Old 06-12-2013, 06:43 PM   #1
trentcdrums
My Ride: BMW 323i Sedan
Exhaust fumes in cabin - headers
I know that smelling exhaust after headers install is normal. So how long will I have it? Will it harm me? Never could find these answers..
Old 06-12-2013, 07:25 PM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
bump for you...I don't want you to die before your time.
Usually, conventional wisdom is smelling the exhaust is not a good thing, and if a mechanic told me it was after a header install, I'd look at him funny, wondering how the leak heals itself. Will wait on experts for that info.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 06-12-2013, 07:29 PM   #3
trentcdrums
+1
Old 06-12-2013, 07:36 PM   #4
Guest021715
Account closed.
Headers will always produce an exhaust smell, to some degree. Anyone telling you otherwise is in denial.
Check to make sure you don't have a leak between headers and exhaust.
Did you use new OE gaskets? Did you maintain the metal bracket between the pipes?
Go drive up next to a wall to hear your leaks better.
Old 06-12-2013, 07:43 PM   #5
trentcdrums
Had the shops tighten my flange bolts again today. Still a little bit smelling. It scares me though.
Old 06-12-2013, 08:54 PM   #6
BobbyC
My Ride: 2000 328I
I remember your post. You sprayed a hell of a lot penetrant to get the header to exhaust off. Might be some of it burning off. Don't forget, dirty hands touching the headers. Takes time to burn off.
BobbyC is offline   Reply With Quote
Old 06-12-2013, 09:13 PM   #7
TerraPhantm
My Ride: M3 & ZHP
They shouldn't... The only time I got a smell inside my cabin is when I drippe some oil on them
Old 06-12-2013, 09:14 PM   #8
HiHoBrian
My Ride: 05 M3
Re: Exhaust fumes in cabin - headers
Also by installing headers in place of your OEM catted manifolds you are now running without a major emmisions control component. The sulfers and NoX"s and what ever fumes in your exhaust are no longer being burnt and cleaned up. So you will have a semi potent nostril buring exhaust fume smell. You will notice this more often at drive thru windows, and in cooler months when the fumes linger. It will be embarising especially when girls tell you your car smell like crap.
You can live with it, purchase aftermarket high flow cats or OEM euro cats to solve this problem and likely correct the service engine light issue that you probably also have now.
HiHoBrian is offline   Reply With Quote
Old 06-12-2013, 09:28 PM   #9
TerraPhantm
My Ride: M3 & ZHP
Most euro models also have their cats in the headers.
Old 06-12-2013, 09:41 PM   #10
trentcdrums
If I just buy a cat and install it after the headers will that help?
Old 06-12-2013, 09:43 PM   #11
HiHoBrian
My Ride: 05 M3
I think you may have corrected me on this before. Sometimes I reply before realizing that I'm not in the M forum. (Using the App) Thanks.
Old 06-12-2013, 09:54 PM   #12
trentcdrums
Other options?
Old 06-12-2013, 10:25 PM   #13
trentcdrums
I had an hour drive home and even with the windows opened I felt really weird.. The fumes just aren't going. I cannot keep driving like this. Especially if it rains.
Old 06-13-2013, 08:52 AM   #14
BeMyWhip
My Ride: 01 BMW 330ci
Wh as you're smelling is raw uncleaned exhaust. The actual toxins in exhaust are ordorless, clorless, and dangerous.
you will not enjoy a fumeless ride anymore unless u use ur cats.
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 06-13-2013, 10:19 AM   #15
trentcdrums
Can someone answer this! Can I delete a resonator and replace with a cat?
Old 06-13-2013, 01:56 PM   #16
HiHoBrian
My Ride: 05 M3
Yes you can. Just check out the amount of space you have for fitment before you order a cat. The closer to the headers the better.
Old 06-13-2013, 02:01 PM   #17
HiHoBrian
My Ride: 05 M3
If you are thinking there are fumes getting in the cabin even with windows closed you might still have leaks under the hood that are being drawn through the HVAC system. Something You can look into more.
Old 06-13-2013, 03:02 PM   #18
trentcdrums
But will my smell issue leave?
Old 06-13-2013, 03:11 PM   #19
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
If you're planning on putting a cat in, why did you put headers on your car in the first place? You're defeating the whole purpose. Might as well just get your stock ones put back on.
Also, the smell is normal and not good for you. By deleting the cats (aftermarket headers) you've deleted the only thing that reduces emissions. Your exhaust is now raw and Uncleaned.
Old 06-13-2013, 04:42 PM   #20
Kubica
My Ride: 2003 325xi
Ummm...you car is illegal until you add a cat.
Ummm...high flow cats.
