Old 06-07-2013, 11:00 AM   #1
saace7
My Ride: is for chicks
Doing P/s fluid and reservoir
I am looking for a new reservoir and noticed on realOEM.com part #32411097164 has ended and replaced by #32416851217 but that part calls for CHF 11.S power steering fluid systems. Does this mean we do not put ATF in our car for the p/s anymore? do i use CHF 11.S fluids or can i get it and use ATF?
I have an 04 330i zhp
saace7 is offline   Reply With Quote
Old 06-07-2013, 11:28 AM   #2
nl318
My Ride: 318i 2000
Re: Doing P/s fluid and reservoir
The container is the same, it only comes with a CHF labeled cap. I used my old ATF cap with the new rubber ring from the CHF cap.
nl318 is offline   Reply With Quote
Old 06-07-2013, 11:30 AM   #3
WDE46
My Ride: 2004 330Ci OBM
No, continue to use Dexron III ATF. The reservoir has no influence whatsoever on what fluids are to be used. The steering rack and pump would dictate that. However, you can still get the old part number: 32411097164. The new one simply has a new label. I would get the old number so it still says ATF Only. I, myself, purchased the old number (brand ZF) from Pelican Parts, but ECSTuning also has it.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 06-07-2013, 11:30 AM   #4
cvx5832
My Ride: 325Ci, 325Cic, C300
The part seems to have been superseded in 03/11 so I think you're good with just ATF. I suspect that note is there for newer BMWs which use the same reservoir and CHF 11.S. Parts cross is here.
cvx5832 is offline   Reply With Quote
Old 06-07-2013, 11:44 AM   #5
saace7
Yea ZF is about 25 bucks cheaper too.
