Old 06-06-2013, 06:37 AM   #1
sd325i03
My Ride: bmw
valve cover nut and bolt came out together.
Hello Everyone, Well I Was Changing My Valve Cover Gasket And Whe Taking Off The Far End Middle Nut The Bolt Came With It .Didn't Notice Till I But It All Back Together When I Tried Tighting Striped.. The Car Runs Good N No Oil Leaks Should Or Is It Ok To Just Leave It Alone?
sd325i03 is offline   Reply With Quote
Old 06-06-2013, 12:03 PM   #2
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Why In The World Are You Capitalizing Every Single Word?
So you removed the valve cover and the stud came out with it, but you didn't notice until you put it back on? What did you strip, the nut? I'm confused.
Old 06-06-2013, 01:46 PM   #3
sd325i03
My Ride: bmw
Re: valve cover nut and bolt came out together.
The valve cover nut is still connected to the bolt.i striped the hole where the bolt goes in.
Sent from my DROID BIONIC using BimmerApp mobile app
ID:	509587   Click image for larger version
Old 06-06-2013, 02:17 PM   #4
Stinger9
My Ride: '04 330Ci
You're in danger of filling the spark plug hole with oil, and you won't be able to see if that is happening unless you pull the coil packs out.
Your choice as to whether you want to repair things properly, or monitor the last two holes for leaks frequently.
Old 06-06-2013, 06:20 PM   #5
2003silver330i
My Ride: 03 BMW 330i
If the threads in the hole broke off you will need to buy a time-sert kit. If the threads are still there than buy a tap and re-thread the hole.
2003silver330i is offline   Reply With Quote
Old 06-06-2013, 08:58 PM   #6
sd325i03
My Ride: bmw
The top part of the tread is gone only has tread at the bottom. Is the time sert the same as the heli coil? Already order new nut n bolt .the same valve cover gasket is fine ?
Old 06-06-2013, 09:02 PM   #7
2003silver330i
Yes you will be fine re-using the gasket. Yes the time-sert is similar to a heli-coil. Since these studs don't require much torque you can't go wrong using either one.
Old 06-06-2013, 09:08 PM   #8
Stinger9
My Ride: '04 330Ci
Similar meaning two different products from two different companys with two different methods of installaton?
People swear by one over the other so the difference should be noted.
Old 06-06-2013, 09:15 PM   #9
2003silver330i
However they are similar in what they intend to do, which is secure a bolt. For the OP's particular application either one will work.
Old 06-06-2013, 11:15 PM   #10
sd325i03
My Ride: bmw
Was Checking The Time Sert Kits And Wow Kinda Pricy .Also Not Sure What Size To Get My Bolt Is M7 6X29.5 Also There Are Two Types Carbon Steel N Steel I Just Don't Want To Mess This Up More .Any Help Would Be Greatly Appreciated..And About The Capitalization It's Doing It On It's Owen ..
Old 06-07-2013, 03:03 PM   #11
2003silver330i
I think you meant to post the size as M7/6X29,5
Old 06-07-2013, 03:06 PM   #12
2003silver330i
The time-sert kit #1710 will work
Old 06-07-2013, 03:41 PM   #13
Stinger9
My Ride: '04 330Ci
Cheaper than a new head
http://www.ebay.com/itm/TIME-SERT-NE...d01215&vxp=mtr
Old 06-07-2013, 05:57 PM   #14
sd325i03
My Ride: bmw
thanK You For All Your Help .Going To Take Care Of These Asap Hopefully Won't Run Into Another Problem ..Now I Just Have To Change These Setting On Capitalization.
