Closed Thread
Old 06-11-2013, 12:13 AM   #41
dan avoN7
My Ride: A car
Originally Posted by Evil Twin Rob View Post
This is actually one of the bolts that came loose and fell out.
So it's a hub bolt, not a cam sprocket bolt as the *****kept insisting. Was your Vanos/head ever taken apart? Possibly to install ARP head studs or some sort of maintenance at one point?
dan avoN7 is offline
Old 06-11-2013, 05:37 AM   #42
FragNasty
My Ride: Car
Originally Posted by dan avoN7 View Post
So it's a hub bolt, not a cam sprocket bolt as the tard kept insisting. Was your Vanos/head ever taken apart? Possibly to install ARP head studs or some sort of maintenance at one point?
Can one of these bolts falling out cause cylinder damage? Or does it just fall into the oil pan and wait to be found?
FragNasty is offline
Old 06-11-2013, 10:24 AM   #43
InDiGlOM3
My Ride: HPF M3 stg 2.5
No it cant that's I'm possible. The main reason these come out is because people that have had them worked on. There is a spring washer behind the hub. So if you tighten one bolt it loosens another. So you really need to go around and tq them more then once. this way making sire they are all perfect.
Sent from my EVO using Bimmer App
InDiGlOM3 is offline
Old 06-11-2013, 11:41 AM   #44
FragNasty
My Ride: Car
Ok.
My question was actually supposing that a bolt does fall off [due to incorrect installation]. It would probably fall into the oil pan and remain there. My point of contention being that a bolt in the oil pan isn't going to cause cylinder damage.
Old 06-11-2013, 02:21 PM   #45
InDiGlOM3
No it won't cause damage from the pan. Unless your car flys upside down lol.
Getting to the oil pan from the hub thou can Fck some shyt up thou. If it falls into the chain and rams into a gear or something.
Old 06-11-2013, 02:48 PM   #46
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
if it s not some bolt, the tabs coming off and getting lodged in the chain..
deadlysyns' pix
"One thing we all adore. Something worth dying for..
Its been nothing but pain, stuck in this game. Searching for fortune and fame"
MachRc is offline
Old 06-11-2013, 03:14 PM   #47
FragNasty
My Ride: Car
Gotcha thanks.
Old 06-11-2013, 04:45 PM   #48
SiGmA_X
My Ride: 93 325iS
Are any of the reported failures from bone stock never worked on cars? Or are they all from cars HPF had worked on?
SiGmA_X is offline
Old 06-11-2013, 05:31 PM   #49
Commanderwiggin
My Ride: 900rwhp Turbo M3
Go to M3Forum...hundreds of hub failures, bolt shearing, etc...
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Commanderwiggin is online now
Old 06-11-2013, 07:09 PM   #50
Evil Twin Rob
My Ride: 2004 M3
A valve adjustment had been done, but I don't know if that work involves removing those bolts. I bought the car with 32k miles, so i'd be surprised if any of those bolts had been previously removed.
HPF 2.5
Evil Twin Rob is offline
Old 06-11-2013, 07:49 PM   #51
InDiGlOM3
Re: Cam Bolt Thread
Its almost never not hub bolts. I think you guys are confusing everyone lol. its either a tab breaking or the cam gear bolts. Not the hub bolts.
Sent from my EVO using BimmerApp mobile app
Old 06-11-2013, 07:51 PM   #52
InDiGlOM3
Re: Cam Bolt Thread
Rob when did it happen to you? Before or after turbo lot or after the build? Or all before? You don't loosen hub bolts for a valve job.
Old 06-11-2013, 08:26 PM   #53
Commanderwiggin
Ya that's what I meant cam gear bolts...no issues with the hub bolts.
Old 06-11-2013, 08:41 PM   #54
dan avoN7
My Ride: A car
If it doesn't get caught up in the timing chain then it will fall directly in to the oil pan. There it will sit until the pan is removed and the bolt/piece is retrieved. Cylinder damage from one hub bolt coming loose, HIGHLY unlikely.
Nope, the hub bolts are not touched during a valve adjustment. When exactly did you have this failure and also you are 100% certain that is the bolt that backed out?
+1 That's why I had mentioned earlier "They are likely confused or they are describing a different scenario" It's like a game of telephone
Old 06-12-2013, 02:02 AM   #55
e46_m3
My Ride: 05' Imola ZCP M3
Cam Bolt Thread
OolOe. Ne
e46_m3 is offline
Old 06-12-2013, 03:38 PM   #56
Forcefed M3
My Ride: HPF Stage 2.75
Originally Posted by MPOWAA View Post
Ok, I'll bite. I went through your links to forum members selling their cars "because of the proefi".
Here's what I found :
What was your point in all this? It seems perfectly clear to me that these cars ran great using the ProEFI/Saad setups. Have we even seen a 10 sec car on an AEM?
Couldn't agree more. +1
Of "course" the car that I am selling runs perfect, the fact that at least two were immediately sold after they took possession means nothing You thing the DME makes a difference and yes an AEM car has run a 10 second pass.
Forcefed M3 is offline
Old 06-12-2013, 03:41 PM   #57
Forcefed M3
Originally Posted by Saad @ Saad Racing View Post
Facts are that the people that sold their ProEFI cars got more because they run better. You just helped prove it, thanks What Vegas flap? As for Jason, he hasn't been on this forum in a long time. If he wanted to be he can, as I have offered to put him under my account and he declined. Just a little FYI for you, ass talker
You don't remember? Chads car was going to run 10's, then your car was going to run 10's? As for Jason he logged under a new name and started crap a bit ago, his new name was banned!!
Closed Thread
