M3 won't start - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 06-05-2013, 10:43 AM   #1
jannah
My Ride: M3
M3 won't start
Hi can need sum suggestions on how to start my M3 lol. I have a 2004 SMG. She was chocking in low gears then SMG cog light came up on the dash I switched hur off now she is dead she wont crack over at all. I have changed the salom relay but still nufin
jannah is offline   Reply With Quote
Old 06-05-2013, 12:44 PM   #2
Moosecakes
My Ride: 02' SMG M3
Check the obvious first? dead battery, and search..
Moosecakes is offline   Reply With Quote
Old 06-05-2013, 07:33 PM   #3
sonnydm3
My Ride: 2004 m3
M3 won't start
Smg pump relay most common under hood by relay box
sonnydm3 is offline   Reply With Quote
Old 06-05-2013, 09:17 PM   #4
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
Get the codes read. You should check the obvious first. All belts intact. Battery is charged. Nothing is visually broken or missing. Then when you get the codes can go from there.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 06-10-2013, 12:06 PM   #5
jannah
My Ride: M3
Hey tnk you so much for ur reply dum me took it to the stealer 900 labour charge just to look at the cluch well they have had hur for 3 days now & called today to say in order to get the exhaust off to look at the cluch they need to brake the clip & apparently as they r rusty this will cost me an extra 110 = a whooping 1100 before any repair has even been done. OMG no wonder the dealership has been very fairly name the STEALER.
Old 06-11-2013, 04:24 PM   #6
khalilsmg
My Ride: 325iS,E36M3,E46M3
My guess is that the clutch hydraulic fluid is running low and therefore the pressure for the gearshift is too low for the pump to prime. SMG lights comes on, and the car won't start as a protection for the gearbox. Try topping up the hydraulic fluid, prime the SMG pump a few times by turning the key on/off a couples of times (maybe 15 or 20 times) and she should start. Good luck.
khalilsmg is offline   Reply With Quote
