///M3 Forum
Old 06-13-2013, 09:42 AM   #1
KyungMin
My Ride: 2002 M3 Cabrio
Loud clicking/squealing noise when driving..
I have a 2002 m3 and I get a clicking noise when I drive.. Sometimes will turning into a squeal/shrieking noise.. Tried to pull e brake as this happened and no difference in noise.. The click is often but the shriek happens every so often.. Clueless on what it is.. We took the wheels off and looked under the car.. Looked fine.. Also bled the brakes... The noise gets faster if im going faster.. kinda sounds like a rock is stuck in my caliper but cant find anything.. Noise remains even under braking.. Any ideas?
1999 Honda Prelude
2002 BMW M3 vert
KyungMin is offline   Reply With Quote
Old 06-13-2013, 11:44 AM   #2
MathewM3
My Ride: BMW M3 E46
Have you checked the subframe?
MathewM3 is offline   Reply With Quote
Old 06-13-2013, 11:46 AM   #3
KyungMin
Looked down there and didn't see any cracks.. And I have a cabrio.. Also the clicking isn't that loud. More like tapping a can with a screw driver..
1999 Honda Prelude
2002 BMW M3 vert
Old 06-13-2013, 12:10 PM   #4
MathewM3
My Ride: BMW M3 E46
Hard to say what it could be, good luck.
Old 06-13-2013, 12:46 PM   #5
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
My guess is that it's your axles.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 06-13-2013, 12:56 PM   #6
KyungMin
Would my axle screech like that tho? Wouldn't it me more of a grind?
1999 Honda Prelude
2002 BMW M3 vert
Old 06-13-2013, 12:59 PM   #7
VMRWheels
VMRWheels's Avatar
One of my axles on my car has a tiny hole in the CV boot and it was slowly leaking grease out. It would squeal/squeak after being driven on for more than about 15 minutes or so. I would just start there. You say that it's rotational, and the clicking symptom is synonymous with axles.
Old 06-13-2013, 01:20 PM   #8
KyungMin
Is there a way to test for bad axles?
1999 Honda Prelude
2002 BMW M3 vert
Old 06-13-2013, 01:30 PM   #9
VMRWheels
VMRWheels's Avatar
Take a look back there and see if your CV boot is torn. I'm sure you would have noticed an excessive amount of grease everywhere, but yours might not be leaking that much. It should be black or even slightly green.
Old 06-13-2013, 04:03 PM   #10
KyungMin
Ok cool! Thanks..
I don't know if this is a good idea but my friend told me to take it to les schwab cuz they will look at it for free...
1999 Honda Prelude
2002 BMW M3 vert
Old 06-18-2013, 11:21 AM   #11
Niicee
My Ride: E60 M5
Send a message via AIM to Niicee
Rear Shock Mounts? Noise was light then got much louder, it was so annoying. Replaced them with RE mounts and noise was gone.
Niicee is offline   Reply With Quote
Old 06-18-2013, 06:45 PM   #12
karl hungus
My Ride: 2004 M3
bad wheel bearing?
2004 Silver Grey M3
karl hungus is offline   Reply With Quote
