Old 06-15-2013, 09:46 PM   #21
NumbaOneNewb
My Ride: 2003 330CI Silver
avoid using the key to lock unlock your car as much as possible. you WILL end up with a new problem which is your door lock cylinder breaking and you not being able to get in the car
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 06-15-2013, 10:17 PM   #22
scottjoh
My Ride: '99 323i & '02 540i
Car won't lock with fob!
Originally Posted by 17AKing View Post
Help, my car won't lock with the fob, and every time I get in the car the dash beeps a bunch and it does the same thing when I get out. The key fob won't lock the car so I have to use the actual key in the door, how do I fix this?
Make sure fuse 67 is installed and not blown.
scottjoh is offline   Reply With Quote
Old 06-16-2013, 02:39 AM   #23
RayPooley
My Ride: 320i SE Coupe
Okay, so If I get a new gm5 module, where is it installed in the car, how long will it take, and should I just have a non dealership german car repair mechanic do it?
Is my posting invisible or something? Watch the video. Jeez. Why do I bother?
Old 06-16-2013, 10:15 AM   #24
scottjoh
OPs problem is not the relays. Did you read his original post? I guess people don't both to there days.
Old 06-16-2013, 01:21 PM   #25
RayPooley
Yes. I did read OP's original post.
"Help, my car won't lock with the fob, and every time I get in the car the dash beeps a bunch and it does the same thing when I get out. The key fob won't lock the car so I have to use the actual key in the door, how do I fix this?"
He also excluded the battery in his second post.
What exactly is it in his first post that makes you think his his problem has nothing to do with the GM5 module? Excluding battery failure the failure of the central locking system to respond to the key fob is classic GM5 relay issue. Which is why I wrote "if it is a central locking issue ...".
Old 01-07-2014, 12:21 PM   #26
17AKing
My Ride: 2003 BMW 325xi
The key has no issue unlocking all the doors, the lock button on the center console works fine, windows work fine with the turn and hold key in the door to put up/down, and wipers work. It's NOT GM5
I talked to the dealership about it ,and they said it could be the receiver not picking up the signal. I have 2 keys, both unlock the door perfectly fine and start the car fine, and I think it's probably the receiver, or the car thinking there is still a key in the ignition.
Orion v2 Opaques
Golf Tee Mod
Aux Jack Mod
17AKing is offline   Reply With Quote
Old 01-07-2014, 02:29 PM   #27
scottjoh
Did you read my post (#22) nearly 6 months ago? Why do I bother?
beep, dash, fob, lock, sensor
