Old 06-20-2013, 07:39 PM   #1
jdstrickland
My Ride: '94 325iC & '00 323i
Misfire caused by water
I was flushing something and flooded spark plug holes with water. Will the water go away on it's own or do I have to take stuff apart and blow the water out?
I'm hot and tired and my hands are sore, I really do not want to take anything else apart today. If the water will cook away in relatively short order, I'll ignore it.
Old 06-20-2013, 07:47 PM   #2
orb
orb's Avatar
My Ride: 325Ci
Personally I'd try and remove the water. Access isn't really that hard.
orb is offline   Reply With Quote
Old 06-20-2013, 08:16 PM   #3
davidwarren
Halfway to 2L
davidwarren's Avatar
My Ride: 2010 335i
I hope the spark plugs were installed? I would not start the car with standing water in the plug wells, but I bet if you leave your hood open in the sun it will dry out on its own fairly quickly. Otherwise I would hit it with some compressed air.
You down with UCC? Ya you know me!
sowing the seeds of jiggery pokery
davidwarren is offline   Reply With Quote
Old 06-20-2013, 08:19 PM   #4
jdstrickland
It's not that hard on my BMW, but I have another car with a similar spark plug configuration -- plugs at the bottom of a hole in the head and have very deep boots to make the connections. I'm still hot and tired and my hands are sore, and I rewared my hard work with some MGDs.
I'm gonna wait to see if the water dries up from the heat. I can fix it on Saturday if I need to.
Old 06-20-2013, 09:07 PM   #5
lszlszx
My Ride: 1.8T, XC70
The engine heat can take care of that pretty fast, I wouldn't leave the water
sitting though, because it can cause rust on the coilboot contacts.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
