The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Old 06-10-2013, 08:44 PM   #21
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
I sense epicness in the making...
E46 Coupe is offline   Reply With Quote
Old 06-10-2013, 08:53 PM   #22
tks
My Ride: slower than yours
oh boy oh boy oh boy!'
WTB:: Natural Brown Sedan Full Interior
tks is offline   Reply With Quote
Old 06-10-2013, 09:11 PM   #23
samurai project
My Ride: E30, E36, E46
Everyone responses is very welcoming. I hope to not dissapoint!
Today we will be re-fitting transmission so we can check all intercooler pipe position.
We have also ordered new powerful clutch and 2-way LSD.
Updates in this evening.
Thank you again for your kindness.
samurai project is offline   Reply With Quote
Old 06-11-2013, 12:42 AM   #24
Barbaros
My Ride: 02 TIAG M5
Originally Posted by cak323i View Post
Tony, you would have to go there
I would love to!!!!
Barbaros is offline   Reply With Quote
Old 06-12-2013, 02:04 AM   #25
samurai project
Upgrade clutch fork.
Today we made strength for the BMW factory clutch fork. We think that it is quite weak from factory, so we made brace and welding it together. Now it is very strong!
More update to come today. We will be working late on the project.
Old 06-12-2013, 06:29 AM   #26
BDUB328I
My Ride: bmw 328i S54 sedan (
nice work, keep it up
BDUB328I is offline   Reply With Quote
Old 06-12-2013, 08:09 AM   #27
wanganstyle
My Ride: e36 M3 / E30 GTS1
tapatalk is awesome and posts double
Billet Original CNC LSD for 188K
http://www.wanganstyle.com/
S54B32 E36 M3 DTA S100 Sedan Street car full swap:
http://forums.bimmerforums.com/forum....php?t=1437471
E30 M20 2,7L Alpina + Euro E46 320D ZF 6 speed install
http://www.e30tech.com/forum/showthread.php?t=110010
wanganstyle is offline   Reply With Quote
Old 06-12-2013, 08:09 AM   #28
wanganstyle
BMW Differential center unit is different geometry for High (3,15->4,10++)
and LOW (3.07, 2.93, 2.79)
fFor the E46 non-m Most Japanese and european companies only make LSD for ratios 3,15->4,10
the 330 has a 2.93 final drive for manual cars -
For your adaptation of the older e36M s50b30 LSD unit you will need to billet retrofit the older LSD unit; you can use a spacer or change the bearing mounting surface and make original top cap for it.
http://forum.e46fanatics.com/showthread.php?p=14989087
Old 06-12-2013, 11:04 AM   #29
wshgrntd
My Ride: 2007 335i m-sport
I am keeping my eye on this one... I do have an automatic though...
wshgrntd is offline   Reply With Quote
Old 06-14-2013, 07:56 AM   #30
samurai project
Today this arrived in the mail:
So we test fitted it to check if everything is OK. It is not a clutch kit, it is something we specially ordered. It is a mix of various BMW models.
Before fitting transmission we cleaned it and painted it with this special Heat Paint.
Finished today now, but tomorrow we will check that everything is working with the clutch system. We will make stainless hose for clutch also.
Old 06-14-2013, 08:57 AM   #31
E46 Coupe
E46 Coupe's Avatar
BMW E46 330i Supercharger - Made in Japan
I love it! But because you said it came in the mail, I will extend my like to the Japanese postal system too lol
Old 06-14-2013, 09:11 PM   #32
samurai project
Our test driver is from England. He said word is mail, not post. Because post is British word.
We are very international organisation.
Old 06-14-2013, 09:55 PM   #33
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
looks great. always great to see people making their parts to make things work!
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 06-15-2013, 02:00 AM   #34
samurai project
I knew it. Our mechanic has too much time and too little work. Time for Japanese boss to strike revenge!
Old 06-21-2013, 06:34 AM   #35
samurai project
L.s.d.
Today we installed Cusco LSD into our D1 Street Legal machine...
Here are some photos to document the process. Maybe useful for infomation for people.
First we pressed new bearing onto LSD unit. We checked clearance perfectly, but we were unsure about height between differential shoulder and actual bearing. In end we used calliper to measure and were happy with result.
At first height was not perfect. But we adjusted bearing very slowly on press
Tightening bolts on final gear ring. We used loctite 270 and at first 100 NM, then turned all bolts more 30 degrees.
Lubricating bearings. D1 machine because, we tread very carefully with footwork parts.
Snap ring is very very stiff. We needed strong hands to insert this snap ring. We recommend to use Snap-on ratchet type snap ring plier. We didn't have so just used normal long nose plier.
Finished product!
For bedding in of L.S.D we will use Cusco own oil, but we have a special blend of L.S.D oil made specifically for drifting for our company by Japans only one-off oil specialists. This is very special blend. We will put infomation online when oil is ready for sell.
Also for BMW fans. We decided to use automatic car final gear ratio of 3.39:1 We think this might better suit our rival gear ratio. Almost all cars are Nissan Silvia 4:1, 4.4:1, 4.7:1 etc. But BMW 330i manual gear ratio are much different to Nissan.
For example.
BMW 2nd gear is 2.5
Nissan 2nd gear is 1.902
BMW 3rd gear is 1.66
Nissan 3rd gear is 1.308
For D1 Street Legal 2nd and 3rd gear is most important, so 3.39:1 is OK!
Old 06-21-2013, 08:21 AM   #36
E46 Coupe
E46 Coupe's Avatar
Awesome update! Nicely explained.
Such good work so far, what are you planning next?
Old 06-21-2013, 10:31 AM   #37
samurai project
Tomorrow will be some more engine work. We have still to make hoses for oil cooler and test fit some intercooler piping. Hopefully tomorrow I will make new update here
Old 06-21-2013, 02:24 PM   #38
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
Nice project I love all the parts you guys are creating for this.
Drew@Swift Motorworks is offline   Reply With Quote
Old 06-21-2013, 03:37 PM   #39
patdeezy
My Ride: a grey e46 sedan
Send a message via AIM to patdeezy
damn awesome!
-m330-
EUROPROJEKTZ
REALIE CLUB 2007 - I'M KEEPIN IT REAL!
SPONSORED BY
|SGC Godfather|
KOBE in 2012
patdeezy is offline   Reply With Quote
Old 06-23-2013, 06:45 AM   #40
samurai project
Today we made some more progress.
We made E36 M3 oil filter housing fit to M54 engine, and welded on some fitting for sensors. We did this so we can use oil cooler.
Then we made some aluminium hose for oil cooler
Then we fitted big capacity oil cooler to car.
Here is a photo of fitting.
Here are some close up of bracket and oil fitting ready for hose
Also we finished fitting all footwork. Propellor shaft, drive shaft and LSD all now fitted! Today was a busy day
