Old 06-12-2013, 09:24 AM   #1
rawbar
My Ride: 2003.5 M3 vert
dead climate control
I searched the forum and only found reference to checking fuse 28, so before I buy a new climate control, I wanted to make sure there is nothing else I can check.
I just purchased a 2003.5 E46 a week ago, and two days ago, the climate control died. By died I mean no lights, the controls do nothing. Fuse #28 tests fine.
Seems a used unit can be picked up on ebay relatively inexpensively and I watched youtube videos on how to replace the unit, looks pretty simple. I did read though on one forum that you have to 'take a new unit to BMW to be programmed'. Huh?? Seems like this would be a case of just plug in the new one.
So before I order a new unit, is there anything else I can check, and can someone clarify this programming requirement?
Thanks!
rawbar is offline   Reply With Quote
Old 06-12-2013, 09:51 AM   #2
esberelias
My Ride: '03 325i
this happened to me last week!
Take it out... unplug it and plug it back in... worked for me. Just a bad connection to the unit it's self (even if the connections look tight.. take them out and re seat them... if not, than its a dead unit and you'll have to order a new one.. I heard they do fail too)
Check out my ride
esberelias is offline   Reply With Quote
Old 06-12-2013, 09:57 AM   #3
rawbar
Thanks, I'll give that a try, looks easy enough that I can step out for lunch from work and attempt it. If I do have to order another one, is there "reprogramming" required, or is it just plug and play?
Old 06-12-2013, 10:00 AM   #4
lmr2wil
My Ride: '00 328Ci
I would check that you have power at the plug. Assuming you do and you decide to get a new - or used - unit, you may need to code it to regain the same options/behaviors of your current unit. BMW Scanner can do this for under thirty dollars.
Luke
lmr2wil is offline   Reply With Quote
Old 06-12-2013, 10:11 AM   #5
rawbar
Thanks Luke, what sort of options/behaviors do you mean? I was thinking of picking up a cable and NCS Expert. Can it be done from that? I guess I'm not really sure what sort of options we're talking about here.
Old 06-12-2013, 10:44 AM   #6
lmr2wil
My Ride: '00 328Ci
See http://www.bmwcarx.com/web/Documento...lClimatico.pdf for too much info on the system. I believe page twelve covers your question.
Luke
Old 06-12-2013, 10:46 AM   #7
lmr2wil
My Ride: '00 328Ci
Also yes NCS expert should do this.
Old 06-15-2013, 07:03 PM   #8
rawbar
It's fixed. Removed the unit, unplugged it, plugged it back in and it now works. Strange.
Old 06-15-2013, 07:10 PM   #9
Foxtrot_Uniform
My Ride: 325Xi
Check into the Final Stage Resistor too...
Foxtrot_Uniform is offline   Reply With Quote
Old 06-15-2013, 07:20 PM   #10
effay
My Ride: 323Ci
Yea I would assume final stage resistor if fuse is okay
effay is offline   Reply With Quote
Old 06-15-2013, 08:10 PM   #11
scarede46er
My Ride: 2001 BMW 325i ZSP
No, the FSU will not kill the display. It only controls the motor.
