Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 3.20 average. Display Modes
Old 06-04-2013, 10:29 PM   #1
CJin2552
My Ride: 2001 BMW 325Ci
My Project Thread (2001 BMW 325Ci Coupe)
A lot of people have been doing Progress/Project/Build Threads, and I figured I'd just on the bandwagon and show the work done to my car inr the time that I have owned the car. The Style 71's basically came on the car, I was able to swap my style 44's for the style 71's from another car that was totaled. I am to believe that it is both a Sport Package and a Premium Package coupe.
How She Sits Today:
Overall Service: (I am missing some paperwork here)
09-11-2010:--134,865--Power Steering Gasket Ring (Prevent Leak)
12-13-2010:--136,727--Hankook Ventus HRII 225/40HR18 x4
06-04-2011:--139,873--Windshield Wipers; Oil Change; NCSI
02-22-2012:--144,967--Oil Change
04-19-2012:--146,063--Oil Change, Crankcase Vent Hose Replaced; Power Steering Flush; Cooling System Flush; Transmission Fluid Flush
10-22-2012:--149,825--Oil Change, Oil Filter Gasket Replaced, Front Brake Service (Pads, Rotors, Sensors)
06-19-2012:--147,776--NCSI
11-19-2012:--xxx,xxx--Dark Grey Suede Headliner
06-24-2013:--156,947--NCSI
09-30-2013:--161,050--Oil Change
10-17-2013:--161,202--Belts/Pulleys Replaced due to Squeak/Rattle
01-09-2014:--xxx,xxx--Beisan Systems VANOS Seals Replaced (DIY)
06-03-2014:--169,024--Hankook Ventus V2 Concept 225/40HR18 x2
07-14-2014:--171,389--NCSI; Windshield Wipers; License Plate Bulb
09-16-2014:--173,900--Oil Change
10-17-2014:--174,262--Hankook Ventus V2 Concept 2 225/40R18 x2
12-06-2014:--175,898--Belts/Pulleys Replaced **WARRANTY**; Control Arm Bushings/Alignment
02-20-2015:--178,550--Driver's Side Door Lock Actuator; Headlights Height/Tilt Adjusted to OEM Specifications
03-31-2015:--180,290--Battery Replaced
04-02-2015:--180,290--Fuel Pump Replaced
04-11-2015:--180,613--Airbag Recall; Brake Service (Rotors/Pads/Sensors)
04-29-2015:--181,023--Cooling System (Radiator/Coolant/O-Ring/Mounting Plate/Water Hose/Expansion Tank/Thermostat/Radiator Cap)
05-15-2015:--181,388--Driver's Rear Wheel Bearing Replaced
06-13-2015:--183,033--(Inspection II?) Spark Plugs; Air Filter; Pollen Filter
06-29-2015:--183,784--H&R Touring Cup Kit
07-01-2015:--183,950--Alignment; (Aesthetics) Engine Cover Screw Caps; Orange Interior Trim Clips
07-09-2015:--184,390--M-Tech II Bumper Painted and Installed
07-18-2015:--184,782--OEM Hood & Trunk Roundels; Windshield Washer Pump Replaced (INOP); Windshield Cowl Replaced (Dry-Rotting)
07-27-2015:--185,312--Oil Change
08-13-2015:--185,938--Check Engine Light: Camshaft Position Sensor Replaced; Cooling Thermostat Replaced
11-30-2015:--191,280--Oil Change; Front-Right Strut Hat Replaced (Creaking Noise While Turning at Low Speed)
01-08-2016:--192,878--OEM BMW M3 Clip-In Style Corner Lights Installed
01-26-2016:--193,456--APEX ARC-8 18x9.5 ET35 Installed
04-30-2016:--196,875--Oil Change; Driver's Seat Belt Tensioner Replaced
05-31-2016:--197,874--Hankook Ventus V2 Concept2 225/40R18 XL
06-23-2016:--198,804--NCSI, License Plate Bulb Replaced
Current Modifications:
-APEX Race Parts ARC-8 18x9.5 ET35 (Hyper Silver)
-APEX Race Parts 90mm Stud Conversion
-5mm Rear Spacers (Unknown Manufacturer)
-OEM M3 Corner Lights (Genuine BMW)
-Quad Morimoto H1 6.0 Projectors Headlights (The RetroFit Source)
-3000K Morimoto H1 Xenon Headlight Color Temperature (The RetroFit Source)
-Yellow Headlight Tint (Lamin-X) --Removed 6/8/16--
-Aftermarket LED Tail Lights (eBay)
-New OEM Hood/Trunk Roundels (Genuine BMW)
-OEM Roof Rack Supports (Genuine BMW)
-Dark Grey Suede with White Stitching E-Brake Boot/Shifter Boot (Bimmian)
-03.5+ CD53 Update (with Auxiliary) (Bought from another Enthusiast)
-Aftermarket Clear Side Markers (eBay)
-H&R Sport Touring Cup Kit (Race Springs)
-Aftermarket Matte Black Kidney Grilles (eBay)
-M-Tech II Front Bumper (khoalty)
-Aftermarket M3 Style Trunk Lip Pre-Painted (eBay? Bought from another Enthusiast)
-Angel Eyes 6000K Predator Orion V2 (Bought from Sedan Hussein, Łmnitza)
-KAMEI Headlight Eyelids (Electrodyne.cc)
-BMW CCA Club Racing Grille Badge (BMW CCA)
Some pictures are lower quality, because I didn't have my Nikon Camera until after I installed a few things.
First pictures I had gotten of the car:
(2010) Had just gotten the car and was at a storage unit picking some things up.
Graduated High School and bought myself some Black/White Logos.
Then I started working and got a combo pack on eBay that came with the built-in halos, projectors, and also came with some smoked corners.
NOTE: Naturally, since they're from eBay and only cost $210 with free shipping, the halos quit working right only about 3 months in. I'm now looking into SolidJake's RetroFit thread. I plan to do the quad projector setup though.
Here's an image with the projectors installed as well.
When I had bought the new housings, they did not even come with a relay harness for the halos to work. I just figured I'd grab them later on when I did the tail lights.
Here's a picture of the halos working and the projectors and fogs on.
Then an image of the rear LED Tail Lights installed.
The next thing I decided to do, was to grab some matte black kidney grilles. For some reason mine chrome ones were falling out and one day when I slammed the brakes, the right one fell out completely.
"http://farm9.staticflickr.com/8255/8955363420_692edbf03e_b.jpg" (Picture keeps getting resized too large)
After that I had decided to do the clear side marker as well, since both of the front and rear turning lights were cleared out.
I then bought some white on black dice valve stem caps.
"http://farm6.staticflickr.com/5455/8955548400_28ba700fef_b.jpg" (Picture keeps getting resized, removed)
I decided that those were a bit tacky, so I traded them from black and white BMW stem caps, painted the calipers matte black, and put on some black lug nut covers from BavAuto. I had also decided to convert all of the BMW Roundels to the Black/White Carbon Fiber ones, as opposed to having the black/white hood and trunk ones, and blue/white wheel roundels including the steering wheel.
After all of that, I put a 3M Carbon Fiber roof wrap on, but they had installed it and I saw a wrinkle, so I had it removed.
A few months of saving, I decided to put some dark grey suede on the pillars and headliner, since the previous headliner was falling off.
My most current modification is the HID 6000K lights.
CJin2552 is offline   Reply With Quote
Old 06-04-2013, 10:58 PM   #2
BBBoy323i
My Ride: 01' 325ci
Nice ride
BBBoy323i is offline   Reply With Quote
Old 06-04-2013, 11:01 PM   #3
jonel1225
My Ride: 02 325ci
I like what you're doing with it. Good job !
Untitled
jonel1225 is offline   Reply With Quote
Old 06-04-2013, 11:04 PM   #4
CJin2552
Originally Posted by BBBoy323i View Post
Nice ride
Thanks, both of you!
Old 06-04-2013, 11:10 PM   #5
serdar255
My Ride: '01 325ci / '90 325i
Nice, now drop in a manual transmission!
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 06-04-2013, 11:12 PM   #6
CJin2552
Definitely would like to. I had gotten this one on a deal and it was an automatic, so I just went with it. If I ever grab another E46, or the transmission needs to be replaced, I'm totally going with three pedals.
Old 06-05-2013, 01:15 AM   #7
c0smic
My Ride: 2001 330Ci
Cool build man! I just got a 2001 330Ci and looks just about how yours started out as.
You throw a new bumper on there.
c0smic is offline   Reply With Quote
Old 06-05-2013, 10:27 AM   #8
CJin2552
I want the MTech, which I did get, but the shipment tore it completely up. I just don't have the funds right now for both a new bumper and paint job. Definitely on the to-do list though. I'd love to see yours.
Old 06-05-2013, 02:55 PM   #9
GeneralJayE46
My Ride: E46 325i
Nice bro, I have a 325i sedan same color that im slowly but surely working on. I've been wondering what the black kidney grills/black badges look like on steel blue...i like it!
E46 Sedan|Steel blue|5 Spd|Angel Eyes|LED Tailights|20% tints|Plate Relocater|BMW performance short shifter|Eibach Sportline springs|
Bilstein struts/shocks|Clear Parking lights|Clear Side Markers|Matte Black Grills|
GeneralJayE46 is offline   Reply With Quote
Old 06-05-2013, 03:49 PM   #10
ryannel2003
My Ride: '04 Cadillac Deville
Sexy car. I love the color and the wheels.
ryannel2003 is offline   Reply With Quote
Old 06-05-2013, 04:02 PM   #11
CJin2552
You could definitely take some pictures, then go into photoshop and put a layer over the badges and color it black.
My friend has a 325CiC in Steel Blue, and when you add black stuff to it, it really pulls the gray.
Mine is Steel Grey Metallic (400), I'm not sure if that's the color you're talking about.
And really, thanks for the kind words!
Old 06-05-2013, 04:03 PM   #12
CJin2552
Thanks a bunch!
Old 06-05-2013, 04:20 PM   #13
GeneralJayE46
My Ride: E46 325i
Yes, I meant Steel blue. Those are deff gonna be on my list on top of a couple other things I wanna do this month. No problem gotta show credit when credits due.
Old 06-05-2013, 07:20 PM   #14
CJin2552
Steel blue does look good, especially on a lowered sedan. You could also just get body colored pieces instead of black. Either/Or, it'll turn out really well. Keep me posted on what you end up doing. I'd love to see the outcome.
Old 06-05-2013, 07:33 PM   #15
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Blah, killed the car with those headlights
Old 06-05-2013, 07:56 PM   #16
CJin2552
I know, I am currently looking at doing your RetroFit. Just trying to get the money to rebuild the lights right now.
Old 06-05-2013, 08:56 PM   #17
filipinoise
My Ride: '02 325ci
+1 with Jake's comment on the headlights. I did the projector retrofit in his thread and don't regret it one bit. Love, love, love my retrofitted projectors.
That said, beautiful color (not that I'm biased or anything...) and clean modifications. While I prefer clear corners instead of smoked, yours' pulls it off rather nicely. Our cars are actually really similar, save for the suspension & wheel set up. Perhaps shadowline black vinyl your window trim? Keep up the good work!
'02 325ci 5MT
I take pictures in the San Francisco Bay Area.
www.eluisphoto.com
filipinoise is offline   Reply With Quote
Old 06-05-2013, 09:07 PM   #18
CJin2552
Believe it or not, I didn't like the smoked corners at the start either. Once I started to make it more of the monochrome look, I started to like them more and more. I am definitely looking to get KONI Shocks and some H&R Lowering Springs, but it will cost me a substantial hole in my pocket.
I do agree, our cars do look a bit alike. The main difference is the CSLs vs. the Style 71s.
Old 06-20-2013, 06:14 PM   #19
BStein325
My Ride: 2003 325Ci
Wink
I don't have my 325 anymore but you can look at my pics. The blacl only looked a little wierd because at the time I had just oainted over my stock wheels, had the black carbon fiber hood emblem, yellow lamin x, and 35% tint. Just looked wierd because it was a vert with a navy top. As for your sedan I think it would look great. I lile the steel blue metallic because its not a common color as for being a good challenge to build/customize. I can see black CSLs on yours and lowered. Changing all the stock lights out getting rid of all amber. Nice dark tint. You habe a good color to work with
BStein325 is offline   Reply With Quote
Old 06-20-2013, 06:15 PM   #20
BStein325
My Ride: 2003 325Ci
My phone keyboard is terrible sorry for typos -_-
