E46 Convertible
Old 06-27-2013, 01:55 PM   #21
Dave
Moderator
Dave's Avatar
My Ride: 323,330,M3,M3,M3
Originally Posted by jeton_g View Post
Has anyone figured out how to keep the glove box unlocked so I dont always have to open with the key, even with the key it takes about 5 minutes, seems the key slips from the spot it needs to be unlocked and i have to play with it over and over....sometimes its embarassing when theres females in the car
Whenever it takes me five minutes to get it in when ladies are present I get embarrassed too.
Originally Posted by johnrando View Post
There are 3 settings I believe. One is lock/unlock with the car. One is locked so manually you have to unlock. The other is unlocked all the time. I'm not 100% sure. So, they (the keyhole position) would be either horizon right, horizontal left, or vertical.
I believe horizontal-left is always open. The problem mine had (before it got broken) was that it'd often rotate itself a few degrees. For a while that meant I had to shut the car off and open it, which was annoying, but as it turns out I can just stick another key in there to turn it those last few degrees from 10:00 to 9:00. Or could, anyway. I assume that a newer tumbler mechanism wouldn't have that issue...
Perhaps you think multi-million dollar ad campaigns make a beer taste better. Perhaps you're mouthing your words as you read this.
Dave is offline   Reply With Quote
Old 07-07-2013, 05:26 PM   #22
Retrax
My Ride: 2004 325CI vert
So the lock is stuck? Try fvcking the lock with the key. (Sorry, but when I describe it, that's what people say it sounds like). In other words, insert the key slowly, gently, and turn it very carefully in every direction (full right, full left, whatever) to see if it opens. If not, try pushing it in hard and turning it hard right, left, whatever (order doesn't matter) to see if that works. Do it multiple times, trying different depths and force. Mine was stuck and seemingly would never open, and finally after just trying every sort of touch/turn, it finally budged.
If it opens, tighten the screws on the inside, which is usually the culprit. I'll post some pics if I get a chance tomorrow.
Thanks for this, you saved me a lot of time just tightening the screws to fix my problem. If I had not read this I would have taken the whole thing apart for no reason!
Retrax is offline   Reply With Quote
Old 07-16-2013, 04:02 PM   #23
Phoenix330ci
My Ride: 04 330Ci Convertible
Yeah slightly old post here but mine has gotten stuck before and I have taken it apart and messed with it a few times and then it works for a while then it stops. I considered buying new parts. The parts diagrams and numbers can be found on RealOEM.com. I priced out the parts in AutohausAZ, and they end up being costly, like $50 for one and I think $90 for the other. It would appear that I only need the outside handle, or the handle part. The key barrel comes out and swaps. If you are having problems with the trunk then I think that is the rear part or the one on the inside of the glove box since there is an electrical connector in there.
Phoenix330ci is offline   Reply With Quote
Old 07-21-2013, 08:55 PM   #24
jimvideopro
My Ride: 2006 330CiC
Glove box handle ripped off - now what?
I had the same problem with the glovebox refusing to open sometimes, then it started making a HORRIBLE screech every time I locked the car. Typical overly complex, under-engineered BMW design.
I undid the latch screws, separated the two halves of the latch and just disconnected the wire to the power lock in the glovebox. Problem solved. Latch has not stuck since. And I confirmed that the trunk button does not work with the car turned off.
jimvideopro is offline   Reply With Quote
Old 07-22-2013, 12:11 PM   #25
Dave
Moderator
Dave's Avatar
OK I officially have no idea how to open my glove box now that the handle has broken off. This is no good.
Old 07-22-2013, 12:22 PM   #26
petemo94
My Ride: 2004 325CiC
This is why I (and you) need a up-close picture of the lock mechanism(s) that are holding this thing in place.
My key does nothing for my lock and I can't open it. Can someone take some close up pics of the inside locking mechanisms? Dave will be you a beer ;-)
Regards,
PeteMo94
2004 325Cic, ZSP, ZPP, ZCW, Owned since 12/1/12
///M3 Floor Mats - Power under my feet!
petemo94 is offline   Reply With Quote
Old 07-26-2013, 06:22 PM   #27
jimvideopro
Try realoem.com and find the appropriate diagram.
Old 08-02-2013, 03:51 PM   #28
Dave
Moderator
Dave's Avatar
Pete, here's a closer photo of what's left. With and without flash. I really have no idea what to do. And now I think I blew a fuse for my BM53. Right before I need to go on a long trip. And I can't get at the fuse box.
I'd REALLY love to know how to get this thing open. (But also then closed again until I get a replacement)
Old 08-02-2013, 03:58 PM   #29
Dave
Moderator
Dave's Avatar
Somehow this all looks unfamiliar to me even though I know I've looked it up before.
Perhaps I can detach that piece somehow - appears to be #4 in the diagram - but that still seems rather insecure (at least when it comes to professional thieves).
http://www.realoem.com/bmw/showparts...38&hg=51&fg=30
Old 08-02-2013, 05:53 PM   #30
Dave
Moderator
Dave's Avatar
OK, that wasn't actually all that hard. And it wasn't the fuses... my BM53 is just flat dead now. (Awesome!) But at least I solved one issue...
Long flat screwdriver to pry down the top, unscrew the three philips heads, reach in with your hand or a screwdriver and hit the triangular mechanism, it opens. Then from there you learn that the metal L piece there angles UP - so push it towards 1:30/2:00 on a clock... and that's how your glove box mechanism works. I'll just need a new handle, to swap lock tumblers, and to re-splice the broken wires on the thing that presumably runs to the car power and locks the trunk. And now it's unlocked (the black plastic bits behind and left of the L are the lock/unlock slider) and I can just move the L when I need to get in.
Old 08-02-2013, 08:32 PM   #31
johnrando
My Ride: '06 330 CIC ZHP
Good work. Sorry I haven't had a chance to check on my parts to see what I have, it was my (extremely) busy time of year at work. I'll see what I have this weekend now that I've been able to come up for air.
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
