Old 06-06-2013, 08:06 PM   #1
dancmos
My Ride: BMW 323i
Gas smell at altitude
I drove my '00 323i up Pikes Peak today. It ran just fine, but suddenly at about 12,000 ft altitude, we started to smell fumes. We checked thoroughly for any leaks and saw none. We drove up to the summit at 14,000. Again, no leaks and the car ran fine.
On the way back down, the smell went away at around 11,000 feet. And still no leaks and no smell whatsoever.
Any ideas?
dancmos is offline   Reply With Quote
Old 06-06-2013, 10:04 PM   #2
lszlszx
My Ride: 1.8T, XC70
There might be a weak spot somewhere in the evap system on your car and gas fumes were able to escape due to the lower of atmospheric pressure at the high altitude?
Pikes Peak sounds like a lot of fun, I am putting it on my road trip to do list.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 06-06-2013, 10:06 PM   #3
dancmos
My Ride: BMW 323i
Hmmm, that makes sense. My nephew was with me and he's a mechanic and he thought it might be the evaporative system as well.
Old 06-06-2013, 10:23 PM   #4
lszlszx
My Ride: 1.8T, XC70
There is supposed to be a pressure test for the evap system to locate leaks. I don't know how it's done, but short of that maybe you can just do a visual inspection in the area of the car where the smell was coming from.
It might be a loose clamp due to deterioration of a hose under it.
Old 06-06-2013, 10:37 PM   #5
dancmos
My Ride: BMW 323i
Thanks so much!
I'll do that. It seems like fumes in the cabin are a bad idea
Old 06-06-2013, 10:49 PM   #6
trj
My Ride: 325Ci
Pikes peak road is open now?
Great. That's the trip I make two times a year. Early in the season and later in the season.
I know where to go next weekend when I finish dealing with the creaking noise with the suspension.
About your issue, check the hoses at the fuel filter and the fuel rail on the manifold. If you are smelling inside the cabin the leak might be at the rails.
Old 06-06-2013, 10:51 PM   #7
dancmos
My Ride: BMW 323i
Will do that
Today was the first day it was open. I'll check those hoses too.
I did a little write up on the drive up with pix.
http://oppositelock.jalopnik.com/a-l...peak-511801476
Old 06-07-2013, 10:12 AM   #8
trj
My Ride: 325Ci
Nice write up man.
I might hit it up next week.
Old 06-07-2013, 10:30 AM   #9
Patton323I
My Ride: R1100GS E46 E53
I wish I could drive up a mountain pass....
Patton323I is offline   Reply With Quote
Old 06-07-2013, 03:35 PM   #10
Yewzer B Lewzer
My Ride: 2003 325i
Blue ridge parkway isn't far from you right?
^^Blue Ridge Parkway^^ '03 325i. '74 Jeep CJ-5. '93 Sailfish 170XL. '12 Westside SS Longboard. One of these four are sure to be running at any given point in time.
Yewzer B Lewzer is offline   Reply With Quote
Old 06-07-2013, 03:41 PM   #11
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Damn. Congrats on getting up to pikes peak!! I was amazed going up in the Rockies to 11k feet
Old 06-07-2013, 05:46 PM   #12
trj
My Ride: 325Ci
Jake, I really wished you could go to Pikes peak and Mt.Evans on your stopover at Denver. But those roads were still closed for the season.
Those are two places that everyone should drive by on their e46. Thats where it really shines.
Another pass is the independence pass. From Golden to Aspen, CO. One of the best drives I ever took in my car.
Old 06-07-2013, 06:15 PM   #13
dancmos
My Ride: BMW 323i
One day at 7k feet with no fume smell. I haven't had time to look at the potential culprits.
altitude, gas smell, pikes peak
