
Sandpaper (I used 40 and 80 grit paper, Medium/Fine/Extra-Fine Sanding Blocks, then 1000, 1500, 2000 Grit Paper)
Polishing Compound (I used generic white)
Clay bar for the centers
Hand polish (Mothers Billet worked great)
Wheel wax or sealant
Here's what I started with....Pitted. Rashed, etc. etc.
Soaked the lips in WD40 overnight then started loosening the screws. Took an 8MM Triple square Bit and a breaker-bar because they were so tight. THESE SCREWS WIL BREAK SO TAKE YOUR TIME. Used a rubber mallet to seperate the center from the hoop.
Soaked and scrubbed both pieces (and the screws, actually) in simple green.
The centers turned out to be in decent shape. Clay bar, KLASSE, Poor Boys Sealant and Wheel Wax got me this result - I'd say a 8.5 out of 10
I went through the process of spraying the Klean-Strip, letting it sit for 5-10 min then scraping - 2 or 3 times. You're going to be sanding everything down so don't worry about scraping too much.
Filed down the rash to as smooth as possible w/ the file. (Thankfully a file did the trick, no fill required)
Start wet sanding. Get everything as consistent as possible before going to the next step. Use the 40 to get rid of ALL the discoloration from pitting or damage before moving on.
Here's after 40 grit
This is after 2000 grit
Polish: I used a few drill mounted polish wheels and basic white paste. 3 big pieces of advice. 1. Tape up the nut holding the wheel to the bit. The wheel slipped a few times on me and nicked the rim which called for re-doing that section. 2. Rake your wheel often. That gets rid of the metal shavings and old polish. 3. A little polish goes a long way. If you end up w/ black junk on the rim, you're using too much.
Here's after polish. I took them to a solid shine. I'm sure I could have gotten to a mirror finish w/ the right compounds. I opted not to, mainly because this is my daily driver and maintaining a mirror finish seems a bit much.
Used Mothers Billet by hand, Poor Boys Sealant and Wheel Wax before I put them back together.
I decided to not clearcoat as any flaking, rash etc would = redoing the entire wheel from step one. I'll be maintaining w/ hand polish and wax.
Reassembly: I'm too cool for a torque wrench so I went 1/4 past wrench tight w a breaker bar. Do so at your own risk.
Results:
$100.00 for 4 rough wheels
$50.00 in supplies
$120.00 for slightly used tires off of CL (I know-risky)
$60.00 to mount and balance
$330.00 plus maybe 4 hours per wheel for 8/10 summer set.
steveintheburgh is offline   Reply With Quote
Old 06-04-2013, 11:59 PM   #2
YOnpds
My Ride: E46
Very nice! Good job.
YOnpds is offline   Reply With Quote
Old 06-05-2013, 12:45 AM   #3
filipinoise
My Ride: '02 325ci
These Style 71's turned out great! Huge improvement from when you first picked them up. Good work.
'02 325ci 5MT
I take pictures in the San Francisco Bay Area.
www.eluisphoto.com
filipinoise is offline   Reply With Quote
Old 06-05-2013, 09:09 AM   #4
BlaccDiamonds
My Ride: 04 330Ci + 02 4.6is
Very nice!
I have a set also and was iffy about the center star being able to remove or not. I have refinished wheels before and I know the long process involved, but the end results always make me smile.
Question? Do you know the exact torque specs for the bolts? My last set of rims stated @ 12 pounds, but i also found that a few extra clicks after the torque bar sets makes me feel more comfortable.
I might even take them apart and have them re-barreled...for extra width since these are the only set I have now that's decent...hmmm
BlaccDiamonds is offline   Reply With Quote
Old 06-05-2013, 09:11 AM   #5
BlaccDiamonds
Another question! Where did you get the BMW logo for the calipers from? I like that!
Old 06-05-2013, 11:12 AM   #6
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Excellent work, those wheels look brand new!
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 06-08-2013, 09:24 PM   #7
indoafro
My Ride: 325ci
great diy!!!
indoafro is offline   Reply With Quote
Old 06-08-2013, 09:48 PM   #8
Riverbmr3
My Ride: MB E350 & BMW 325i
nice job
Riverbmr3 is offline   Reply With Quote
Old 06-11-2013, 08:49 AM   #9
jonel1225
My Ride: 02 325ci
great diy! i was wondering what you would have had used to fill them with if needed?
Untitled
jonel1225 is offline   Reply With Quote
Old 06-17-2013, 12:01 PM   #10
Redline
Redline's Avatar
My Ride: ///M3 Vert
I'd say 15-25 lb's are normal for this kind of wheel. I'm going to do 15 lb with blue loctite and see how that goes then go to 18 lb.
Tighten in a rotating 5 bolt star pattern.
k.
///M
Old 06-17-2013, 12:12 PM   #11
steveintheburgh
My Ride: 2004 330Ci
@ Jonel1225 I probably would have filled per this DIY.
http://forum.e46fanatics.com/showthread.php?t=713071
This wouldve Required a paint job though.
@BlaccDiamonds
Tons of options on ebay
Here's an example.
http://www.ebay.com/itm/BMW-Brake-Ca...0aaefe&vxp=mtr
I painted the Calipers black, the Retainer Clips Silver then went w a simple decal on the all 4. I believe the rears took a smaller decal.
Old 06-17-2013, 08:26 PM   #12
jonel1225
My Ride: 02 325ci
Great thank you!
Untitled
Old 06-17-2013, 08:56 PM   #13
e46JAB
My Ride: 2000 323CI, 2004 M3
Great job! Some of my favorite OE wheels.
e46JAB is offline   Reply With Quote
Old 10-07-2013, 06:04 PM   #14
EthirD
My Ride: '02 325iT, '07 X5
Old thread bump and newb question: would using the stripper on a wheel with the tire mounted cause issues for the tire? I have a 135 with serious paint peelage that needs stripped and repainted. I know I can mask the tire for paint, but wouldn't want to eat it alive.
wagon devotee
BMW CCA Member #480924
EthirD is offline   Reply With Quote
Old 11-12-2016, 05:45 AM   #15
z3pilot99
My Ride: 2004 330ci 6sp. AW
Another old thread bump. But, how did the polished aluminum hold up without clearcoat? Did it oxidize or start to turn in any way? Getting ready to do this and would like to find out if you would do anything different. Does the removal of aluminum cause any wheel/tire balance issues?
z3pilot99 is offline   Reply With Quote
Old 11-12-2016, 11:03 AM   #16
steveintheburgh
My Ride: 2004 330Ci
3 -4 years later the polished aluminum has held up great. Once every 6 months or so I hand polish w Mothers Billet then 2 coats of Wheel Wax (polished portion only).
Mind you I'm in Nashville so Snow and Salt is very minimal. More frequent polishing would be needed if you run these all winer up north. (I had separate 17s for winter when I was in Pittsburgh)
Regarding balancing...relatively speaking you are removing a very small amount of material. They balance out fine each time I've had new tires mounted.
As the post says this gets you to a 8-9 on a quality scale. Not perfect by any means.
Old 11-12-2016, 12:29 PM   #17
BKMrSteel
My Ride: 99 328i
I polished the lips on some M3 18"S because of threads like this. Mine came out perfect for a DD or street car. I love it, most people don't realize what they are even.
Instead of stripping the paint from the lip, you can spin it on the car and use a hard smooth edge of the paint scraper. Just don't catch an edge and gouge the surface. Makes short work of the lip, maybe 30-60 minutes from start to finish.
<a href=http://forum.e46fanatics.com/showthread.php?t=1094528 target=_blank>http://forum.e46fanatics.com/showthread.php?t=1094528
</a>
BKMrSteel is offline   Reply With Quote
Old 11-14-2016, 07:47 PM   #18
steveintheburgh
My Ride: 2004 330Ci
I should add that since refinishing I've lightly rashed 2 of the wheels.
Not adding Clear was a big plus as I was able to sand and polish the damaged section only - ultimately blended in w/ the rest of the wheel
