Old 06-10-2013, 03:35 PM   #1
erich330ci
My Ride: 2004 330ci
Replacing Valve Cover
I cracked my existing valve cover while replacing gasket about 750 miles ago and I'm now replacing it due to minor leakage. Should I install a new VCG or can I re-use the existing one that has only a few miles on it?
Thanks.
Eric H.
erich330ci is offline   Reply With Quote
Old 06-10-2013, 03:44 PM   #2
TheDeadner
My Ride: 00 323i
You should replace your vcg anytime you remove your valve cover.
TheDeadner is offline   Reply With Quote
Old 06-10-2013, 04:06 PM   #3
WDE46
My Ride: '13 128i, '04 330Ci
You can reuse it to be honest. It's not a perishable gasket, like your head gasket or the VANOS gasket. I would be wary of the RTV areas though. Make sure those are cleaned off well and not damaged. You can DEFINITELY reuse the grommets assuming you already replaced those.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 06-10-2013, 04:14 PM   #4
Stinger9
My Ride: '04 330Ci
Many with low miles have re-used and report no leaks after that.
Old 06-10-2013, 04:47 PM   #5
rudycoop
My Ride: 3 pedal 330i
Yeah re-use it!
Just a Jersey guy lost in NorCal
rudycoop is offline   Reply With Quote
Old 06-10-2013, 05:00 PM   #6
fiveightandten
My Ride: '03 330ci / '98 M3
As good as a new one after it's been pressed already? No.
Will it leak if reused and installed properly? Probably not.
Go for it.
-Nick
fiveightandten is offline   Reply With Quote
Old 06-10-2013, 05:05 PM   #7
pawelgawel
My Ride: 330CI
its rubber, and its almost new. reuse it, no need for a new one
pawelgawel is offline   Reply With Quote
Old 06-10-2013, 06:30 PM   #8
erich330ci
My Ride: 2004 330ci
5-to-1 in favor of re-using.
Eric H.
Old 06-10-2013, 06:51 PM   #9
TheDeadner
My Ride: 00 323i
Fair enough but remember who voted for replacement when you get it all done and find out in two weeks that it's leaking and you have to pull it apart again because you didn't want to spend $20 to replace it.
Just kidding man, go for it. I've never tried re-using one, I've just been told they distort once tightened down. If other people say they've done it, give it a shot.
Old 06-10-2013, 07:26 PM   #10
rudycoop
Yeah if he does a bad job of cleaning the surface and re-applying the rtv. I literally had mine off 4 times and it holds fine. Prepping the surface is key OP.
Old 06-10-2013, 07:26 PM   #11
erich330ci
My Ride: 2004 330ci
I actually almost didn't even post the question, as I thought everyone would say replace it and give me a bunch of $&/! for asking. Funny.
Eric H.
Old 06-10-2013, 07:40 PM   #12
Stinger9
My Ride: '04 330Ci
OH, we haven't even starting doing that next!
Old 06-10-2013, 08:00 PM   #13
tks
My Ride: slower than yours
Can we turn this into a for sale thread?
I assume your interior is semi-mint and you will be starting your part out in a week?
I am looking for the driver's side kick panel when you get the chance, thanks!
WTB:: Natural Brown Sedan Full Interior
tks is offline   Reply With Quote
Old 06-10-2013, 08:05 PM   #14
orb
orb's Avatar
My Ride: 325Ci
First of all, to all those saying it's only $20 to replace, you're wrong. Even the crap Victor Reinz VCG isn't that cheap. Second, you can reuse it assuming it's fairly new. The only reason you'd replace every time removing the VC is if you were using a paper or cork gasket, which this obviously isn't.
orb is online now   Reply With Quote
Old 06-11-2013, 10:22 AM   #15
erich330ci
My Ride: 2004 330ci
I'm not selling anything.
Sent from my SCH-I500 using Bimmer App
Eric H.
Old 06-11-2013, 10:34 AM   #16
Stinger9
My Ride: '04 330Ci
But you are taking the bait
Old 06-11-2013, 11:23 AM   #17
rudycoop
LOL I think he was joking...
Old 06-11-2013, 11:25 AM   #18
erich330ci
My Ride: 2004 330ci
Got me!
Eric H.
Old 06-15-2013, 08:39 PM   #19
CyndyB
My Ride: 2004 325CI
Anybody know a good link for OEM parts. I need a valve cover, as my wonderful husband cracked my while replacing gasket as well. Go figure SMH.
CyndyB is offline   Reply With Quote
Old 06-15-2013, 08:51 PM   #20
wildirish317
My Ride: 2004 325Ci vert
I use www.thebmwpartstore.com for OEM parts. They are reasonable.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
gasket, oem parts, valve cover, vcg
