///M3 Forum
Old 06-17-2013, 06:07 PM   #1
Mddicted
My Ride: M6
95 Octane Joy Ride
Added 9 gals of 100 octane unleaded and topped off with 91 - Full tank of roughly 95 octane and the concensus optimized octane for the factory tune. Cannot afford to do it all of the time but sure is an extra kick in the pants once in a while!
Highly recommended.
Mike
2005 Silver Grey Metallic / Imola
Competition Pkg
Slick top
Active Auto Werke Headers
Rogue 3" Race Exhaust w/Y pipe
Dinan 3.91
KW Clubsport 3 Way Coil Overs
Rogue Adjustable Rear Camber Arms
Fluidyne Aluminum Radiator
Rogue Aluminum Oil Cooler
AKG Solid Motor and Transmission Mounts
UUC Organic Clutch Kit w Aluminum Flywheel
Brembo calipers with OEM Comp rotors
PFC 08's
Nitto NT01's 18" Sq on Apex Arc 8's
Mddicted is offline   Reply With Quote
Old 06-17-2013, 06:45 PM   #2
Alaska
My Ride: E46 + other junk
Where are you reading that 95 is optimum on a factory tune? Just curious. I really have no idea but would like to know.
Alaska is offline   Reply With Quote
Old 06-17-2013, 07:09 PM   #3
Mddicted
My Ride: M6
I copied this post below from the M5/M6 boards, I have seen similar reports on other forums for other BMW engines. It is definitely a seat of the pants difference in performance. Opinions differ on what ratio is required to achieve 95 Octane, I use basic math and figure I am close with 9 gals of 100 in a full tank.
"High octane gas / Trick Gas
I did a search and didnt come up with anything so here you go for sharing.
When I had my E39 M5, we experimented with higher octane gas.
We learned a lot so I thought I'd share it here too in case some of you are not aware of this.
Summary:
On E39 M5's S62 motor, we learned that the engine loves higher than 92 octane gas.
We learned that if we add 5 gallons of 101 octane then fill up the tank with 92 octane super unleaded gas - the BMW engine becomes really happy.
Acceleration is much smoother, throttle response is much quicker, the engine simply runs better with higher octane gas.
95 octane is pretty much it. Anything higher than 95 is a waste /no additional benefit.
So I have been trying 5 gallons of 101 octane to my M6 for a while now and I tell you - whoooaaaa!
The V10 S85 engine just loves it too.
I caution you - trick gas is addicting!
Hope that helps some of you."
Competition Pkg
Slick top
Dinan 3.91
PFC 08's
Old 06-17-2013, 09:07 PM   #4
grkm3
My Ride: Money Pit
Send a message via AIM to grkm3
93 Octane all the time FTW.
SOLD
03 Steel Gray M3 - Imola Red Interior - SMGII - Premium - HK Sound
Mods: VFE SC Stage 2, SS Ceramic Coated Stepped Headers, S-Pipe, X-Pipe, TMS Subframe Reinforcement, KWV2 Coilovers, TMS Camber Plates, Powerflex RTAB's, Rogue RSM's, ZCP F/R brakes
Coming Soon: Open to suggestions
grkm3 is offline   Reply With Quote
Old 06-17-2013, 09:11 PM   #5
Moosecakes
My Ride: 02' SMG M3
I get 92/93 depending where I'm at. Chevron usually has 93 available and shell is typically 92.
Moosecakes is offline   Reply With Quote
Old 06-18-2013, 07:50 AM   #7
Suseer
My Ride: Cayman S
I fill up with 94 octane here, unfortunately it has "up to" 10% ethanol -_-
Suseer is offline   Reply With Quote
Old 06-18-2013, 09:46 AM   #8
Inflame
My Ride: 2002 M3 TiAG
93 is no problem here in Michigan, some Sunoco have 94.
Inflame is offline   Reply With Quote
Old 06-18-2013, 09:58 PM   #9
Charlescrs6
My Ride: E46 M3 Convertible
Never put anything except for 93 in here in CT. Us east coast guys at least have something going for us!
Current: SG/IR E46 M3 Convertible
Past: 2004 Audi A4 USP, 2003 Audi A4
Charlescrs6 is offline   Reply With Quote
Old 06-20-2013, 01:22 AM   #10
illestminimike
My Ride: Project Drama
95 Octane Joy Ride
I'll try this next track day.
Old 06-23-2013, 01:51 AM   #11
aaronstarr
My Ride: e46 m3
i wish someone would just break down and do a dyno comparison. when i first got my car (e46 m3)it had very cheap gas in it and kept pinging so i put 3.5 gallons of c12 race fuel in to bring the octane up the mixture was enough to bring the octane way up but not really mess with the cats to bad. either way it sounded more aggressive and felt like it was pulling the front end up. Ive tried this in a 05 audi s4 4.2 as well and results were similar..
aaronstarr is offline   Reply With Quote
Old 06-23-2013, 02:35 AM   #12
Steve///M
My Ride: E46 M3 LSB Vert
95 Octane Joy Ride
There was a dyno study on the E46 M3 by either Turner Motorsport's or Jim Confortti, not 100% sure who, but they found that there were significant WHP gains by using up to 96 octane. The car would self adjust timing advance and retard automatically, anything higher than 96 would not yield any additional benefits. This was based off of a stock E46 M3.
Steve///M is offline   Reply With Quote
Old 06-23-2013, 02:43 AM   #13
aaronstarr
My Ride: e46 m3
nice. i wonder how quickly it adapts and advances timing and what the perfect formula in mixing fuels would be for maximum results?
Old 07-01-2013, 07:11 AM   #14
Steve///M
95 Octane Joy Ride
Theoretically it would depend on your method of mixture and the time it would take to clear the lines and fuel rail of old gas. Say for example you were to put five gallons of c16 in first on an empty tank and then fill it with 92, that alone would obviously mix the fuel enough to where you wouldn't have to drive like an idiot trying to slosh the fuel around. The ECU will begin adjusting timing as soon as the car is started to optimize performance and reduce any chance of ping or knock. As far as max octane/mixture for best performance, going higher than 96 octane is pointless on a stock tune as you won't see any gains past that. Now if you have a programmer, shark ECU injector, or a nice evolve tune then you may yield more gain with higher octane than 96, either way be ready to watch you temp gauge run hot!!!
Old 07-01-2013, 01:07 PM   #15
aaronstarr
My Ride: e46 m3
thats an untrue myth btw race fuel burns slower and colder if you were running thick aluminum spacers on the throttle bodies it would be freezing cold to the touch or form ice c16 is a very slow burning fuel that mixed with high velocity air would not cause the engine to run hot ive tried this and seen it on high comp 1000 hp cars....87 oct burns quicker and hotter temps and nitro meth is just ferocious lol
Old 07-01-2013, 03:28 PM   #16
piaa_ump
My Ride: 2000 328CI
My father was a pilot and kept his Cessna 172 at a small local airport, as a teenager, I regularly purloined a number of gallons of 100 octane avgas to add to Trans Am gas tank..........lol...good memories ........
piaa_ump is offline   Reply With Quote
Old 07-01-2013, 05:43 PM   #17
MathewM3
My Ride: BMW M3 E46
F.Y.I they actually have 98 octane available at gas stations in Europe (Germany and northern Europe, not sure about the rest of the continent).
MathewM3 is offline   Reply With Quote
Old 07-01-2013, 06:32 PM   #18
//Maxwelljuppercut
My Ride: e46
110 "racing fuel" is available at a few gas station by me
//Maxwelljuppercut is offline   Reply With Quote
Old 07-01-2013, 06:36 PM   #19
Elvin123
My Ride: 328i
95 Octane Joy Ride
Haven't even touched anything less than 93
Elvin123 is offline   Reply With Quote
Old 07-02-2013, 01:03 AM   #20
Mddicted
My Ride: M6
Be careful with 110, at least here in Socal it is leaded and will destroy the cats. They register who they sell it to here and it must be used for track purposes only.
Our premium is only 91 no matter where you go.
I have heard they use a different method to calculate octane in Europe and that is why the numbers are higher.
Competition Pkg
Slick top
Dinan 3.91
PFC 08's
