Old 06-15-2013, 11:44 AM   #1
17AKing
My Ride: 2003 BMW 325xi
Exclamation Car won't lock with fob!
Help, my car won't lock with the fob, and every time I get in the car the dash beeps a bunch and it does the same thing when I get out. The key fob won't lock the car so I have to use the actual key in the door, how do I fix this?
17AKing is offline   Reply With Quote
Old 06-15-2013, 12:04 PM   #2
17AKing
And it's not the battery, I'm not stupid
Old 06-15-2013, 03:18 PM   #3
RayPooley
My Ride: 320i SE Coupe
You seem certain its not battery. How do you know that? If it is a central locking issue then I suspect GM5 module relays. Check this out.
Old 06-15-2013, 03:30 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
I believe the most common GM5 module problems are failure to unlock?
Simple test, borrow a spare key and attempt to program it to your car.
How do you know it is not the keyfob battery??
If the keyfob is original, it is likely failed or on the way out?
What beeping from the dash are you referring to?
Maybe the ignition switch is bad and thinks the key is still in the ignition? This may be why the car cannot be locked with the keyfob?
Old 06-15-2013, 06:01 PM   #5
17AKing
It's like a half second repetitive beep,
Te ignition sticks some times and I have to force the key to turn (approx. 20-30 ft.lb torque) then it clicks and goes
You may be right, I'm gonna take it to apple bmw in a few weeks if it doesn't work, any other thoughts?
Old 06-15-2013, 06:12 PM   #6
Foxtrot_Uniform
My Ride: 325Xi
GM5 module....
Foxtrot_Uniform is offline   Reply With Quote
Old 06-15-2013, 06:54 PM   #7
17AKing
Originally Posted by Big Rick View Post
GM5 module....
Okay, so If I get a new gm5 module, where is it installed in the car, how long will it take, and should I just have a non dealership german car repair mechanic do it?
Old 06-15-2013, 07:01 PM   #8
NumbaOneNewb
My Ride: 2003 330CI Silver
Re: Car won't lock with fob!
It sounds like it has something to do with your car not recognizing that the key has been removed from the ignition. If thats the case, it could explain why you hear that beeping momentarily. Also explains why you're having issues
Sent from my SPH-L710 using BimmerApp mobile app
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 06-15-2013, 07:03 PM   #9
NumbaOneNewb
I am almost 100% sure this has to do with your car thinking the key is still in the ignition
Old 06-15-2013, 07:08 PM   #10
jfoj
Put the brakes on the GM5 module for the moment, deal with the basics first. Best to have the GM5 module repaired if it turns out to be the issue. No coding or programming required if you get your module repaired.
Old 06-15-2013, 07:16 PM   #11
Foxtrot_Uniform
My Ride: 325Xi
Have you used the keys for a while? I mean... To make sure the battery inside is charged? If so... It is the GM5 module!
HERE is the location!
Old 06-15-2013, 07:18 PM   #12
NumbaOneNewb
Before you go buying a gm5 module, contact a member on here called.scottjoh. he is well known as being the guru of the gm5. His answer would be law when it comes to the gm5. I would only heed his expert advice. There is nothing about the gm5 module that he doesnt know
Old 06-15-2013, 07:19 PM   #13
17AKing
How much will that cost/what does that process entail?
Old 06-15-2013, 07:22 PM   #14
NumbaOneNewb
Find scottjoh. Get his advice first before firing your guns. It doesnt matter how much it costs because you will not want to know. On top of that, I thought a bit of programming is required
Old 06-15-2013, 07:29 PM   #15
NumbaOneNewb
oh wait. no coding needed on a repaired module. my bad
Old 06-15-2013, 07:44 PM   #16
17AKing
And yeah I've been using the keys for the past while every day
Old 06-15-2013, 07:52 PM   #17
17AKing
Okay, I messaged him about it,
And I need to know how much this will cost me, I'm 17, I don't have a ton of extra money, I gotta figure out and work on saving
Old 06-15-2013, 08:01 PM   #18
Foxtrot_Uniform
My Ride: 325Xi
Have you search for ANY threads or followed ANY links here? A lot of your questions would be answered if you did!
Old 06-15-2013, 08:07 PM   #19
jfoj
4th link in my signature has the website and last I was aware pricing was on the website for GM5 module repair.
Old 06-15-2013, 08:10 PM   #20
17AKing
Yeah, a few but they've not been what I was looking for completely
beep, dash, fob, lock, sensor
