Koni FSD question - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 06-06-2013, 03:24 PM   #1
Mrob
My Ride: '01 3-Pedal 330i
Koni FSD question
I am looking into getting a Koni FSD setup with the Eibach springs. I wanna know if I will need spacers / camber kit to drop the full 1.4". Also, should I buy the $340 install kit which is seperate from the actual cup kit?
I am running M68 wheels with sport suspension on my 01 330i.
Mrob is offline   Reply With Quote
Old 06-06-2013, 04:05 PM   #2
SK330ci
My Ride: 02 330ci w/ 3 Pedals
Originally Posted by Mrob View Post
I am looking into getting a Koni FSD setup with the Eibach springs. I wanna know if I will need spacers / camber kit to drop the full 1.4". Also, should I buy the $340 install kit which is seperate from the actual cup kit? Post up a link to this.
First buy ans install the FSD / Eibach (Sportline or Pro-Kit ?), then assess if you
need spacers. Concerning the camber kit: remember, as you go lower you Automatically get more Negative camber. So camber plates may not be necessary.
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Special Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
Old 06-07-2013, 01:37 AM   #3
SK330ci
Buy these, and mix them with FSD's #2100 4006.
http://forum.e46fanatics.com/showthread.php?t=940061
The seller has had these for sale for quite awhile, offer less.
Old 06-07-2013, 07:33 AM   #4
Mrob
I dunno. 30K on them makes me feel a little uneasy. If there's anything I've learned in the short time that I've owned my car- buying new parts saves more money in the long run. Thanks for taking the time to look for me though. And I will be looking for the pro-kit.
Old 06-08-2013, 12:18 AM   #5
drumsauce
My Ride: 2000 323it
No, you will not need a camber kit. Suspension refresh is a good idea since you will be in there already, but cannot comment on the "install kit" as I am not familiar.
FWIW, on my touring, the front and rear came down a little less than an inch all around on the exact same setup. Best ride quality/handeling combo you can buy for e46. You will love it.
drumsauce is offline   Reply With Quote
Old 06-18-2013, 08:10 AM   #6
Afrodeezyak
My Ride: TiAg ///M
Re: Koni FSD question
I've been running this kit for about a month now and I didn't need spacers or chamber plates. Its a bit on the soft side for my liking but ride comfort is great. Looking at swapping them out for some coilovers now.
Sent from my SCH-I535 using BimmerApp mobile app
Afrodeezyak is offline   Reply With Quote
Old 07-15-2013, 05:43 AM   #7
MJM Distributing
Past Site Sponsor
My Ride: TOO MANY TO LIST
Send a message via AIM to MJM Distributing Send a message via Yahoo to MJM Distributing
You will not need spacers to run any Eibach product or any KONI product. Also, keep in mind that the FSD Shocks are not a full-on racing damper like the KONI Sports are, but the perfect medium between a stock shock and performance valved shock. In fact, KONI FSD Shocks are not approved to be used with any springs other than a stock spring, and of course, the Eibach Pro-Kit Springs. We met with a KONI engineer for dinner at SEMA one year and were explained the reasoning behind this. The Eibach Pro-Kit, more than any other spring they tested (and they tested several), showed to lower the car the exact drop as advertised from Eibach, something KONI needed for certainty, as the shock travel is minimum with the FSD Shocks and a spring offering even the slightest more in drop than advertised from said manufacturer, would not work. In other words, you cannot use a more aggressively rated spring with an aggressive drop like an H&R Race Spring or Eibach Sportline Spring with KONI FSDs. The FSD Shocks are not designed for that type of spring and would not be warrantied should there be an issue of any kind. The FSD's valving would not support it.
The KONI FSD Shocks are very nice and ride extremely well. We have one of our in-house cars here at the shop riding on this very setup and it's great. Again, it's not a full-on race car type feel, but a mild 1" drop is visible, the ride comfort is darn near like stock (and we are not joking), yet the steering response and handling is fantastic. It's definitely perfect for the street car that's never going to track the car, that wants a mild drop, wants the car to handle well, and likes the luxury of a shock absorber that's going to have Frequency Select Dampening, the technology that KONI uses that enables the shock to soften up for rough streets, all while firming up with recognizing smoother roads where some spiriting driving might take place. It's a great shock with great technology, brought to you by KONI, the ones that inventing rebound dampening technology in the first place.
Oh, and KONI's 44% sale is back for its Authorized Distributors. Feel free to PM us here if any of you guys would like to get in on that action.
Deals, deals!
MJM Distributing is offline   Reply With Quote
Old 07-15-2013, 11:02 AM   #8
ECSTuning
ECSTuning's Avatar
My Ride: BMW
I am looking into getting a Koni FSD setup with the Eibach springs. I wanna know if I will need spacers / camber kit to drop the full 1.4". Also, should I buy the $340 install kit which is separate from the actual cup kit?
With the mild drop Eibachs provide the factory adjustments put you very close to stock specs. A camber kit would not be required in this instance.
With the design of the Knoi FSD (stock shock style replacement) spacers are not required to provide clearance between the inner wheel/tire and the spring perch.
As for an install kit, what condition are your stock mounts in? Is your hardware corroded? If so it might be a good idea for you to pick up an install kit to prevent putting nice new shocks and springs on the car with blown shock mounts. Or even having to deal with reinstalling corroded or rounded off hardware.
Old 07-16-2013, 05:04 PM   #9
Handsome Kev
My Ride: 328
Koni FSD question
Deals, deals!
Would the FSD be good with H&R sport?
Handsome Kev is offline   Reply With Quote
Old 07-17-2013, 09:39 AM   #10
ECSTuning
ECSTuning's Avatar
My Ride: BMW
The FSD Shocks pair well with mild drop spring. They are not suggested for springs with a more aggressive drop.
-James
Old 07-18-2013, 12:25 AM   #11
MJM Distributing
Past Site Sponsor
As stated a few posts up.
Again, the FSD Shocks (per KONI) are not approved for anything other than the Eibach Pro-Kit Springs or OEM springs (based on the valving of the shocks, required spring rates and required drop levels needed from a spring for that shock to be effective). Again, it is not a racing damper like a KONI Yellow (Sport) Shock is. This is per KONI engineers and is explained in detail above a few posts up.
Old 07-18-2013, 12:59 AM   #12
MJM Distributing
Past Site Sponsor
Originally Posted by ECSTuning View Post
The FSD Shocks pair well with mild drop spring such as the Eibach Pro kit Springs (1.0-1.4"F 0.8-1.4"R) and the H&R Sport Springs (1.4"F 0.75"R). They are not suggested for springs with a more aggressive drop.
-James
James,
You might want to call Lee Grimes or Jim Ryan at KONI for clarification on this. Unless something has changed since 2011, warranty will not be honored when running any H&R Sport Spring on a KONI FSD Shock (for the reasons we outline above). As a Master WD for KONI, that buys direct from them, and attends their quarterly training seminars, this has been per KONI engineering since that shock was introduced. It's also stated on the KONI website.
Old 08-27-2013, 02:53 PM   #13
Poncho@home
My Ride: MY04 330Cic ZSP
I have a '04 330Ci convertible with factory sport suspension. Will the FSDs change ride height if I retain my original springs? Is't ride height a function of springs?
How do they work/feel on the slightly heavier convertibles?
Poncho@home is offline   Reply With Quote
Old 08-27-2013, 03:07 PM   #14
MJM Distributing
Past Site Sponsor
Ride height is not affected whatsoever with the FSD Shocks.
The fact that it's a convertible will also not deter from the ride quality with the FSDs.
Old 08-27-2013, 11:54 PM   #15
drumsauce
My Ride: 2000 323it
There have been cases where people with verts use the eibach pro-kit/FSD and experience a more dramatic drop in ride height, but I have not seen any instances with that happening using stock springs. You are correct, springs determine right height, for the most part. But, worn bushings or even high-pressure dampers (bilstiens) have been known to change the ride height even on stock springs.
FSD will be a great upgrade with stock springs.
