Old 06-06-2013, 08:27 PM   #1
Jsmk23
My Ride: 02 325i-JapanRot Red
E46 stalls and no power
Sorry guys, my car just yesterday started to stall on my and give me no power.
After exiting off the freeway, I was waiting at the light to turn and my car starting stalling and it was idling rough. The rpm gauge was going up and down, not too much though.
Once i got a green light, I push the accelerator and no power, after 2-3 seconds it finally kicked in. After driving a little more it went back to normal.
Same thing happened today, and again the car drives normal again
Any ideas?
BTW: codes are
P0313
P0300
P1345
P1347
P1342
P0444
P0492
P0491
Jsmk23 is offline   Reply With Quote
Old 06-06-2013, 08:50 PM   #2
scarede46er
My Ride: 2001 BMW 325i ZSP
Bad ignition coils?
Old 06-06-2013, 08:51 PM   #3
scarede46er
The codes are irrelevant and have to do with emissions, as far as I know.
Old 06-06-2013, 09:09 PM   #4
Jsmk23
Sorry I just went to pep boys and they pulled 8 codes!!!!!
P0313
P0300
P1345
P1347
P1342
P0444
P0492
P0491
Old 06-06-2013, 09:31 PM   #5
ZHPSteve
My Ride: 2004 330i ZHP
Sounds like the symptoms I had when my fuel pump was going out. Check the boards, it's an easy DIY if that turns out to be the cause.
ZHPSteve is offline   Reply With Quote
Old 06-06-2013, 09:38 PM   #6
Jsmk23
A fuel pump would pull all those codes?
I'm not gonna lie, but I to tend to drive with a 1/4 fuel and less.
Old 06-06-2013, 10:13 PM   #7
lszlszx
My Ride: 1.8T, XC70
This does sound like a fuel delivery issue.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 06-06-2013, 10:16 PM   #8
Jsmk23
Would 8 different codes mean 8 different problems that need fixing? Sorry I'm new.
Old 06-06-2013, 10:21 PM   #9
ZHPSteve
I don't believe so, but there are a bunch of guys on here who would be able to answer that better than me. I could see where fuel delivery could trigger multiple codes since it's really going to set the engine off. The giveaway to me was the fact it started running better again for a short time, that happened to me twice over a period of about 5 days before it was no longer drivable.
How many miles do you have on your car? The majority of pumps seem to be going out between 100K and 120K Miles.
I'll look up the thread for the fuel pump issues and post it here for you to review
here it is, worth reading in full
http://forum.e46fanatics.com/showthr...ight=fuel+pump
If you do need a new pump, do the filter at the same time. Plenty of suggestions for suppliers, but I've always had a great experience with Max at OEMBimmerParts.com, his prices are competitive and delivery times are usually very quick.
Old 06-06-2013, 10:49 PM   #10
Jsmk23
I just hit 110k
I was hoping to drive 250 miles round trip this weekend, I wonder if its possible with my situation going on.
Old 06-06-2013, 10:58 PM   #11
ZHPSteve
Originally Posted by Jsmk23 View Post
I just hit 110k
I think you would be asking for trouble....think about what it might cost you if you get 125 miles from home and the car won't start to come back home...
Is there anyone locally that you could pickup a pump from? Install takes 45 minutes to an hour (excluding the filter).
Old 06-06-2013, 11:09 PM   #12
Jsmk23
Yeah I don't mind changing the FP tomorrow but only if I knew for sure that's the problem.
Old 06-07-2013, 06:46 PM   #13
Jsmk23
Just got back from a free diagnostic check up and it's the FP, and to change the FF as well.
Any good websites to check them out?
Thanks again.
Old 06-07-2013, 07:37 PM   #14
jfoj
My Ride: 330CiC, M5, X5, E93
Not sure this is a fuel pump issue??
So when do the misfires happen, cold start?
You may also want to read this over VERY carefully - http://forum.e46fanatics.com/showthr...6&highlight=50
DISA O-ring, lower intake boot and CCV lower oil return line are very common problems and relatively cheap repairs.
Fuel pump and filter is not a bad idea anyway, not sure this will solve your current issue.
Suggest you visually inspect the items I listed above and read the link a few times so you understand the issues.
Old 06-07-2013, 09:49 PM   #15
ZHPSteve
Max @ OEMbimmerparts has always taken great care of me when i've needed parts quickly.
Old 06-08-2013, 03:10 AM   #16
Jsmk23
It starts up fine. It happened twice so far but it was at random so I can't tell what exactly causes it.
It just idles rough, and sounds like it was to shut off.
But after a while it goes back to normal.
Old 06-08-2013, 05:08 AM   #17
jfoj
If you claim this is only happening when warm, then it could be fuel pump related.
You really should get a scan tool that will display Freeze Frame data as this would likely be very helpful in this case.
You should read this post for more info on scan tools and software - http://forum.e46fanatics.com/showthread.php?t=967204
Old 06-08-2013, 07:09 PM   #18
Jsmk23
What do you guys think?
Fuel pump on eBay from Bavarian auto for 85$ shipped
item.mobileweb.ebay.com/viewitem?itemId=370689064524&siteId=0&isClassified=false#
And a Mann fuel filter from stockwiseauto.com ?
Old 06-09-2013, 12:48 AM   #19
trentcdrums
My Ride: BMW 323i Sedan
Most likely a hidden misfire or multiple. Happened to me.. Replace coil packs and move on.
Old 06-09-2013, 03:51 AM   #20
dznuts007
My Ride: 2001 325i Sedan
$85 is a pretty good price for a fuel pump. It's a Uro brand though and I think most members would recommend the Siemens fuel pump. It's about double the cost, but I think $150 is still pretty good compared to the $325+ list price. Either way a new fuel pump and fuel filter would be recommended as preventative maintenance so that you don't get stranded somewhere.
, autohausaz.com and bmaautoparts.com are some of the sites I like to use. Prices are good and parts arrive quickly.
You can rent a fuel pressure tester at Autozone for free to see if that's one of your issues.
Also make sure you check out jfoj's links and suggestions. They really helped out when my smog tests failed twice...those damn new STAR testing requirements!
dznuts007 is offline   Reply With Quote
