Old 06-15-2013, 04:25 PM   #1
martinmsport
My Ride: e46 320d 2003 black
Power and squeaky problems!!!
Hi everyone ,
I have a few problems !! Whilst driving to work I heard a squeak coming from my front driver's wheel , but it only squeaks when I turn the wheel to the right ever so slightly ??? And the second problem is as I was accelerating this morning in 2nd or 3rd gear I had a sudden complete loss of power with the warning triangle caption then it picked it self up again ?? Any ideas peeps
p.s its a 53 plate 320d.
Martin
martinmsport is offline   Reply With Quote
Old 06-15-2013, 05:12 PM   #2
martinmsport
Hi all ,
Again while I was driving today the same thing happened! Loss of power wirh the warning triangle caption flashing! !
I had a check to see if I could find the problem and found this ?? It is broken but don't know what it is , can you help !! Tge the 2 red bits are meant to be connected , and whats the black box it all goes to ??? Cheers
Martin
Old 06-15-2013, 05:20 PM   #3
martinmsport
http://forums.bimmerforums.com/forum....php?t=2005321
Power and squeaky problems!!! Help
Old 06-15-2013, 06:28 PM   #4
PerfectStorm01
My Ride: 320Ci
Originally Posted by martinmsport View Post
Hi everyone ,
Martin
Usually the warning triangle is for your traction/stability control. Mine sometimes goes on when I'm accelerating over a rough patch in the road or when it's wet out - read your owners manual.
A squeaky front wheel can be anything...need more info. Have you jacked up the car and tried to recreate the noise again?
PerfectStorm01 is offline   Reply With Quote
Old 06-15-2013, 06:50 PM   #5
NumbaOneNewb
My Ride: 2003 330CI Silver
Re: Power and squeaky problems!!!
If it occurs where you cant drive or start your car,try disconnecting your maf sensor. Or better yet,try it now and see if it happens again
Sent from my SPH-L710 using BimmerApp mobile app
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 06-16-2013, 02:59 AM   #6
martinmsport
Hi , I have tried to recreate the squeak but no joy !! And regards the power loss with warning triangle again no joy!!
Sent from my GT-I9305 using BimmerApp mobile app
Old 06-16-2013, 05:08 AM   #7
martinmsport
Do you think that the vehicle stability sensor has anything to do with it? ?
Old 06-16-2013, 06:20 AM   #8
PerfectStorm01
My Ride: 320Ci
Have you just changed your tyres? I googled your issue and one thread mentioned new tyres that needed to be broken in
Again, I get the same thing when my tyres slip...I think if the light stays on you may have issues? Do you have any codes SES on?
Old 06-16-2013, 06:23 AM   #9
PerfectStorm01
My Ride: 320Ci
Can you describe this in more detail? When it happens? Frequency?
Old 06-16-2013, 06:38 AM   #10
martinmsport
The squeak only happens when you turn the steering wheel to right slightly whilst driving and the power loss is infrequent
Old 06-21-2013, 12:55 PM   #11
martinmsport
I haven't had a look and what codes come up.
Old 06-21-2013, 06:04 PM   #12
martinmsport
Weekend bump
Old 06-21-2013, 10:25 PM   #13
73Challenger
My Ride: 2004 330Ci
Martin, I just bought an '04 330Ci with a 6 speed and I have one shared issue. Does this sound like what yours is doing - All is fine, then you hit a rough/slippery/sand/gravel that causes minor traction loss, the TC takes over, fist noted only by the light flashing, then the light stays on and power is pulled (assuming by TC) for 4-5 seconds, then it gets over it and light goes off and power is back. Just today I was trying to sort this issue, and have found that it hasn't occurred while TC is OFF, and once I turned TC off as soon as it pulled power and the issue immediately went away (possibly coinciding with the TC getting over the issue). I just found your post, so I will look for your broken component on mine in the AM, but I don't know what it is. I don't mind driving without TC, my challengers rear end is much more lively, but I prefer to keep all systems functioning properly.
John
73Challenger is offline   Reply With Quote
Old 06-22-2013, 02:58 AM   #14
martinmsport
Hi mate
Yeah very similar but mines seems to do it more on uneven ground ! I ordered the part yesterday from bmw for 60 so I will let you know if it fixes the problem !
Old 06-22-2013, 09:35 PM   #15
Alex323Ci
My Ride: M3 & 323Ci (sold)
interesting
subscribed to hear the outcome
Old 06-23-2013, 03:59 AM   #16
martinmsport
Interesting or annoying
320d, e46, power
