Old 06-18-2013, 10:23 PM   #1
indoafro
My Ride: 325ci
325ci with 330 manifold ?? need expert
so i just read a tons of thread from this forum and bimmer forums about swaping the manifold
there are a few question i want to ask to u all
1. i have 325ci 2001, its m52b25, am i right ?
2. so, if i want to use the manifold from M52B30, what should i need ?
3. does my car is dbw ? if its not, how can i use the m52b30 manifold ? (considering the M52b30 using a dbw)
4. any diy ?
indoafro is offline   Reply With Quote
Old 06-19-2013, 12:23 AM   #2
Hornung418
My Ride: '04 MB ZHP
A few things:
1. Car is M54B25.
2. Manifold is M54B30. You need an M54B30 Manifold, B30 DISA and B30 Throttle body, probably need the boots and the MAF from the B30 as well as an airbox to fit the new 3.5" intake tract.
3. The M54 is Drive-By-Wire.
4. Yes. Research.
Truth be told, you won't really gain all that much. Something around 6 whp. Wouldn't waste my time getting dirty unless you seriously know what you're doing or what the end goal for the car is. A non-M will never be fast. I would focus on Suspension upgrades and cosmetic enhancements.
Hornung418 is offline   Reply With Quote
Old 06-19-2013, 12:48 AM   #3
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Originally Posted by Hornung418 View Post
A few things:
1. Car is M54B25.
4. Yes. Research.
All good advice !
Being a fan of WHP in any amount though, 6 WHP or so is worth getting dirty for; at least in my book. NITROUS !
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 06-19-2013, 08:38 PM   #4
indoafro
My Ride: 325ci
for the TB, because its dbw, does the TB use the same electrical socket ? or i have to change it ? couple question
1. how about if i use just the manifold ? and just use my TB ?
2. how about i use the standart manifold, but use the TB from 330 ?
Old 06-19-2013, 08:39 PM   #5
Hornung418
My Ride: '04 MB ZHP
Re: 325ci with 330 manifold ?? need expert
Different diameters and bolt patterns between the designs of each part.
Old 06-19-2013, 08:39 PM   #6
Hornung418
My Ride: '04 MB ZHP
Plug is the same.
Old 06-23-2013, 09:52 PM   #7
indoafro
My Ride: 325ci
any diy for this manifold ?
Old 07-03-2013, 04:12 PM   #8
indoafro
My Ride: 325ci
bump and question
should i use the M54b30 TB ?
Old 07-03-2013, 10:31 PM   #9
jdjg
My Ride: e39, m52tub30
Originally Posted by indoafro View Post
bump and question
Yes
jdjg is offline   Reply With Quote
Old 07-07-2013, 12:18 PM   #10
TerraPhantm
My Ride: M3 & ZHP
A few things:
1. Car is M54B25.
4. Yes. Research.
B30 maf wouldn't be a good idea without retuning for that maf.
Old 07-07-2013, 08:06 PM   #11
mjpgolf1
My Ride: 00 328i,05 745,03 X5
Save your money and time. Buy a sports car if you want horsepower. If you love your BMW and want more out of it then do your maintenance on it and spend your money refreshing the old worn out parts that are supposed to be on your car. It's not worth the money spent for only 6 hp that you won't even feel. Just take care of and enjoy what you have and save your extra money for a faster car down the road. Kids, ugh!
mjpgolf1 is offline   Reply With Quote
Old 07-07-2013, 08:10 PM   #12
indoafro
My Ride: 325ci
win!! lol.. i am saving money to buy another car.. i just want to improve my skills..and also i just want to build a daily driven N/A drift car...i love my bmw, thanks for ur advice man
