///M3 Forum
Old 06-07-2013, 09:51 PM   #1
rama1200
My Ride: E46 M3 Vert 6MT
Need wheel bearing brand suggestions
Hi, all.
I think I have at least a bad rear bearing... I was wondering if you have any brand suggestions?
rama1200 is offline   Reply With Quote
Old 06-08-2013, 04:52 AM   #2
bernie21614
My Ride: 01 330i
I purchased the timken bearings from autozone a couple months ago they seemed like really good quality but only time will tell. Anyway I picked up the front pair for under $95 I believe, which is a really good buy, I don't know what they go for now as when i purchased them there was a special going on.
bernie21614 is offline   Reply With Quote
Old 06-10-2013, 08:22 AM   #3
rama1200
Thanks, bernie21614... did you get the hub too or just the bearing?
Old 06-10-2013, 08:53 AM   #4
rama1200
I forgot to ask...
Do you guys know if the bearings are pre-greased?
Old 06-10-2013, 01:17 PM   #5
bernie21614
My Ride: 01 330i
Re: Need wheel bearing brand suggestions
for the fronts you need to get the hub, that's the only way they sell them.
The rears you can get just the bearings
Old 06-10-2013, 01:18 PM   #6
bernie21614
My Ride: 01 330i
yes, the bearings are greased up already when you purchase them
Old 06-10-2013, 10:44 PM   #7
rama1200
Does this sound like failed bearings?
I'm just spining the hubs ... i did not feel any play/gaps when i wiggled the hubs....
Rear wheel, no brake pad or calipers, rotors on hubs, car jacked, in neutral, released ebrake
Old 06-11-2013, 10:23 PM   #8
rama1200
I'm really at a lost here.... I removed all the way to the rotor, leaving exposed the hub (hub still seating on spindle) I wiggled it, but did not see/feel the typical gap/play... It does not pop in or out when tugged or pushed... There is some some gap if i spin it forward or backward, when compared to the differential.
Tires look good. Pressure is good...
I still hear the sound, today i tried driving in zigzags and definitely more noise when weight is in left [turning to the right)
Old 06-13-2013, 04:36 PM   #9
bernie21614
My Ride: 01 330i
I can't watch the video through my phone, but if you removed the brake components and you still hear noise when rotating the wheel then switch out the bearings
Old 06-19-2013, 05:05 PM   #10
bernie21614
My Ride: 01 330i
Here is a review of different bearings;
http://forum.e46fanatics.com/showthread.php?t=800397
Old 06-19-2013, 08:06 PM   #11
rama1200
Yes, i saw that... That is why i decided for timken... Om is the best, but since money is short, i think it gives the best compromise between price and quAality...
