Old 06-19-2013, 11:15 AM   #1
Shazam3
My Ride: 2002 e46 M3
MAX PSI Turbo Stage I kit - getting installed
Hey guys -
I am getting the MAX PSI Turbo Stage I kit installed. I am getting the following:
1. MAX PSI Stage I kit
2. AEM Wideband and eBoost II.
3. Southbend stage 4 clutch.
4. Subframe reinforcements with all the differential bushings rehaul.
I will post updates as they come available from MAX PSI. A few pictures attached.
My experience has been outstanding with the guys at MAX PSI! This includes shipping, receiving and start of work on my car.
ID:	511899   Click image for larger version
Shazam3 is offline   Reply With Quote
Old 06-19-2013, 12:01 PM   #2
2002330i
My Ride: 2002 330i
Send a message via AIM to 2002330i
This will be good!
THANKS JAKE!!!
2002330i is offline   Reply With Quote
Old 06-19-2013, 12:05 PM   #3
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
MaxPSI FTW
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 06-19-2013, 06:46 PM   #4
Moosecakes
My Ride: 02' SMG M3
Congrats man! Wish I could do that haha
Moosecakes is offline   Reply With Quote
Old 06-19-2013, 07:20 PM   #5
luke@maximumpsi
Past Site Sponsor
My Ride: 750hp E36 NickG Tune
Hey guys,
We got Sheraz's car here mid morning on Monday. So far the stock components have been removed, the Southbend Stage 4 clutch has been installed, and the majority of the turbo kit has been installed.
We also dropped the subframe and found a few minor cracks. Luckily we caught these before the chassis saw boost!!
On the agenda for Tomorrow, we will be cleaning up the mounting points and welding our reinforcement kit in, followed by installing a set of AKG black sub frame bushings, rear trailing arm bushings, and diff bushings. Once the sub frame is back in, the fuel pump will be installed and the last bits and pieces of the kit will be mounted in place. Then it is on to the dyno!
luke@maximumpsi is offline   Reply With Quote
Old 06-19-2013, 08:40 PM   #6
STORMER
My Ride: AA SC 98 M3
Me Jelly Looking good man. Obviously in for pics and vids
360+rwhp
AA Stage 2, Arp2000, Underdrive Pulley, M50 Manifold, Cat Delete, Supersprint Exhaust, M5 Clutch w/ Lightweight Flywheel, Euro Fan, FK Coilovers, AEM Boost Gauge, Zhp Knob, Stoptech Brakes, R1 Rotors
Originally Posted by Sweetness View Post
You sir, just thread jacked the sh!t out of OP.
STORMER is offline   Reply With Quote
Old 06-20-2013, 07:34 AM   #7
BDUB328I
My Ride: bmw 328i S54 sedan (
looks great.
BDUB328I is offline   Reply With Quote
Old 06-20-2013, 08:09 AM   #8
cosmos///m3
My Ride: 2005 JB/IR ZCP ///M3
Looks great guys.... Does the bracket for the turbo require a new/different motor mount? I just installed Vibra-Technics Motor mounts about 3 months ago and love them reason I ask...
2005 ZCP Schwarz II/Imolarot 6spd ///M3 ||| 1999 Estoril Blau/Estoril Blau ///M Coupe "Clownshoe"
2014 Alpinweiss Uni/Mokka X5 ///M Package (wifey)
cosmos///m3 is offline   Reply With Quote
Old 06-20-2013, 08:32 AM   #9
ECHydro
My Ride: 525i
Beautiful car. excited to see the dyno numberss
ECHydro is offline   Reply With Quote
Old 06-20-2013, 10:30 AM   #10
Sedan Hussein
My Ride: e46
Me likey. Did you ship the car to the shop or drive it?
Sedan Hussein is offline   Reply With Quote
Old 06-20-2013, 10:31 AM   #11
luke@maximumpsi
Past Site Sponsor
We include a different motor mount arm and motor mount for the passenger side with the kit. There is a potential your new motor mounts will work. Send me a picture of them and I will tell you.
-Luke
Old 06-20-2013, 12:52 PM   #12
Shazam3
Carrier delivery/shipped.
Old 06-21-2013, 12:52 AM   #13
02black330ci
My Ride: spaceship
Congrats OP on your MAXPsi kit!
Originally Posted by luke@maximumpsi View Post
Hey guys,
The Southbend Stage 4 clutch has been installed, and the majority of the turbo kit has been installed.
Stage 4...? Isn't that a bit of an overkill for this kit? Or is the OP planning on more "PuuuurrrrRRRRrr" in the future
02black330ci is offline   Reply With Quote
Old 06-24-2013, 08:07 AM   #14
A4RingedONE8T
My Ride: Turbo ///M Roadster
Always better to have more than less when it comes to a clutch. The power of this setup is perfect for the 4, should get quite a bit of miles out of it at that level. Also pricing on 1 - 4 is separated by only a few dollars, probably less than $150 stage 1 to 4. Basically why not.
Looking good guys, when we gonna see some built motor numbers?? =)
A4RingedONE8T is offline   Reply With Quote
Old 06-24-2013, 09:09 AM   #15
Shazam3
^ Exactly.
Old 06-24-2013, 11:38 AM   #16
BaDiNfLuEnCe
My Ride: 04 m3, 06 jeep srt8
Originally Posted by Shazam3 View Post
^ Exactly.
6spd or smg.. I also have the stage 4
shes finally here
[/IMG][/URL]
BaDiNfLuEnCe is offline   Reply With Quote
Old 06-24-2013, 02:44 PM   #17
Shazam3
smg
Old 06-25-2013, 04:22 PM   #18
luke@maximumpsi
Past Site Sponsor
Hey guys,
Just a little update.
The car has been up and running for a couple of days now. We have been getting some street miles on the car to break in the clutch. We tried another injector set up to eliminate some hardware from the kit. Even though the injectors are rated for the same flow rate, they do produce different driveability results. Eventually we will be going to this new set of injectors on the stage one kits, but with Sheraz driving around in a rental car, I want to make sure his car is done in the time frame allotted. With that said, we will be going back to the original set up that the tune is currently calibrated for. Those will be going in today, then it is on to the dyno!
Here are some pictures for eveyone:
When Sheraz's car showed up, we noticed a fair amount of unwanted differential movement. With the subframe dropped, you can see why! All of the stock differential bushings were torn. We popped those out and installed the AKG black differential bushings, subframe bushings, and rear trailing arm bushings in the car.
We also Installed our sub frame reinforcement kit (this includes the trunk welding):
Here are a couple of pictures of how the car sits today with the gauges installed:
I know Sheraz is excited to get his car back! We hope to have some numbers soon!
Old 06-25-2013, 08:28 PM   #19
Shazam3
Can't wait to see the dyno results!
Old 06-25-2013, 11:33 PM   #20
02black330ci
My Ride: spaceship
OP, enjoy your car, there is nothing like turbo rush!
All valid points! Thanks for the response my friend
