Go Back   E46Fanatics > New Member Introductions
New members check-in, introduce yourselves, and post a picture of your BMW here!
Old 06-20-2013, 06:26 AM   #1
my323coupe
My Ride: 323ci
Hi from germany!
Hello!
I am from germany and this e46 platform gives ne many lessons! Thanks for that dudes!
I drive a e46 323ci with a engine swap to the m54b30.
Most is Stock !
Drive on lpg (kme diego g3 with obd Adapter and hana rails) about 4 years and 120000 km!
Last week i blow of my head gasket...
Now i had finished the engine rebuild.
I do the timing without special tools.. i marked all with steelneedle and waterproof markers.. now i have no torque under 2500rpm... and a static failure in the ecu!
Camshaft inlet sensor
Not correct signal
Static failure
When i put the connection unpluged from the camshaft sensor and i delete the failure the same failure comes back!
So is the timing incorrect?
A new sensor brings the same failure!
In another engine the sensor works!
I had test the connection between ecu and sensor the harness ist ok!
So i think i do the timing wrong an the result ist the failure in the ecu..but with disconnected sensor it throws the same code!
And the lack of power!
I read out with INPA!
Before i forget! I blow the headgasket with a damaged waterpump... the water wheel was loose.. ... i bought a new head.... and build in... i have full compression no water or oil use..
Sorry my english is bad...
The german guy sad thanks!
Sent from my GT-I9305 using BimmerApp mobile app
my323coupe is offline   Reply With Quote
Old 06-20-2013, 08:41 AM   #2
ikeupinya
Stay modded my friends!!!
ikeupinya's Avatar
My Ride: 05 ZHP
Hi from germany!
Hallo, welcome to the site & your English is really good compared to other Americans here!!!
Da Lil' Paratrooper!
ikeupinya is offline   Reply With Quote
Old 06-20-2013, 09:15 AM   #3
Crespo5190
My Ride: 2001 325CI
Hi from germany!
Originally Posted by my323coupe View Post
Hello!
Close but no cigar
-Tony
Crespo5190 is offline   Reply With Quote
Old 06-22-2013, 04:32 PM   #4
my323coupe
My Ride: 323ci
AW: Hi from germany!
Cigarett cigar is ugly...
Old 06-22-2013, 04:34 PM   #5
my323coupe
My Ride: 323ci
ID:	512519   Click image for larger version
ID:	512520   Click image for larger version
ID:	512521   Click image for larger version
Old 06-25-2013, 01:56 AM   #6
777eThOd*
My Ride: spins too much
Clean whip you have there mate!! Welcome aboard to the forums!
2007 BMW 335i FBO 6MT - Current
2013 Nissan Nismo 370Z - Current
2004 Non-M Facelift Coupe - SOLD
2006 BMW M3 - SOLD
777eThOd* is offline   Reply With Quote
Old 06-25-2013, 02:34 AM   #7
my323coupe
My Ride: 323ci
I need for my m54b30 swap a 316ci lable
Display Modes
