Old 06-14-2013, 12:59 AM   #1
tmr931
My Ride: 330ci
p0173 code
I have a p0173 on a 2000 323ci. what are some possible causes?
I believe this is a rich condition. from doing a search, i am thinking its a bad 02 sensor. Can anyone confirm that? Does this car have 2 o2 sensors?
tmr931 is offline   Reply With Quote
Old 06-14-2013, 02:26 AM   #2
dznuts007
My Ride: 2001 325i Sedan
http://www.obd-codes.com/p0173
This might help. Mentions a few possiblities such as:
Vacuum leaks
Possible bad O2 sensors
Dirty MAF
Bad CCV or hoses - This guy solved his P0173 by changing out the CCV hose (http://www.e46fanatics.com/forum/sho...d.php?t=799653)
Other stuff
Easy stuff to start off with is to take out your boots and carefully examine them for rips, especially around the ribbed areas (sometimes hard to see if you don't take them out). While you have them out, clean out your ICV and Throttle body, or you'll have to take out the boots again if you do it at a later time.
Clean the MAF with CRC MAF cleaner (don't use brake cleaning fluid or throttle body cleaning fluid like some people do. Can potentially mess up your MAF)
Check your DISA gasket and replace the gasket with an oring (was it MJLavelle that sells it for like $3?)
Your car should have 4 O2 sensors. 2 pre-cat and 2 post-cat sensors. What year is your car and how many miles? Depending on that might want to change out your O2 sensors anyways. (autohausaz.com, bmaautoparts.com and other websites have some pretty good pricing on them)
Look into checking your fuel pressure at the Schrader valve on the fuel rail (Autozone rents out the fuel pressure tester for free) and possibly replace your fuel filter
Oh, and remember to plug your MAF back in after you take out your boots. I seem to have a problem forgetting to reconnect it every time after working on the car and always get the SES light and always facepalming...
These are things that would be good for maintenance anyways. Have fun!
dznuts007 is offline   Reply With Quote
Old 06-14-2013, 07:09 AM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
http://forum.e46fanatics.com/showthr...6&highlight=50
http://forum.e46fanatics.com/showthread.php?t=929501
Old 06-14-2013, 07:24 AM   #4
bostonsthename
My Ride: 2003 Jet Black 330xi
I had this and my DISA was broken
bostonsthename is offline   Reply With Quote
Old 06-14-2013, 10:38 AM   #5
tmr931
My Ride: 330ci
good info, thanks guys
my understanding though is that if an intake boot is torn, it would cause a lean condition, not rich? is that correct?
Old 06-15-2013, 12:52 PM   #6
jfoj
Re: p0173 code
Forget what the code states, BMW/Bentley had the codes mixed up and even had the same code listed as both rich & lean. Most cars never run rich, almost impossible with fuel injection or very rare.
Likely you have either a crankcase or intake air leak somewhere.
