Old 06-21-2013, 09:33 PM   #1
erich330ci
My Ride: 2004 330ci
Auto transmission clunk when coming to stop.
This just started today. When I'm slowing to a stop, when I get down to maybe 10 mph or so, I feel a fairly blatant clunk when the tranny shifts down from 2nd to 1st gear. It causes me & passenger to lurch forward a bit. It has never done this before. It's a 2004 330ci with about 85K miles. I've had the car for about six years and have never touched the tranny. I just asked my independent shop yesterday if I should have the fluid & filter changed, as well as the differential fluid. The answer was basically, "Wouldn't be a bad idea with almost 90K miles". I've put a few thousand bucks into the car for maintenance and wheels/tires/suspension over the last few months and after all that, I'm sick at the thought that I may have a tranny issue. Please tell me I don't!!! Any thoughts?
Thanks.
Eric H.
erich330ci is offline   Reply With Quote
Old 06-21-2013, 09:49 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
With any luck it could just be trans mounts, jack the car up & slide under. Sometimes they are so bad you can just see the damage without touching anything. Trans mounts are not expensive. IF it's inside the trans, well that's another story / price tag.
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 06-22-2013, 06:42 PM   #3
erich330ci
My Ride: 2004 330ci
Good luck.
Do the mounts just go bad all of a sudden?
Eric H.
Old 06-22-2013, 08:04 PM   #4
Rob43
Rob43's Avatar
Yes.
The old rubber fatigues, then one day it just fails, as in it breaks in half. With luck, this is your problem.
If not, the price to fix it will increase.
Good luck.
Old 07-14-2013, 08:33 PM   #5
erich330ci
My Ride: 2004 330ci
I have new tranny mounts in hand for installation, but it dawned on me that perhaps I should see how the 2nd-to-1st shift goes in sport mode. Tried it and there's no clunk. Drove it in sport mode a couple of times, then went back to normal mode. The clunk is now gone in normal mode. This is great, but I'm at a loss as to why there was a clunk. Seems as if it may be/have been a programming issue rather than anything mechanical. Stumped. Any ideas?
Eric H.
Old 07-14-2013, 08:42 PM   #6
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Change your fluid and filter. It could also be fluid level that affects that.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 07-14-2013, 10:13 PM   #7
erich330ci
My Ride: 2004 330ci
I've got the tranny filter & filter change on my radar, but have been stalling a bit, trying to figure out if I should buy a kit or buy the filter and fluid piecemeal.
Eric H.
Old 07-14-2013, 10:14 PM   #8
erich330ci
My Ride: 2004 330ci
Going to have differential fluid changed at same time. Totally unfamiliar with these fluids, hence the stalling.
Eric H.
Old 07-14-2013, 10:28 PM   #9
BMWCaptain
Just buy the filter plus gasket and then go get your fluid.
Not many people sell a kit for tranny fluid and filter change.
Order a filter with pan gasket like ATP-B275 ( if it fits your vehicle) off Amazon for $37, and then pick up Castrol transmit import multi vehicle ATF from your local parts store
BMWCaptainE46.com
Old 07-16-2013, 01:19 PM   #10
jbren325i
My Ride: 2003 325i
Re: Auto transmission clunk when coming to stop.
Did you also have the little gear with the ! In the middle beside your indicator on your dash?
Sent from my SAMSUNG-SGH-I337 using BimmerApp mobile app
2003 325i sedan K&N INTAKE, ebay headers, REMUS EXHAUST, depo hid headlights with angel eyes, EAGLE EYE LED TAIL LIGHTS, vmr csl replica wheels 18" BFGOODRICH GFORCE 225/40/ZR18
jbren325i is offline   Reply With Quote
Old 07-16-2013, 01:30 PM   #11
jbren325i
My Ride: 2003 325i
The reason I ask is because I had this same problem in my sedan. Hard clunck when slowing down at redlight. Had the gear box warning light on dash. I had the transmission codes read by shop, nothing. One day the car finally died on me. It wouldnt do anything. Had it towed to a bmw indy shop. They told me they only thing they saw bad was the fuel pump had died and clogged fuel filter. Rrplaced both and car ran great. Never had transmission issue again. Just food for thought.
Old 07-16-2013, 01:36 PM   #12
erich330ci
My Ride: 2004 330ci
Nope, that light never came on, but thanks for the info.
Eric H.
