Old 06-15-2013, 06:35 PM   #1
mlah384
My Ride: 2005 330i 6spd
Central locking quit working after checking fuses
My keys quit working. I replaced battery in the keys. The keys are not responding to reprogramming. So I checked the fuses on the central locking system and now none of the power windows nor locks work... How do I get the central locking system to start back working with the interior controls?
I'm stuck with all windows down and they will not roll up...
Thanks...
mlah384 is offline   Reply With Quote
Old 06-15-2013, 06:42 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Make sure you put the fuse back in the correct position.
Old 06-15-2013, 06:42 PM   #3
NumbaOneNewb
My Ride: 2003 330CI Silver
Re: Central locking quit working after checking fuses
Have you tried rolling them up with the car started?
Are you 100% sure that the battery is the correct one used to replace it? And im not sure if you replaced it with a rechargeable or non rechargeable battery. I've always wondered if there would be a problem with the system attempting to charge the battery if a non rechargeable battery was used
Sent from my SPH-L710 using BimmerApp mobile app
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 06-15-2013, 06:44 PM   #4
mlah384
Correct position? I put them back in the same spot... Are they directional? How do I find out the proper direction? I've never heard of a directional fuse?
Old 06-15-2013, 06:44 PM   #5
mlah384
Power windows and power locks are totally dead with car started...
Old 06-15-2013, 06:45 PM   #6
jfoj
Not direction, but if I could have $5 for every situaiton where someone removed a fuse to check or replace it and claimed they put it back in the proper location, I would have a nice mod/maintenance budget!
Old 06-15-2013, 06:47 PM   #7
NumbaOneNewb
Have you attempted to roll windows up by sticking key in lock on driver door and turning it to the right and holding it there
Old 06-15-2013, 06:47 PM   #8
mlah384
Fuses are in correct spot
Old 06-15-2013, 06:47 PM   #9
jfoj
Pull fuse again, check that is did not blow, leave it out for 5 minutes, then reinsert and try again.
Old 06-15-2013, 07:14 PM   #10
NumbaOneNewb
While youre at it,dont just check the obvious fuses. Look into the
Fuses related to the thiefproofing system , fuse 49 &67 I think
Old 06-15-2013, 07:24 PM   #11
NumbaOneNewb
Just an odd question here. Did you pull the fuse out when your key was in the ignition by chance?
Old 06-15-2013, 08:26 PM   #12
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
What would that have to do with anything? I don't think the OP would be that dumb to check with the car on.
scottjoh is offline   Reply With Quote
Old 06-15-2013, 09:11 PM   #13
NumbaOneNewb
hence the "just an odd question" explanation prior to my question. and? what would your statement "what would that have to do with anything?" have to do with anything?
Old 06-15-2013, 11:50 PM   #14
mlah384
Sorry for the late reply... I pulled all the fuses back out, checked them with a meter, they all tested fine... I put them back in, and it started working... weird, weird, weird....
Also, I've read that if you lock all the doors and can still open the fuel door then the fuse is blown that goes to the fuel door actuator or either the actuator itself is bad? That this can cause the keyless entry to not work?
I've been unable to locate the fuse to the fuel door actuator...
The batteries that came out of the keys tested fine on the meter (3.0v and 3.3v) I replaced the 3.0v with a new battery but it will not program. I cannot figure out why the key will not program...
Old 06-16-2013, 01:19 AM   #15
NumbaOneNewb
well I'm glad members on here were persistent in pushing you to continue and check your fuses. so, next problem. why it isnt initializing? well, did you check the fuses? jk. so both lock unlock working? check fuse 49. if that didnt do anything, I'm not sure myself. now you had 2 keys right? have you tried switching the key you use to start the procedure? that might help
Old 06-16-2013, 09:20 AM   #16
scottjoh
Modded ///Member
The fuel flap actuator is powered from the same fuse as the door locks. If the there is no fuse for the door locks then the flap won't work either.
I keep telling people the battery's in the fobs are not the problem and rarely go bad. After repairing almost 100 of them I rarely need to replace it. Other stuff goes bad, but, not that. The can't sync problem could be in the car and not with the remote. Have you read my web page on the subject www.bmwgm5.com/no_fob.htm
Old 06-16-2013, 12:12 PM   #17
mlah384
Unfortunately when I opened the main key, the circuit board was damaged so I'm stuck with only the back up key (has red strip on back). Is this key able to be synced? or does the master key have to be synced with it or I'm out of luck?
Thanks for the link scottjoh, I read through it and I think the amplifier might be my problem? Especially since the battery in both keys were fine... they just quit working. The main key that I always used slowly got weaker and weaker as if the battery were going dead. It wouldnt always work, or you had to be very close to car for it to work. Then one day it stopped working totally.. so could the amplifier go out slowly like that?
Old 06-16-2013, 12:18 PM   #18
scottjoh
Modded ///Member
What you call the master key does not need to be synced in order to sync other keys. You only need a key that is able to start the car to begin the sync process.
I have not heard of the amplifier failing that way. That is usually a key problem.
Old 06-16-2013, 01:38 PM   #19
mlah384
Neither key worked... One wasnt used for years, the other I used daily and it died slowly. I opened both keys up and both batteries tested fine. I soldered new battery in non-damaged key just incase the old battery had problems under load. And it will not program. Even when I hold my mouth just right... I'm at a loss...
Old 06-16-2013, 01:51 PM   #20
scottjoh
Modded ///Member
From your description I'm pretty sure the key fob it bad. Take them to the auto parts store. Many stores have remote testers these days or contact me via PM to arrange testing and repair.
