Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 06-12-2013, 07:23 PM   #1
BreakfastBurrito
My Ride: ///GT3 RSR
tiling pattern help
I'm getting ready to tile my bathroom. I laid out the 12x12 tiles to see how they would fit and my problem is I have about a 2" in gap between the tub skirt edge and the full tile. I suppose I could tile the 2" gap but I feel that would look weird against the tub or against the wall. I thought about moving the tub but then it would be too far from the wall.
So I'm thinking of shifting everything over about 6" so I have half a tile against my east wall and approx. 8" against the tub skirt. Does this sound correct? halp.
BreakfastBurrito is offline   Reply With Quote
Old 06-12-2013, 07:35 PM   #2
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Send a message via AIM to JonJon
Yes, that is how you tile. Split the difference between walls
I typically start a full tile at the door threshold since you see that first.
But if the other walls come up short, adjust
Sometimes you get lucky and can hide the short sides under a vanity or something
Lay it all out, make your cuts, lay it out again to be sure... Number the backs of the tile.... then get started
JonJon is offline   Reply With Quote
Old 06-13-2013, 10:29 PM   #3
BreakfastBurrito
My Ride: ///GT3 RSR
I'm really tempted to move the tub over and add wall on top of the existing wall. My gf was saying to add a piece of strip/tile in that gap, that it wouldn't look bad. (I know the hardibacker is at an angle, that was my fault.)
Old 06-13-2013, 10:52 PM   #4
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
You could move your tub but then your plumbing will be off...
It's only a 1" gap and your grout lines look like 1/4"?
You can hide 3/4" by shifting the tiles to the tub and getting a thicker base molding on the opposite wall.... Add quarter round molding on top of it...
Thicker grout lines?
Thicker base molding?
Old 06-13-2013, 11:06 PM   #5
K_is_Like
My Ride: black e46 coupe
In the industry we do a thing called "spacing" the tiles a little further than the spacer but not big enough to be noticed. Start with full pieces at the door and if the space left is 3/4 and above, just cut a piece of tile and use it. Try to keep cuts by the least visible walls/areas.
K_is_Like is offline   Reply With Quote
Old 06-13-2013, 11:07 PM   #6
K_is_Like
Also as jonjon said, moldings or bases help a lot!
Old 06-13-2013, 11:14 PM   #7
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Yea, he doesn't have much to make up but 1/4" is already kinda thick.
Definitely use sanded grout to minimize cracking and don't grout at the tub...
Use color matched caulk
Moldings are great for hiding things with finish work
Old 06-14-2013, 02:28 AM   #8
K_is_Like
Yes definitiley sanded grout. Also, I'd use 1/8" spacers. It'll look much better and cleaner but I guess that's preference. Another plus would be minimizing the chance for grout cracking even further. Try and color match the grout or something close to. I agree with the silicone by the tub idea as well. Too much grout will crack without a doubt. Good luck and if you have any other questions feel free to ask.
Old 06-14-2013, 08:11 AM   #9
BreakfastBurrito
My Ride: ///GT3 RSR
tiling pattern help
Yea the 1/4 is kinda spaced out, think I'm going to turn the spacers on their sides. I've been reading about base molding and it looks like I can make up more than 1in with a baseboard with a shoe. You guys definitely did help, thanks.
Old 06-18-2013, 11:44 AM   #10
BreakfastBurrito
My Ride: ///GT3 RSR
Tiling came out pretty good for my first time. I washed it a few times and i'll buff it out today. I can install my toilet now, caulk everything and start installing my walls.
(Everything_went_better_than_expected.jpg)
The mess after I tore everything out.
Old 06-18-2013, 09:04 PM   #11
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Put the toilet in last. Otherwise it'll just get in the way
