Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 07-18-2003, 11:10 AM   #1
daz
My Ride: 2003 Bmw Coupe 330ci
Send a message via AIM to daz
Look what Batman deliveried
Recieved Infinity SUB.... and Punch 300s amp to drive it. Goes in tomorrow..
Name:	disney 2003 054.jpg
daz is offline   Reply With Quote
Old 07-18-2003, 11:11 AM   #2
daz
Batman delivers
amp
Name:	disney 2003 051.jpg
Old 07-18-2003, 11:12 AM   #3
daz
more
more
Name:	disney 2003 050.jpg
Old 07-18-2003, 11:12 AM   #4
daz
more
amp
Name:	disney 2003 053.jpg
Old 07-18-2003, 11:15 AM   #5
daz
spec
spec
Name:	disney 2003 055.jpg
Old 07-18-2003, 11:26 AM   #6
daz
Anyone have this AMp
Also you may note this amp you do not need a high low converterif you are useing it as your main amp. It is built in... Sweet....
Old 07-18-2003, 12:36 PM   #7
daz
Anyone using infinity sub? with Rockford Fosgate Amps?
Old 07-18-2003, 01:24 PM   #8
razorghost
My Ride: 330CI
Hi....
Is that the Perfect 12.1?
If it is, I am getting the same thing too..
One question for you, my kicker amp has that built-in hi-low level inputs, so I don't need to get those hi-low converter right?
How do you connect the factory hi level to the amp? Do you need to cut or solder anything?
Will there be any improvement in SQ if I decided to get the hi-low inverter and use the low level with good interconnects instead of directly using the factory hi level to the amp?
Anyone knows?
razorghost is offline   Reply With Quote
Old 07-18-2003, 04:10 PM   #9
bbh03
My Ride: M5, X5, 911SC
I use the perfect 12", but not with FR amps - have an Infinity Kappa amp (non digital!)
BBH
bbh03 is offline   Reply With Quote
Old 07-18-2003, 09:03 PM   #10
daz
Originally posted by razorghost
Hi....
Anyone knows?
Just use the High input connector if your AMP comes with one. Just remove the HK AMP.. Cut the connector to the HK AMP.. Splice/connect to the Head unit out puts to the High input connector that came with the AMP.
Input Connection (or head unit output) pin #
Wire Color Description
37 Yellow/Red (+) Front left
30 Brown/Orange Front left ground
36 Yellow/Black (+) Rear left
29 Brown/Orange Rear left ground
9 Blue/Red (+) Front right
17 Brown/Orange Front right ground
8 Blue/Black (+) Rear right
16 Brown/Orange Rear right ground
See this link for details: http://www.projectbimmer.com/BmwWiring.htm
Old 07-19-2003, 10:23 AM   #11
daz
Just finished the install SUB and AMp are in... No Alternator noise.. Every thing is good.
One question what should I set the frequency range to on my LP-X-over...?
