Old 06-06-2013, 07:44 PM   #1
AdelxS22
My Ride: 2000 323Ci
Car stalls and shakes
HELLO everyone, recently i was driving my 2000 bmw 323ci and i ran over a pothole and my check engine light and my transmission light turned on. i stopped the car and let it cool off and then i started it and while it was in park the RPM kept revving up. Then I tried driving it and the whenever i pull to a stop or a light the car stalls and shakes i have to hit the gas to keep it from stalling out. Took it to autozone and it gave me few codes. About 7, the codes are P0303 - MISFIRE DETECTED-CYLINDER NUMBER 3
P0301 - MISFIRE DETECTED-CYLINDER NUMBER 1
P0101 - MAF SENSOR DIRTY OR DEFECTIVE
P0130 - HEATED OXYGEN SENSOR - BANK 1 SENSOR 1
P1770 - TRANSMISSION RANGE SENSOR CIRCUIT MALFUNCTION- OPEN
P1188 - FUEL CONTROL BANK 1 SENSOR 1
P1189 - FUEL CONTROL BANK 2 SENSOR 2
IF ANYONE HAS ANY SUGGESTION TO WHAT IT CAN BE PLEASE HAVE WRITE YOUR INPUT I WOULD LOVE TO GET THESE PROBLEMS TAKEN CARE OF .
AdelxS22 is offline   Reply With Quote
Old 06-06-2013, 08:43 PM   #2
lszlszx
My Ride: 1.8T, XC70
Check the two intake boots that are between the MAF sensor and the throttle body for cracks. While those are off clean the MAF sensor with MAF sensor cleaner, as a first step.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 06-06-2013, 08:45 PM   #3
scarede46er
My Ride: 2001 BMW 325i ZSP
What he said. If that doesn't fix it, check the wiring of the MAF else replace it. How long ago were your O2 sensors replaced?
Old 06-06-2013, 08:47 PM   #4
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
The fact that it started right after you hit a pothole probably means you jarred something loose. Check the intake boots and the MAF.
Drew@Swift Motorworks is offline   Reply With Quote
Old 06-06-2013, 09:49 PM   #5
trj
My Ride: 325Ci
I say check for misfires. Check for the codes.
Every time there is a shake under the hood with a SES, it very possible that one or more cylinders are misfiring.
But the transmission icon leads me to think it is MAF though.
