Old 08-22-2013, 07:35 PM   #61
Jsmk23
My Ride: 02 325i-JapanRot Red
E46 stalls and no power
Originally Posted by BMANN405 View Post
My bad. There is a Fuel Tank Breather Valve on these cars located between throttle body and charcoal canister. Looks like easy part to replace. ECS Tuning has it for 73.00 and it will give a CEL when it goes bad.
They told me that the fuel tank breather valve is at the end/ back of the car.
Jsmk23 is offline   Reply With Quote
Old 08-23-2013, 07:58 AM   #62
BMANN405
My Ride: 2002 325ci
That's where I think it's located as well. Was quoting ECS part description.
BMANN405 is offline   Reply With Quote
Old 08-23-2013, 08:46 AM   #63
Jsmk23
The part number on my paper they printed is
# 13901433603
And from that part number it looks like the EVAP purge valve which is in the engine.
But they called it the fuel tank breather valve.
Is that what they meant ? Or is it the one in the rear?
Old 08-23-2013, 05:29 PM   #64
BMANN405
My Ride: 2002 325ci
No, that's the correct part number for the Fuel Tank Breather Valve.
Old 08-23-2013, 05:58 PM   #65
Jsmk23
Okay just to clarify is it a part to go inside the engine or back in the tank?
Old 08-24-2013, 05:56 AM   #66
BMANN405
My Ride: 2002 325ci
According to ECS Valve is between charcoal canister and throttle body.
This is the valve that sends the fumes from the fuel tank to the throttle body to be burned.
If this valve fails you'll receive a check engine lamp. Still not sure on location but don't think it's in the tank. Gonna look around on mine later to see if I can find it. Did your shop replace it yet?
Old 08-24-2013, 09:26 AM   #67
LuiGProdigy
My Ride: 2002 325i
Re: E46 stalls and no power
This happened to me one time, it was my MAF sensor. Happened again one time, and it a misfire, I guess because it was parked for a long time.
2002 325i
Style 197 18s - ZHP Bumper - Angel eyes - Smoked Tails and Corners - H&R Sports - AUX Radio MOD... More to come.
LuiGProdigy is offline   Reply With Quote
Old 08-24-2013, 11:37 AM   #68
Jsmk23
No I just took it to get my car checked out and they said it was the fuel tank breather valve(which I'm assuming is the EVAP purge valve) and the SAP
but I'm planning on changing it myself.
Old 08-24-2013, 02:04 PM   #69
dedekind
My Ride: 2001 330ci
Keep us posted! Slightly similar issue with my car.
dedekind is offline   Reply With Quote
Old 08-24-2013, 07:02 PM   #70
Jsmk23
http://item.mobileweb.ebay.com/viewi...d=170674458079
So is this the exact part?
Because I'm confused between the fuel tank breather valve and EVAP purge valve.
Old 08-24-2013, 08:03 PM   #71
Jsmk23
P1085
P0183
P0174
P0171
Those are the codes I have now.
No more misfire codes anymore
Old 08-26-2013, 07:34 AM   #72
dabu320i
My Ride: 2001 BMW 320i sedan
any updates? did u get it fixed?
dabu320i is offline   Reply With Quote
Old 08-26-2013, 07:49 AM   #73
Jsmk23
Just ordered the part over the weekend.
Hopefully to get it during the week so I can slap it on.
Old 08-30-2013, 03:09 AM   #74
dabu320i
let us kno how u go
Old 08-31-2013, 10:59 PM   #75
Jsmk23
Just swapped the EVAP purge valve (Fuel tank breather valve) and also inspected the DISA and cleaned the idle control valve and throttle body.
Old 09-03-2013, 03:29 AM   #76
dabu320i
did it fix the problem ?
Old 09-03-2013, 10:35 PM   #77
Jsmk23
Any suggestions to my problem here?
I cleared my codes last night and so far all I have are:
P0430
P0174
P0171
P1085
I have replaced fuel filter, fuel pump, spark plugs, EVAP purge valve
Cleaned: Mass Air Flow sensor, Idle control valve and Throttle body
I also noticed that my precat o2 sensor is covered in oil (possibly from VCG).
Was going to change my VCG this weekend and going to order new o2 sensor right after.
Any suggestions?
Old 09-05-2013, 06:41 PM   #78
dabu320i
sorry I don't kno much about this stuff I was hoping u cud find out the problem so I cud get mine fixed too
Old 09-10-2013, 06:54 PM   #79
dabu320i
car stalled this morning on the highway in peek hour traffic!! that was embarrassing!!
any news on ur car?
Old 09-12-2013, 11:29 PM   #80
dabu320i
geting desperate to get my car fixed. anyone have the same problem?
