Sponsored by The Tire Rack
Old 06-21-2013, 07:00 PM   #1
TR4G-
My Ride: '01 325xi, '90 325iC
Wheel fitment: 42mm offset on xi
Hey guys,
considering picking up a set of elbrus ZHP reps. They are 18 inch with 42mm offset. First time purchasing rims. Will I run into fitment issues on either the front or the rear with 42mm offset?
Tires are 225/40/R18. I dont want to have to roll my fenders or do any shaving. Car has KW V1s, so height is adjustable
TR4G- is offline   Reply With Quote
Old 06-22-2013, 07:10 AM   #2
2003 325i
My Ride: '03 Orient Blue 325i
Re: Wheel fitment: 42mm offset on xi
As long as they're no wider than 8.5" you'll have no fitment issues
Sent from my SGH-I747M using BimmerApp mobile app
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
Old 06-26-2013, 10:19 AM   #3
jdny516
My Ride: Oxford Green M5
you should be fine. But why buy reps? real ones aren't that expensive
National Capital Chapter #465420
2000 ///M5 ///M Registry
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Frank Smith Tune
TTFS Alpha N
SuperSprint Headers
SuperSprint X-Pipe
DINAN Front Strut Brace
Storm Motorwerks Products
2003 BMW X5 4.6iS | Black Sapphire Metallic | Black Sport | Titan Trim
2000 323Ci | TiAg | Gray | 5MT | SOLD My Progress Thread
jdny516 is offline   Reply With Quote
Old 06-26-2013, 12:30 PM   #4
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
What width are they?
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 06-26-2013, 08:14 PM   #5
TR4G-
Ok we'll I've changed my mind lol. Headed out Friday to see if a set of OEM BBS Style 29s will fit on my xi. Tires are 225/55r16 I believe. Although the sidewall height is pretty large I think it should be fine if I raise up my car (sitting low on stock 17s now). That way I can relieve stress on my cv boots while enjoying e39 good looks on my shoes!
Old 06-26-2013, 08:51 PM   #6
2003 325i
Offset may be too low on those... careful.
Old 06-26-2013, 08:53 PM   #7
TR4G-
Et20. Same as style 5s which plenty of people have run on e46s without rolling fenders. I'm not looking to slam my car either, quite the opposite, so I think it may work out
Old 06-27-2013, 06:51 AM   #8
jdny516
I am with him on this one. Be careful, maybe if you run 215 or 205 it'll fit. Again it really depends on the suspension.
TTFS Alpha N
SuperSprint Headers
SuperSprint X-Pipe
Old 06-27-2013, 08:45 PM   #9
2003 325i
205/55 R16 is what you want for those, fronts will start to get close to fenders but should be ok as long as you're not slammed.
Old 06-29-2013, 09:49 PM   #10
TR4G-
Ok so picked up a pair of one piece BBS style 5s. 8x16 et 23 with 235/55 on two and 225/55 on the other two. They look pretty damn good! And fitment is almost perfect
Old 07-08-2013, 07:39 PM   #11
TR4G-
Running into a small amount of rubbing with moderate suspension play (dips in road, cornering hard). Looking to put on smaller tires. The OEM recommendation for a 16 inch tire is 205/55 I believe. Would it be unsafe to run 205/45s? I'm not concerned with the spedo issue, but more so rubbing. So stepping down from 225/55 (235/55 on rears) to 205/45 would probably cure my rubbing issues. What are your thoughts on this?
Old 07-08-2013, 07:51 PM   #12
2003 325i
You didn't listen to me...
205 is going to be a good bit of stretch on 8" wide. I'm not a fan of stretch...
If you find a wheel expert who says you can safely machine 5mm off the back pad of those wheels I would go that route...
Old 07-08-2013, 08:05 PM   #13
TR4G-
Sorry for not listening.
I don't understand why it would be such a stretch. 205mm is 8.07 inches. On and 8inch rim. How thick is the lip of a tire? Would not the stretch be minimal? Also what is the danger of stretching. Can the tire come off the rim? Or is it more of a stability issue with the sidewall of the tire?
Edit: I've been digesting a lot of information via several threads (This one as well as older threads via search) sorry if I've missed some points. I see now your reccomedation of 205/55.
Old 07-08-2013, 08:28 PM   #14
Foxtrot_Uniform
My Ride: 325Xi
TR4G... Are your style 73s 17X7? 205s are the stock tire on those... I figure you would have a little stretch but not a whole lot. Why not 215s?
Foxtrot_Uniform is offline   Reply With Quote
Old 07-08-2013, 09:27 PM   #15
TR4G-
Yes Rick, I have 205/45R17s on my 17x7 Style 73s. I also have a set of one piece Style 5s, 16x8 ET23. I'm using the style 5s as a summer set, and making my Style 73s a winter set. I'm looking for advice on tires for the Style 5s due to the low offset. When I picked them up they had 225/55s on two and 235/55s on the other two. I'm encountering a bit of rubbing with passengers in the car. Pretty much none when I'm by myself. However, this is not practical considering I have a sedan.
So I think I will grab a set of 205/55s to do away with this small rub. But I'm concerned whether 205s are safe to run on 8 inch rims. 2003 325i recommended 205/55s but says no way on 205/45s.
Old 07-08-2013, 09:27 PM   #16
2003 325i
I recommended 205s on a 7" wide rim, now you have 8" wide, effectively pushing your wheels out another 1/2" resulting in the rubbing your experiencing now.
As far as stretch goes that 205 is the width of the tire at the sidewall, not the tread patch. It will have some stretch but not excessive at all, however the problem that still persists is that you have too wide of a rim, or to low of an offset. Like I said as long as your not slammed and it's safe to machine off 5-8 mm off the back pad of those wheels, that's the best way I can see (be sure your rear wheel lugs do not interfere with park brakes). Otherwise you'll need to run some negative camber which costs money to get that adjustability in the front and will wear tires on the inner edges more, roll the fenders (not much can be done in the front from what I hear) which costs money, or run more stretch (which looks ghey unless your car is sick).
You got yourself into this, just be sure to keep us updated as to how you get out of it as this thread can become useful for those looking at what is "at the limit" in terms of clearance without issues.
BTW my fronts are 225/40 18s ET 29 and I'm lowered on H&R touring cupkit, It's really close but never rubs, that's why I knew you'd be in trouble.
It would help if you told us what suspension you're running as you indicated you have some drop.
Old 07-08-2013, 09:35 PM   #17
2003 325i
I think you'll be fine running that small amount of stretch (I know you will be) but I'm not POSITIVE you'll still have no rubbing in front with a loaded car.
The rears will 100% be fine. You may get away with just knocking out the alignment pin and running available camber up front (strut adjustment) and be ok, it will be close.
Old 07-08-2013, 09:37 PM   #18
TR4G-
Thanks for the help. I will keep this updated. Didn't realize that recommendation was for a 7inch rim. Makes sense now. I did see a picture of someone running 205s on an 8 inch rim and it did look a bit stretched. The look was not superb.
Running KW V1s, so I can mess around with the height.
Also, as is (225/55s on the front) I have significantly less rub up front than I do in the rear.
Old 07-08-2013, 09:44 PM   #19
2003 325i
Plugged your numbers in my favourite site: http://www.rimsntires.com/specs.jsp and it appears to clear. If you crank those up as far as you can I know you won't rub as long as your struts/springs are in good shape. Should be good to go with 205/55s.
I'd crank them all the way up in front and drive it loaded with people, find the nastiest road you figure you'll encounter and see. Then slowly lower and repeat until you rub, crank it up a couple turns and be good to go. KW V1s drop a min of 1.5" in front, mine's lowered 1.4", essentially the same.
Edit: Minimal to no stretch http://tyrestretch.com/?s=8.0+205+55+R16+. I'd bet that with the camber allotted to you by the manufacturer (assuming not maxed out negative as your car sits now) you could get away with 215/55s might look a bit better.
Old 07-08-2013, 09:50 PM   #20
TR4G-
Been using that site too. Lots of good information there. 205/55s look promising. I'm sitting at normal camber.
Have my rears at the highest setting with the 235/55s and am rubbing. For some reason my passenger side rear sits higher than my drivers side rear. Had these coilovers for just under 23k miles, they should still be in good condition at this rate no? Struts arent leaking, how long do springs last?
