Sponsored by The Tire Rack
Old 06-07-2013, 01:42 PM   #1
WHITESHOGUN325I
My Ride: 2001 325I Sedan 5spd
Need help with spacer and tire specs
I have a 2001 325I that ill be modifying the suspension and rim/tires on. The coilovers ill be using are ECS Tunings FK Streetline coilovers, the rims I will be using are Style 95 rims which are 19x9 (front) and 19x10 (rear). I really need your guys help when it comes to selecting the tire sizes for both front and rear, as well as selecting the correct spacer size to achieve the following stance:
So basically:
1) What size spacers for the front and back?
2) What tire sizes for the front and back?
Also I understand fender rolling and or pulling my play a role.
WHITESHOGUN325I is offline   Reply With Quote
Old 06-07-2013, 02:10 PM   #2
trj
My Ride: 325Ci
Search:
http://forum.e46fanatics.com/showthread.php?t=905777
The size of the spacers required to get the gap closed will depend on how much drop and how much fender pulling you are going to go with.
I am pretty sure you will rub on the rear arches with a drop, so spacers would only be required if you are doing extensive body work. The offsets on these wheels are pretty high and sedan doesnt have much of a room to play with for the rear tires.
Old 08-24-2013, 04:02 PM   #3
WHITESHOGUN325I
Accomplished!
