Old 06-15-2013, 08:21 AM   #1
Mugidado
My Ride: E46
Morning Misfires
Hi Guys,
I am facing problems of misfires with my e46 at every morning start or when the engine is too cold, when l switch off immediately and restart the engine again the misfire goes away until next morning. The SES light stays on.
Kindly suggest solutions as usual. Thanks
Mugidado is offline   Reply With Quote
Old 06-15-2013, 08:40 AM   #2
lovemy330ci
My Ride: 03 M3, VF570 StgII
get new ignition coils, first find out which clinders are misfiring
lovemy330ci is offline   Reply With Quote
Old 06-15-2013, 12:13 PM   #3
Mugidado
My Ride: E46
The misfiring cylinder is mainly no.3 and some times 3&5 together(the engine power stalls a little bit).
Old 06-15-2013, 12:29 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
Its not likely an ignition coil problem.
What you are having is cold start with misfire and fuel cut off. Turning the engine off and back on will clear the misfire with fuel cut off, however, you still may have a slight misfire.
You likely have a vacuum leak or leaks.
I would start with inspecting the DISA and replace the DISA O-ring.
You can read all about vacuum leaks in this thread here, likely you can find you answer or at least rule out issues one by one - http://forum.e46fanatics.com/showthread.php?t=897616
