Sponsored by BimmerWorld
Old 06-21-2013, 01:44 PM   #1
dkuchta
My Ride: 325cic
H&R Sport Cup kit rear shocks blown
I know this is a common thing, however I was interested to see what others have done. Is there a difference with the convertible and other models? I read xi owners were replacing with E36 M rear's.
I need to get new ones and don't want them to blow in 12k miles...
dkuchta is offline   Reply With Quote
Old 06-21-2013, 01:48 PM   #2
johnrando
My Ride: '06 330 CIC ZHP
Verts are different.
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 06-21-2013, 01:52 PM   #3
dkuchta
My Ride: 325cic
Thanks, That was my assumption.
So, I guess I am asking what others have been successful with?
Old 06-23-2013, 04:11 PM   #4
sakumaxp
My Ride: 02 M3 convertible
Do a rebuild
Carbon Black Metallic
SMG II
Verttttt
VCSL Front Bumper
VCSL 1 Piece Splitter
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
sakumaxp is offline   Reply With Quote
Old 06-24-2013, 02:49 PM   #5
dkuchta
My Ride: 325cic
Originally Posted by sakumaxp View Post
Do a rebuild
I have heard of and have done rebuilds on motorcycle front shocks. I did not know these could be rebuilt....
Old 06-24-2013, 07:40 PM   #6
sakumaxp
Some manufactures you can send the shocks back and they can revalve (I know not a word) them for you
SMG II
Verttttt
VCSL Front Bumper
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
Old 06-24-2013, 08:26 PM   #7
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Here's the deal, I don't know what Will fit & what will Not fit a convertible. For this part of the discussion I'm referring to actual "fit" (Not Shock Valving), as in it's ability to physically bolt in place. So, if the 95-99 E36 M3 Bilstein Sports physically can be bolted into your Bimmer, GET THEM.
I switched over from regular E46 Bilstein Sports to the 95-99 E36 M3 Bilstein Sports & all I can say is WOW. The M3 shocks are physically much bigger in diameter, and Will carry a greater load for a longer period of time. That's what the OP really needs, for me the key to there success is the control they have over the rear spring (I Run The H&R Race). That one change transformed my suspension.
OP, if they fit they're your absolute best option.
Good Luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 06-26-2013, 03:17 PM   #8
dkuchta
My Ride: 325cic
Good Luck.
Thanks, I will have to take a look what kind of clearance I have. I know because I'm running 245's it is very tight....
Also concerned about using un-matched shocks. Does anyone know what brand is matched with the H&R Cup kits?
Old 06-27-2013, 12:42 AM   #9
BMW WHP
My Ride: 01 330Ci w/ stick
Don't you know that H&R use Bilstein for your kit?
BMW WHP is offline   Reply With Quote
Old 06-27-2013, 03:53 PM   #10
dkuchta
My Ride: 325cic
That was my assumption, but I was not sure. I assume Bilstein does not supply a warranty for it... I am going to try and take a look at them this weekend and see if I can find residue from leaking or if I have another issue.
Old 07-03-2013, 04:02 PM   #11
Rob43
Rob43's Avatar
Any updates on this ?
