Old 06-20-2013, 12:02 PM   #1
Gasturbine
My Ride: 2005 330ci Cabrio
Switched 12vdc in teh trunk?
Anybody know if/where I can get (ignition) switched 12vdc power from in the trunk? I just need to power a small device that pulls like 750ma.
My car is wired for a CD changer, but I dont have one, so if that info helps...
Gasturbine is offline   Reply With Quote
Old 06-20-2013, 12:09 PM   #2
jdstrickland
My Ride: '94 325iC & '00 323i
I'm confused.
Have you looked to see if the wiring for the CD changer has switched-power.
HINT
Most of the switched power wires are RED/WHT. Some are other colors, usually RED with a stripe of another color.
The problem you will have is that many of these wires come out of a controller of some sort, and adding an amp to the load might not be appreciated by the circuit. You can test for switched or not easily enough with a volt meter.
There are lots of constant hots in the trunk, starting with the battery.
Old 06-20-2013, 12:37 PM   #3
Gasturbine
Originally Posted by jdstrickland View Post
I'm confused.
I dont know where the CD wiring is.
That why I thought I would use the switched power for the CD changer. With no load (CD changer) on it, Im sure it would handle 750ma.
Or a test light...this I know. Im looking for the LOCATION of said possible sources.
Cant use constant, but be switched with the ignition.
