Old 06-15-2013, 11:10 PM   #21
Stinger9
My Ride: '04 330Ci
Originally Posted by CyndyB View Post
Anybody know a good link for OEM parts.
No one has the best price on every part.
www.furiousmethod.com
Old 06-16-2013, 02:54 AM   #22
captkhaos
My Ride: '02 330Ci
Is the Victor Reinz gasket really as bad as I've heard? I've got a brand new VR gasket waiting to be installed but will order a different brand if it sucks that bad.
captkhaos is offline   Reply With Quote
Old 06-16-2013, 09:11 AM   #23
miguelpr0
My Ride: 325i
OP are u getting p0171 and p0174 lean codes?
miguelpr0 is offline   Reply With Quote
Old 06-16-2013, 10:44 AM   #24
CyndyB
My Ride: 2004 325CI
Thanks, Stinger9
CyndyB is offline   Reply With Quote
Old 06-16-2013, 10:50 AM   #25
CyndyB
My Ride: 2004 325CI
Thanks Wildirish317!
Old 06-16-2013, 10:56 AM   #26
Stinger9
My Ride: '04 330Ci
You be the judge. Many here have installed the dreaded VR and within 5-8000 miles their engines start to leak oil at the gasket. Is that enough life from a gasket until you have to replace it again? (with all the concomitant labor)
An oil leak on our engines is not a casual thing. For example the small leak on my engine was dripping down on my lower rad hose. Hot oil on rubber ate into my hose and necessitated replacement to avoid failure of that eventually. The rad hose has already stared to bubble and crack under the dried oil.
What will you do?
Old 06-16-2013, 08:48 PM   #27
erich330ci
My Ride: 2004 330ci
Replacing Valve Cover
oembimmerparts.com
Can't beat 'em for price and speedy delivery.
Eric H.
erich330ci is offline   Reply With Quote
Old 06-16-2013, 08:59 PM   #28
erich330ci
My Ride: 2004 330ci
I had been getting those codes prior to and after replacing VCG, but I replaced the fuel filter and they disappeared.
Now I'm getting "cylinder 1 misfire" (or something to this effect). The crack is in the vicinity of cylinder 1 (which I'm assuming is the forward-most cylinder), so I'm wondering if there any be a small amount of oil seeping into the spark plug/coil area. The engine stutters a bit for a few seconds after starting it cold, then it smooths out. Will see what it looks like when I install the new valve cover. I suppose it could be a bad plug, all six of which I replaced e VCG.
Eric H.
Old 06-16-2013, 10:21 PM   #29
WDE46
My Ride: '13 128i, '04 330Ci
I had a VR on mine that I think the PO had put in. It leaked. I've never heard anything good about the VR VCG.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
gasket, oem parts, valve cover, vcg
