Old 06-07-2013, 09:07 AM   #1
Pole position
My Ride: E46 330ci
Quick- is this diff oil good?
Just picked up some valvoline 75w 90 synthetic gear oil to do a diff oil change today. It's all the shop had in that weight . Is this an ok, or good oil to use? Just double checking, thanks
Shut up and drive
Pole position is offline   Reply With Quote
Old 06-07-2013, 09:10 AM   #2
philljones54
My Ride: 03 325xi
Re: Quick- is this diff oil good?
Not sure... check wiki
Sent from my Torque using BimmerApp mobile app
philljones54 is offline   Reply With Quote
Old 06-07-2013, 09:38 AM   #3
pcarney
My Ride: 2002 330ci
It does not say on the bottle if it meets BMW SAF-XO. I would recommend Redline, LiquiMoly, Motul, or BMW.
pcarney is offline   Reply With Quote
Old 06-07-2013, 09:45 AM   #4
Pole position
My Ride: E46 330ci
here is its spec sheet, any ideas? http://www.valvoline.com/pdf/synpower_gear.pdf
Shut up and drive
Old 06-07-2013, 10:10 AM   #5
pcarney
My Ride: 2002 330ci
Valvoline is a great product....For a Jeep....
Old 06-07-2013, 10:11 AM   #6
Pole position
My Ride: E46 330ci
Gotcha. Will be returning it asap. Thanks
Shut up and drive
Old 06-07-2013, 10:14 AM   #7
pcarney
My Ride: 2002 330ci
No Problem!
Old 06-07-2013, 10:16 AM   #8
cvx5832
My Ride: 325Ci, 325Cic, C300
SAF-XO is a specific product, not a standard. That said I've been using Redline in my diff for the last 60k miles and its been fine, granted I change it every 40k.
cvx5832 is offline   Reply With Quote
Old 06-07-2013, 10:18 AM   #9
Pole position
My Ride: E46 330ci
wait, so redline isnt saf-xo?
Shut up and drive
Old 06-07-2013, 10:26 AM   #10
pcarney
My Ride: 2002 330ci
Redline states that it meets BMW SAF-XO. Same with the others I listed. I use Redline also.
Old 06-07-2013, 11:40 AM   #11
hummer
My Ride: 2001 330CI
Much ado about nothing! The requirement is GL5 gear oil. So, any synthetic should be more than adequate! Don't think you'll find any better than Redline.
Old 06-07-2013, 01:04 PM   #12
Kubica
My Ride: 2003 325xi
Lol. It's fine.
Old 06-07-2013, 01:05 PM   #13
Pole position
My Ride: E46 330ci
Ordered redline. Was cheaper and even more fine lol
Shut up and drive
Old 06-07-2013, 02:18 PM   #14
Grande D
My Ride: E36 M3
Yes, Valvoline is fine. I'd run either the Valvoline you bought or Mobile One 75w90.
Redline will need to be drained more often, but is otherwise fine.
It will change your life!
Old 06-07-2013, 03:09 PM   #15
sprintman
My Ride: Ex 325CI owner
Redline 75W90
sprintman is offline   Reply With Quote
Old 06-07-2013, 03:14 PM   #16
WDE46
My Ride: 2004 330Ci OBM
That makes no sense...they make good products. This gear oil is totally fine.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
