///M3 Forum
Old 06-08-2013, 08:10 PM   #1
VAMZ
My Ride: ///M3
Send a message via Yahoo to VAMZ
Sunroof making weird noises
Been fairly hot recently, sunroof making weird noises when put in tilt position. Have not tried to retract it all the way back (afraid if something is wrong that it will get stuck while in open position).
I know that the sunroofs have quite a lot of problems with e46 model. I'm hoping that its just dry and needs some good lithium lube. Im going to get a cloth, try to clean up the debris and then apply the lube.
Do you guys remove the sunroof glass to do this? (its about 6 torx screws) Not sure if i want to go through that much trouble - but if it helps I'll go ahead and do that. It's in tilt position currently.
VAMZ is offline   Reply With Quote
Old 06-11-2013, 01:34 PM   #2
MathewM3
My Ride: BMW M3 E46
What kind of noise is it making?
One common problem is the "FRAME SLIDING-LIFTING ROOF" part no 1 (54137134536, look at the parts diagram below) breaks. You need to lubricate inside of the frame where the cable that is driven by the motor is moving the sun roof.
http://realoem.com/bmw/diagrams/l/o/266.png
MathewM3 is offline   Reply With Quote
Old 07-06-2013, 09:36 PM   #3
VAMZ
My Ride: ///M3
Do you guys actually remove the sunroof glass to do the lubrication? Seems easier to do this, but dont want to remove if unnecessary. Looks easy to take off but im afraid adjusting it to be flush will be time consuming when putting it back on.
Old 07-08-2013, 10:34 AM   #4
hinds90
My Ride: E46
I need to do this also. Any particular grease to use.
hinds90 is offline   Reply With Quote
Old 07-25-2013, 10:47 PM   #5
VAMZ
My Ride: ///M3
i bought white lithium grease. still havnt done it yet though. are we suppose to actually remove the sunroof to apply it? putting sunroof back on properly seems like a pain according to some
