Old 06-15-2013, 09:17 PM   #21
wildirish317
My Ride: 2004 325Ci vert
Your Dad is an artist. No problem with that, but he's not a mechanic. First get a code reader, such as PASoft, it will help you figure out exactly what's wrong. Second, get rid of the CAI, it's not helping. Go back to stock. BMW produced a performance car, no need for performance add-ons. If you want more hp, do an engine swap for an S54 or a Chevy LSx.
Don't replace the O2 sensors just because you get an O2 sensor code. If you clear the code, and it keeps coming back imediatly, then you can replace them. I had an issue that threw O2 codes, but it turned out to be something else.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 06-15-2013, 09:31 PM   #22
diM3tri
My Ride: 330ci + stg2 Scoobie
The fact that I'm getting such poor gas mileage and having the code kinda makes me skeptical. I think I'm gonna do plugs first tomorrow then see if the SES goes away. Ill put the stock air filter back on and see what happens
Current Cars:
'99 Big Turbo B5 A4 (the red one) ^^^
'13 GLI
'91 Ford F150 v8 5spd
Previous Cars:
'05 stg 2 scoobie wagon
'82 VW rabbit vert
'01 330ci
'84 633csi
diM3tri is offline   Reply With Quote
Old 06-15-2013, 11:38 PM   #23
Tbone8ty
My Ride: 2003 330i
CAI always throws CELs
Tbone8ty is offline   Reply With Quote
Old 06-15-2013, 11:40 PM   #24
diM3tri
Surprisingly MAF wasn't a code I was getting even though its completely removed. I just got o2 sensors and some a/c circuit board thing. Plugs I'm doing just for fun. Haha
Current Cars:
'13 GLI
Previous Cars:
'82 VW rabbit vert
'01 330ci
'84 633csi
Old 06-16-2013, 01:10 AM   #25
NumbaOneNewb
My Ride: 2003 330CI Silver
CAI dont always throw error. I made mine going off a DIY somewhere on this forum. piped tubing from maf all the way down by left fog light. no issues for a year now.
im really surprised you arent getting a light for maf. thats so odd. now if you dont have maf on, them how does your system run efficiently without knowing how much air is entering? I know that when maf is disabled, the dme runs off preset mappings, but that should severely impact mpgs and performance. the dme can no longer make adjustments to the car seeing as it is like being blind.
now Im also suspecting now that maybe its related to your o2s error. I always thought the pre cat o2s measure how well the engine is burning up its mixture, informing the dme so that it could make adjustments. if the o2s are working but try and report that the car isnt being efficient, all its doing is reporting to deaf ears.
when my maf started acting up, it didn't throw a maf code either. it told me my o2s were shot, but at that time I was having other issues as well butt yeah, I never got maf errors
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 06-16-2013, 01:15 AM   #26
diM3tri
I'll put my new plugs in tomorrow and replace the MAF to see what happens. I haven't noticed any change in performance or mileage with the MAF on or off. Except a super rough idle at start with the maf on
Current Cars:
'13 GLI
Previous Cars:
'82 VW rabbit vert
'01 330ci
'84 633csi
Old 06-16-2013, 01:22 AM   #27
NumbaOneNewb
aside from the rough idle, see if that o2 error shows its ugly face. if not blame the maf. then with a new maf, perhaps you can see the benefits of the maf
Old 06-16-2013, 01:27 AM   #28
diM3tri
Maybe my MAF was just bad
Current Cars:
'13 GLI
Previous Cars:
'82 VW rabbit vert
'01 330ci
'84 633csi
Old 06-16-2013, 05:52 AM   #29
jfoj
My Ride: 330CiC, M5, X5, E93
You need to actually post the DTC/CEL codes you are reading along with any Freeze Frame data if the tool you are using supports Freeze Frame data, not some general mention of a sensor mentioned in the DTC. Just because a sensor is mentioned in the DTC does not mean the sensor is bad or faulty. More often than not the sensors are not actually the problem, buy even seasoned mechanics knee jerk and jump on a sensor replacement party.
As for your mileage issue and cold start issue, the very first thing you should do is confirm your engine coolant temperature is correct. You cannot do this with the dash temp gauge, you need use the Hidden OBC Menu and/or a scan tool that reads real time data.
As for scan tools and software, read this - http://forum.e46fanatics.com/showthread.php?t=967204
Also suggest you read the 1st & 3rd links below in my signature.
