Old 06-17-2013, 06:05 PM   #1
M6BrokeMe
My Ride: 2001 330 ci, 1988 M6
Can I change from rain sensing ...
windshield wiper system to a normal one with just delay? If so, how can I accomplish this?
Also, do I need to reprogram my computer for this?
M6BrokeMe is offline   Reply With Quote
Old 06-17-2013, 07:04 PM   #2
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
It can be done. Yes, you will need to reprogram the computer. Not sure if the stalk is the same with and without rain sensing. Do you have the 4 position variable delay on the stalk? If it's not there then there may be a wire that will need to be added.
scottjoh is offline   Reply With Quote
Old 06-17-2013, 07:20 PM   #3
Zell
Zell's Avatar
My Ride: so turbo wow
If you simply unplug the rain sensor (or the fuse for it) you'll have normal delayed wiping. You will lose the light sensor though. You can also reprogram the LCM to not use the rain sensor if you want. That way you can keep auto lights.
Old 06-17-2013, 10:02 PM   #4
auto180sx
My Ride: '02 Steel Blue 330Ci
Thats nice to know, I've got bubbles in between the sensor and windshield on the car so mine dosen't really work... I have really ****ing fast and way to ****ing fast as far as delay goes. Anyone have any suggestions on replacing the rain sensor? I've heard I need a new windshield altogether to fix it.
Steel Blue FTMFW!!
OKI BMW
BMW CCA Member #444186
auto180sx is offline   Reply With Quote
Old 06-17-2013, 10:09 PM   #5
Rezist09
My Ride: 325i sedan
This to mines doesn't not work
Rezist09 is offline   Reply With Quote
Old 06-20-2013, 05:54 PM   #6
M6BrokeMe
Not too keen on reprogramming the LCM but that sounds like the way to go compared to the other methods mentioned. Thanks for all the suggestions. I'll post back with my results.
Old 06-20-2013, 06:12 PM   #7
B78SYX
My Ride: 325CI 2004
I have changed my broken windshield at Pilkington, locally and, despite I thought also that it comes with a new sensor, it has just a frame, where the sensor is fixed...therefore, it can be replaced, not with too much hassle, by what I have seen in their workshop...you will have to remove its cover and to take it easy, not breaking anything. Check realoem about sensor price although, you might just need to clean the glass, in that area, and reconnect the sensor...
B78SYX is offline   Reply With Quote
Old 06-20-2013, 06:30 PM   #8
Zell
Zell's Avatar
Oh dude, easy solution! All you need is some thin wire, patience, and clear silicone sealant.
http://forum.e46fanatics.com/showthread.php?t=615032
