Old 07-17-2013, 11:35 PM   #41
Jsmk23
My Ride: 02 325i-JapanRot Red
I just bought my FP, gonna put it in this weekend, This better be it lol
Jsmk23 is offline   Reply With Quote
Old 07-17-2013, 11:38 PM   #42
dznuts007
My Ride: 2001 325i Sedan
Hahah, hope so too. If not, at least have peace of mind that you have a new fuel pump. Getting stranded on the road sucks
dznuts007 is offline   Reply With Quote
Old 07-17-2013, 11:43 PM   #43
Jsmk23
Yeah thats why I'm being positive about this lol
Old 07-20-2013, 02:04 AM   #44
Jsmk23
Just swapped the fuel pump, power is back, but still have a rough idle, but not too much.
Old 08-13-2013, 09:52 PM   #45
Jsmk23
E46 stalls and no power
Sorry to bug you guys again.
But it just happened to me again.
I've changed fuel filter, fuel pump, spark plugs and clean the MAF in that order.
I also noticed that when unplug the fuel pump fuse and plug it back in, the car runs normal again.
So it buys me time but it'll come back weeks later.
Any help?
Old 08-14-2013, 10:06 AM   #46
Jsmk23
Bump
Old 08-14-2013, 07:24 PM   #47
Jsmk23
Old 08-21-2013, 09:04 PM   #48
Jsmk23
Also, I noticed my o2 sensor light came on. P0155
And when I looked in the engine to check it out I seen that some oil (maybe coming from the VCG) is on the sensor.
I know it's gonna need to be replaced but what could happen to this?
Idk if its a coincidence or maybe it's suppose to but my car tends to idle rough and such when I get close to 1/4 level of fuel or less.
Does it have to do with anything?
Old 08-21-2013, 09:25 PM   #49
scarede46er
My Ride: 2001 BMW 325i ZSP
Fuel pump if it gets bad with 1/4 tank of petrol.
Old 08-21-2013, 09:52 PM   #50
Jsmk23
already replaced fuel pump.
Old 08-22-2013, 03:46 AM   #51
BMANN405
My Ride: 2002 325ci
Change VCG and pre cat o2 sensors. U can probably get away with not changing post cat sensors as they rarely go bad and are far more difficult to change. While you are in there check vacuum hoses for breaks and cracks. Take a good look at your intake boot as well. Could be dried out or cracked. Good luck!
BMANN405 is offline   Reply With Quote
Old 08-22-2013, 08:06 AM   #52
dabu320i
My Ride: 2001 BMW 320i sedan
Hey there Jsmk23. From your description of ur problem it sounds like I have the exact same issue with mine. It doesn't happen all the time but when it does it usually happens at first start up if I wait too long before driving. I usually have to drive it straight away, but even that sometimes doesn't work. it idles funny (shakes) and it stalled on me a few times before (embarrassing). No power when i accelerate. When this happens, I pull over and turn the car off for a few seconds to a minute then start it back up and that fixes it for me. I have taken it to a mechanic before and they rekon it might need new coils and plugs. I'll get around to doing that once I get enough money but for now, turning the car off for a few seconds to a minute works like a charm!
dabu320i is offline   Reply With Quote
Old 08-22-2013, 09:49 AM   #53
BMANN405
My Ride: 2002 325ci
There u go. With that amount of mileage if u haven't done plugs and coils now would b a good time. B easy to do when u r in there doing VCG. If u have the money and don't mind doing some PM that is.
Old 08-22-2013, 01:55 PM   #54
Jsmk23
Just took it to a Indy BMW shop.
Hope to get what the problem is instead of shooting in the dark as I been doing.
Hopefully it's nothing too serious and costly $$$$.
Old 08-22-2013, 02:56 PM   #55
davidt443
My Ride: 2001 325i
If the idle problem and sluggish problem still persist, unplug the MAF sensor connector, and try running it and see if it fixes the idle, you will set a code by doing this but it is just a test. Thats what i found in my case, replaced fuel pump fuel filter even though they were good, and then found out it that the MAF was bad the whole time, good luck
davidt443 is offline   Reply With Quote
Old 08-22-2013, 03:13 PM   #56
dabu320i
let us know how u go I'd love to get mine fixed too
Old 08-22-2013, 03:21 PM   #57
piaa_ump
My Ride: 2000 328CI
anyone suggest replacing the camshaft positioning sensor?..........when mine went bad, the symptoms were rough idle and stalling and reduced power.....not sure if the OP threw that code or not.......but easy fix......
piaa_ump is offline   Reply With Quote
Old 08-22-2013, 06:02 PM   #58
Jsmk23
Just got the results.
They told me it was the fuel tank breather valve and a bad SAP.
Is this right?
Old 08-22-2013, 06:18 PM   #59
BMANN405
My Ride: 2002 325ci
Not sure about "fuel tank breather valve" maybe they mean evap canister? A bad SAP pump will have absolutely no affect on how the car runs or idles tho. It only works for the first 90 to 120 seconds after a cold start. My SAP relay was bad and pump wasn't even running. I didn't find out until inspection time when I had one "not ready" MA allows one system not ready so still passed but decided to see if I could fix it myself. Had no idea relay was bad and system wasn't working cuz car was running fine and I didn't know that system existed in these cars until doing some research on this forum.
Pump looks easy to replace but I believe it's a bit expensive. Around 340 if I remember correctly. Let them change out other part but I would wait on SAP Pump and perhaps DIY
Old 08-22-2013, 06:27 PM   #60
BMANN405
My Ride: 2002 325ci
My bad. There is a Fuel Tank Breather Valve on these cars located between throttle body and charcoal canister. Looks like easy part to replace. ECS Tuning has it for 73.00 and it will give a CEL when it goes bad.
