Old 06-10-2013, 01:04 PM   #1
andynb
My Ride: e46 m3
Exclamation HPF jumper box and harness needed
I think my jumper box and the small two harness' have finally had it, so if anyone have one then would sell please let me know!
Or if anyone local to me have one I can try out for day to verifiy the problem!
andynb is offline   Reply With Quote
Old 06-10-2013, 07:00 PM   #2
InDiGlOM3
My Ride: HPF M3 stg 2.5
Jumpr box is prolly fine. Just the Shitty pins in short harness. What I did was slightly bent all the pins in the jumper box then slowly worked connectors on. Worked great.
Sent from my EVO using Bimmer App
Old 06-10-2013, 07:16 PM   #3
andynb
My Ride: e46 m3
Its past that at this point. I've repaired the box and harness twice before, but the problem keeps coming back after a while...
Old 06-11-2013, 08:53 PM   #4
andynb
My Ride: e46 m3
bump...anyone?
Old 06-12-2013, 04:27 AM   #5
Dreikraft
My Ride: slow m3
What problem? Afr go lean and car stall?
Dreikraft is offline   Reply With Quote
Old 06-12-2013, 12:12 PM   #6
andynb
My Ride: e46 m3
No same issue I was having before, running lean but only between 10 and 4 inches of vacuum...
Old 06-12-2013, 09:36 PM   #7
Dreikraft
My Ride: slow m3
check MAP is in spec? we need replacement MAP sensors now that hpf is gone.
Old 06-12-2013, 09:38 PM   #8
andynb
My Ride: e46 m3
Has a brand new map in it. I replaced that when i first started having the problem. And the map is just a aem standard part number
Old 06-13-2013, 09:16 AM   #9
InDiGlOM3
Re: HPF jumper box and harness needed
Im working on hard wiring the short harness to the jumper box this weekend or next. this should solve all your problems.
Sent from my EVO using BimmerApp mobile app
Old 06-13-2013, 10:01 AM   #10
Commanderwiggin
My Ride: 900rwhp Turbo M3
I know when I had replaced my Map sensor once they sent a 5 bar instead of the 3.5 bar sensor that was originally in the car...good thing I noticed as it would've changed the feedback to the EMS and changed the whole tune.
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 06-13-2013, 01:48 PM   #11
andynb
My Ride: e46 m3
I hard wired the small plug on mine a while ago and that fixed the issue for months.... but then it came back.
But I got a new box and harness last night and its running perfectly!
Old 06-13-2013, 02:39 PM   #12
InDiGlOM3
Awesome. Which one did you hard wire and how?
Old 06-13-2013, 04:29 PM   #13
andynb
My Ride: e46 m3
I did the smaller of the two white plugs, as that was the one giving me the problems. I just unsoldered the female connector off the board and soldered the wires straight to it. It was a pain and took forever...
Old 06-13-2013, 06:38 PM   #14
InDiGlOM3
I don't see how that caused a problem after that was done....unless something was slightly damaged inside the jumper box.
Old 06-13-2013, 07:12 PM   #15
andynb
My Ride: e46 m3
Yeah i'm not sure on that. It was fine for months after I hardwired it, but then it came back. Not nearly as bad though. Maybe having that bad connection and all the added resistance that goes with that caused a problem inside the board?
Old 06-14-2013, 09:14 PM   #16
thesull
My Ride: e46
What is the issue you are having? My car is acting up lately. I have 30k on the build and it just recently started acting up.
thesull is offline   Reply With Quote
Old 06-15-2013, 08:24 PM   #17
andynb
My Ride: e46 m3
read post #6
Old 05-15-2014, 12:46 AM   #18
Jose ferrer
My Ride: Bmw e46 m3 turbo
PLEASE help me, urgent
Good day to all
Urgent need HorsepowerFreaks HPF M3 Turbo Jumper Box, anyone can sell me one, mine was damaged.
Jose ferrer is offline   Reply With Quote
Old 07-07-2014, 09:18 AM   #19
Jose ferrer
Horsepowerfreaks parts for sell
Hi,
I sell my car without turbo kit,
I'm only selling these pieces:
1) complete harness
2) jumper box tps upgrade horsepowerfreaks
3) aem horsepowerfreaks
4) Bavarian Autosport High Performance Ignition Coil
All for 1,950.00 or make a offer
Old 07-07-2014, 10:03 AM   #20
Commanderwiggin
I also have HPF parts for sale!
Harness, ECU and Jumper box all verified in working condition - 1250 shipped in the USA!
