Old 06-15-2013, 12:16 PM   #1
tlester
My Ride: 2001 330i
Jack & Jack Stands... How Tall?
Hi Guys -
I've got to replace my clutch and I my old jack is about dead. So, I'm going to buy new jack and some more stands. How tall do I need to get so that I can safely drop the transmission (manual)? I'd like to be able to drop it with low profile transmission jack, so I don't drop it on my head. So, I need to get the 330i up tall enough to fit the transmission on the transmission jack and roll it out.
Let me know.
tlester is offline   Reply With Quote
Old 06-15-2013, 12:22 PM   #2
jdstrickland
My Ride: '94 325iC & '00 323i
I'd put this car on four stands, and put them as high as they can go. I'd look for 24 - 30 inches, and take more if I could get it. I'd lift the car half the distance on one side, or end, and then lift it the full distance on the other, then return to the first and lift it the remaining amount.
Old 06-15-2013, 12:28 PM   #3
NumbaOneNewb
My Ride: 2003 330CI Silver
Re: Jack & Jack Stands... How Tall?
I just hate getting that far under the car. Scares the crap out of me. When doing my post cat o2s, not only did I have 2 jacks and 2 stands holding it up,I also used 4 of my rims placed in clutch spots in case **** falls and I needed an emergency bailout route
Sent from my SPH-L710 using BimmerApp mobile app
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 06-15-2013, 12:40 PM   #4
tlester
My Ride: 2001 330i
Yeah... scares me a bit, too. It's one of the reasons I'm getting new stands, so my old stands can be safety backups.
Old 06-15-2013, 12:46 PM   #5
iRide113
My Ride: 2004 M3
If you're scared, build some wood ramps.
Something like this or you can buy these.
Personally I would build some wooden ramps because you can make them to your wanting - just remember lots of lateral support and you'll be fine.
iRide113 is offline   Reply With Quote
Old 06-15-2013, 12:56 PM   #6
tlester
My Ride: 2001 330i
Have any of you guys invested in one of those home scissor type lifts? Those seem pretty cool, but are like $1200. I mean... the work I'm going to be doing myself will more than make back $1200 compared to taking it to a mechanic, but still.... that's a lot of coin.
Old 06-15-2013, 01:15 PM   #7
FenderGuy05
My Ride: 2002 BMW 325i
The Rhino ramps definitely wouldn't work getting it up high enough. I used them for cooling system and an oil change, but anything farther back and you definitely dont' have the room.
FenderGuy05 is offline   Reply With Quote
Old 06-15-2013, 01:26 PM   #8
wildirish317
My Ride: 2004 325Ci vert
+1 I just changed my tranny fluid today, and the Rhino ramps didn't lift it high enough; had to put it on stands.
This is on my Christmas list:
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 06-15-2013, 01:29 PM   #9
tlester
My Ride: 2001 330i
Tasty... what brand/model is that?
Old 06-15-2013, 04:52 PM   #10
AV8OR
My Ride: 2000 323i
Here's the lift: http://naautoequipment.com/mid-rise-scissor-lifts.html
AV8OR is offline   Reply With Quote
Old 06-15-2013, 05:24 PM   #11
Alex323Ci
My Ride: M3 & 323Ci (sold)
that second one looks a lot like the HF one
http://www.harborfreight.com/automot...ift-91315.html
which btw looks scary to see that van on
that photo make me not want to buy it seeing it like that.
Old 06-15-2013, 05:44 PM   #12
iRide113
My Ride: 2004 M3
Even if you put four? I wasn't saying drive up on two, but rather raise the car with a jack in the front and put the Rhino Ramps under the front, then do the same to the back.
Old 06-15-2013, 05:54 PM   #13
wildirish317
Think about that, and explain in detail how it's done. To drive up on 4 ramps, all wheels must go the same direction. The ramps won't fit between the front and back wheels.
Old 06-15-2013, 05:58 PM   #14
iRide113
My Ride: 2004 M3
How long are they? If they're too long, couldn't you just put the rear ones backwards? It was just a suggestion, I don't have a pair. Personally, I built my own wooden ramps with LED's in them.
Old 06-23-2014, 04:33 PM   #15
Boolala
My Ride: 2001 325xi
I know this is an older thread but this is an awesome idea and I will be building mine this weekend. I need to get under my 325 and check tranny mounts, quibo, U-Joints etc etc etc and jack stands or Rhino Ramps don't cut it. With a crawler undre the car what couldn't a person do except for tire work and jack stands for that since you don't have to crawl under the car.
Boolala is offline   Reply With Quote
Old 06-25-2014, 08:55 PM   #16
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Since the drive-over height is 4", will that clear a low E46 such as with ZSP or even a lowered one?
Old 06-25-2014, 09:46 PM   #17
dakkon
My Ride: e46 330ci/e30 318is
Just get 4 6 ton jack stands from HF... I've been using them for years and have spent days under the car wrenching on it. Never worried about anything. The 330 only weighs 3400lbs ish.
As far as a floor jack goes. This is one of the best ones around.
http://www.pelicanparts.com/catalog/...ACHyd1_pg1.htm
dakkon is offline   Reply With Quote
Old 06-25-2014, 09:49 PM   #18
phoopsta
My Ride: 02 330xi 3-pedal
I had my car up on all fours with only about 18inches worth of clearance and did my CSB and Guibo. It was ok except the exhaust when it was time to put it back in. Its a little heavy.
When it is up , I climb into my car and wiggle a bit, make sure nothings sliding around, I also have a jack up front and try to have one in the rear just in case the jack stands "fail"
______________________________________________
phoopsta is offline   Reply With Quote
Old 06-26-2014, 12:49 AM   #19
BaliDawg
^^^^^This is good advice.^^^^^
Old 06-26-2014, 08:28 AM   #20
franz
My Ride: 03 330i
This is not true, I did the job twice by myself with Rhino ramps at the front and jack stands at the rear, was able to use a std jack to help lower & raise the transmission. I did not put the jack stands at their highest position in the rear, I think they were up one from the bottom. Esco stands.
franz is offline   Reply With Quote
330i, jack, jack stands, transmission
