Old 06-10-2013, 08:29 PM   #21
Jsmk23
My Ride: 02 325i-JapanRot Red
E46 stalls and no power
I just changed the fuel filter and it's still the same.
Fuel pump sounds like its working.
I noticed that when I try to accelerate there's not power whatsoever.
Jsmk23 is offline   Reply With Quote
Old 06-20-2013, 11:51 PM   #22
Jsmk23
Anyone?
Old 06-20-2013, 11:58 PM   #23
dznuts007
My Ride: 2001 325i Sedan
Have you tested your fuel pressure and get fuel trim readings?
Also, what other things have you tried fixing/replacing?
dznuts007 is offline   Reply With Quote
Old 06-21-2013, 08:40 AM   #24
Jsmk23
No how would I do that?
I just replaced the fuel filter with the fuel pressure.
Its weird, when I was gonna change the FF, I unplugged the FP fuse so I won't spill alot of gas.
After it was changed, I started it back up and it stopped idling rough for a couple weeks and just last night it started again.
What are some other options?
Old 06-21-2013, 09:27 AM   #25
B3ZKONTROLU
My Ride: 03 325i and 04 545i
Had the same issue, I swapped out my fuel filter, it helped temporarily, but then began stalling again. Swapped out Fuel Pump, and BAM back to perfection! Fuel pump for sure!
B3ZKONTROLU is offline   Reply With Quote
Old 06-21-2013, 09:43 AM   #26
trentcdrums
My Ride: BMW 323i Sedan
Change coils! Got mine brand new for 156 shipped off amazon.
Old 06-21-2013, 10:40 AM   #27
dznuts007
$85 is a pretty good price for a fuel pump. It's a Uro brand though and I think most members would recommend the Siemens fuel pump. It's about double the cost, but I think $150 is still pretty good compared to the $325+ list price. Either way a new fuel pump and fuel filter would be recommended as preventative maintenance so that you don't get stranded somewhere.
, autohausaz.com and bmaautoparts.com are some of the sites I like to use. Prices are good and parts arrive quickly.
You can rent a fuel pressure tester at Autozone for free to see if that's one of your issues.
Also make sure you check out jfoj's links and suggestions. They really helped out when my smog tests failed twice...those damn new STAR testing requirements!
^^^ "You can rent a fuel pressure tester at Autozone for free to see if that's one of your issues."
After you rent it, there are some videos on Youtube that show you exactly how to do it or you can Google "E46 test fuel pressure". Really easy and getting the results will tell get you some good info as to whether or not your fuel filter and fuel pump are the possible culprits. Also make sure you read up on Jfof's links. He has the #'s you're going to want to see.
Old 06-21-2013, 02:04 PM   #28
Jsmk23
I was guessing it might be my spark plugs/coils.
Should I do that or the FP?
Old 06-21-2013, 02:16 PM   #29
David McMahon
My Ride: '99 E38 740iL
All above seems to point to FP, and your one seems to be "due" to go @110k
I'd change it now, clear codes and *touch wood* all will be well.
David McMahon is offline   Reply With Quote
Old 06-21-2013, 02:42 PM   #30
Jsmk23
Thanks.
Would a bad FP set off all the misfiring codes?
Old 06-21-2013, 02:48 PM   #31
David McMahon
Originally Posted by Jsmk23 View Post
Thanks.
Not sure, I'd clear codes (but keep note of them) after getting a new FP, I'd argue that getting one is a good PM move anyway.
Old 06-21-2013, 04:34 PM   #32
dznuts007
I think bad fuel pump might cause low fuel pressure and/or volume and contribute to the "running lean" code.
Testing your fuel pressure can possibly help determine if the fuel pump is going bad or is bad. Again, read jfoj's links. They are very informative and has all the information you're asking. It's written quite well to where non-mechanics (such as me) can understand it and benefit from it.
Just like recommended above, wouldn't be a bad idea to change out your fuel pump. Your car is an '02 and the pump can give out any day now, or it can still keep working. Just not optimally. These repairs/replacements you're doing will not be in vain since you're replacing wear and tear parts. I've been doing alot of DIY's and replacing hoses, boots, valves, sensors, etc and my car feels like it's running great!
Old 06-21-2013, 08:06 PM   #33
Jsmk23
Thanks.
When i got my fuel filter there was a choice of 2 different kinds, one with the fuel pressure regulator and on without. I had to get the one with the regulator
Now with the FP, is there only one type to get?
Also any good websites/brands you reccommend?
Thanks.
Old 06-21-2013, 08:19 PM   #34
David McMahon
Thanks.
Thanks.
There are lots on the site, most important thing is to get the correct type, I believe there are at least three types.
M52, M54 and M56, the M56 being very unusual
Goto Realoem.com to find your correct FP, have the last 7 digits handy, I'm sad enough to remember mine!
Old 06-21-2013, 08:46 PM   #35
dznuts007
Cant go wrong with the Siemens pump
Old 07-17-2013, 10:58 AM   #36
Jsmk23
Bump
Old 07-17-2013, 11:37 AM   #37
dgknight
My Ride: 02 325xi 5sp 120k
Best price I found for oem pump was bmaparts.com. And 5% off that with code specE30.
Fault codes will be reported whenever a sensor detects out of range parameters. Low fuel pressure can cause misfires and thus misfire and lean trim codes, but there is not a 1:1 mapping of codes to failed parts which is why you are getting multiple answers. If you can do more diagnosis as suggested, you can narrow down the possibilities. When my fp died at about 115k it just shut off - no codes. It first did it at 110k and AAA whacked my fuel tank with a mallet and it restarted. I assumed it was the fuel filter, changed that and it bought me 5k miles and then I got deserted 300 miles from home with no warning. Another mallet tap got me home - lucky.
It sucks throwing parts at something, but your fp is definitely around failure time anyway, so if you swap it you are not 'wasting' money even if it is not the issue - it will be an issue soon.
Plugs are due at 100k so if they have never been swapped do those too. Pushing the plug change will put strain on the coils, and those are expensive if they let go.
dgknight is offline   Reply With Quote
Old 07-17-2013, 11:37 AM   #38
David McMahon
Bump
Changed FP yet?
Old 07-17-2013, 04:12 PM   #39
Jsmk23
Have not changed FP yet, I don't mind changing it but it sounds like its working.
Has not died on me (not yet hopefully).
It starts up fine, but noticed not lately it starts to idles rough right away before it would never, just a few weeks once at a time.
And the last 2 days it's been doing it once its warmed up.
Old 07-17-2013, 05:36 PM   #40
David McMahon
FP might help, is due anyway.
I would reset and charge battery overnight.
