Old 09-14-2013, 05:49 PM   #81
Jsmk23
My Ride: 02 325i-JapanRot Red
Just changed VCG when I noticed something.
Its a vacumm line that is coming from some valve of the secondary air pump.
I found it near the cables with the oxygen sensor.
Would this cause my misfiring/idle problems.?
Where does this vacumm line lead to?
Jsmk23 is offline   Reply With Quote
Old 09-14-2013, 06:39 PM   #82
dznuts007
My Ride: 2001 325i Sedan
Here you go. I would replace it regardless if is the cause of your problem or not hahah. Hopefully it stops the issue
dznuts007 is offline   Reply With Quote
Old 09-14-2013, 07:16 PM   #83
BMANN405
My Ride: 2002 325ci
E46 stalls and no power
Most likely not the cause of your problem but I would change it cuz it could throw a code which would be a problem come inspection time. The SAP pump only comes on for about 90 seconds just after a cold start. Funny cuz I needed to change the same line and didn't find out it was bad until I changed my VCG. Car was running fine but line was dry rotted.
BMANN405 is offline   Reply With Quote
Old 09-14-2013, 07:39 PM   #84
Jsmk23
I assumed this has to be it cuz I had taken it to an Indy shop and they said I needed a new one and that it was causing my rough idle/misfire/loss of power.
What does that vacumm go to?
Old 09-15-2013, 09:15 AM   #85
BMANN405
My Ride: 2002 325ci
Looks like #3 in the diagram. Long line that starts at check valve and goes around back of engine to solenoid. If that is the line that's in your pic it's definitely not the cause of your rough idle. It's for emissions only. SAP pump only comes on for about 90 seconds after cold start than shuts off. Mine was rotted and was disconnected from the check valve yet car was still idling and running fine.
Old 09-17-2013, 08:44 AM   #86
Jsmk23
Still have codes P0171, P0174, P1083, P1085 codes. I just replaced VCG from little oil residue on manifold ad pre cat o2 sensor on bank 2.
Also replaced that o2 sensor as well.
What else can it be?
Old 09-17-2013, 09:39 AM   #87
jfoj
My Ride: 330CiC, M5, X5, E93
Dude, you have to stop here an listen for a moment, this thread is way too long (87 replies) for likely a simple issue that is being overlooked?
You NEED to provide the following information if you expect to get anywhere with this problem.
1. All Freeze Frame date for each DTC/trouble code you keep getting. This is scan tool specific if you can read and see Freeze Frame Data.
2. Long Term Fuel Trim values at warm idle and while at a steady cruise 40-50 MPH.
3. Explain any driveability issues you may be having. Example cold stumble in the morning, stall, rough idle and when the CEL/SES light typically comes on.
4. Explain how long/many miles it takes for all your Emission Readiness Monitors to clear.
5. You need to tell us what OBDII scan tool you are using, make and model.
Once you post this info up, it will be far easier to see what is going on.
It appears you have a lean fuel mixture condition, but it the lean condition accurate or do you have a false lean condition due to faulty or incorrectly connected sensors?
Hope you can understand what I am asking and can provide the specific data without clouding the picture.
If you do not have the proper scan tool, you NEED to buy one that supports Freeze Frame and Live data. They are less that $100, likely it would have saved you at least this much money by now?
Read this - http://forum.e46fanatics.com/showthread.php?t=967204
Old 09-25-2013, 07:08 AM   #88
dabu320i
My Ride: 2001 BMW 320i sedan
any updates on the situation??
dabu320i is offline   Reply With Quote
Old 09-25-2013, 02:15 PM   #89
Jsmk23
Nothing. It comes and goes.
Old 09-25-2013, 11:44 PM   #90
dabu320i
damn!! exact same problem I have still ..
Old 09-25-2013, 11:45 PM   #91
dabu320i
anyone else have this problem or have experienced this before?
