Old 06-20-2013, 07:39 PM   #1
egruber
My Ride: 2001 325 CiC
Mystery rattle under the car.
I hope you guys can help with this one. My 2001 325 convertible has a metallic rattle from somewhere under the car. I only hear it when the left side goes over bumps. Pressing the brake makes no difference and when the windows are up I don't hear it. Mechanics have checked all over under the car and can't find a thing. None of the springs are broken. Everything is tight in the front end. Can struts make this noise?
I'm stumped. Any ideas on this one?
egruber is offline   Reply With Quote
Old 06-20-2013, 07:42 PM   #2
j_block
My Ride: 2003 325i
Re: Mystery rattle under the car.
Exhaust loose?
j_block is offline   Reply With Quote
Old 06-20-2013, 07:43 PM   #3
egruber
Didn't appear to be. Seems odd that the noise is not transmitted into the car when the windows are up.
Old 06-20-2013, 07:47 PM   #4
Foxtrot_Uniform
My Ride: 325Xi
Sway bar end links?
Foxtrot_Uniform is offline   Reply With Quote
Old 06-20-2013, 07:48 PM   #5
egruber
Didn't check that one. But I'm going to take down all these suggestions for the next time I get the car on a lift.
Old 06-20-2013, 08:14 PM   #6
davidwarren
Halfway to 2L
davidwarren's Avatar
My Ride: 2010 335i
my exhaust hanger was slightly loose and it took me forever to figure out what was making the noise. It was a horribly loud metallic rattling sound. check that and check the heat shields by the exhaust manifold.
You down with UCC? Ya you know me!
sowing the seeds of jiggery pokery
davidwarren is offline   Reply With Quote
Old 06-20-2013, 08:17 PM   #7
egruber
That sounds like a possibility!
Old 06-20-2013, 08:26 PM   #8
davidwarren
Halfway to 2L
My Ride: 2010 335i
Actually, the hanger wasn't loose, it was just misaligned. I just hit it with a wrench and the rattle stopped. Like, I literally just hit it.
Old 06-20-2013, 08:32 PM   #9
jdstrickland
My Ride: '94 325iC & '00 323i
If the rattle is light, my money is on the exhaust system. If the rattle is heavy, then suspension is my first choice.
Old 06-20-2013, 08:33 PM   #10
egruber
I think the noise is light. I will check the exhaust. Where exactly are the spots I should check?
Old 06-20-2013, 08:39 PM   #11
jdstrickland
You should be able to hit it with your hand and get it to rattle.
Old 06-20-2013, 08:39 PM   #12
jdstrickland
You are describing either a heat shield that is loose or the internals of the exhaust are coming apart.
Old 06-20-2013, 08:40 PM   #13
egruber
Where? Behind the rear muffler?
Old 06-20-2013, 08:44 PM   #14
davidwarren
Halfway to 2L
My Ride: 2010 335i
mine was the hanger right below the passenger door.
Old 06-20-2013, 09:44 PM   #15
miguelpr0
My Ride: 325i
Fuel filter cover maybe? Loose?
miguelpr0 is offline   Reply With Quote
Old 06-20-2013, 10:16 PM   #16
lszlszx
My Ride: 1.8T, XC70
Take a look at the auto headlight adjusting link on the control arm too.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 06-20-2013, 10:24 PM   #17
egruber
I will have to check them again. But the mechanic said the front end was all tight.
Old 06-20-2013, 10:56 PM   #18
Sweetness
My Ride: '01 325i
Have the same problem. 100% sure it's exhaust related. Mine is also cracked, so both of those problems finally gave me reason to buy a full cat-back
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 06-20-2013, 11:05 PM   #19
VishTheFish
My Ride: Ex M54B30 ZHP
parking brake issue?
VishTheFish is offline   Reply With Quote
Old 06-20-2013, 11:21 PM   #20
BeMyWhip
My Ride: 01 BMW 330ci
Not to thread jack, but mine it annoying the living F out of me!
However, mine goes away when I step on the brakes even lightly.
So, Im suspecting its a brake pad?
It just has to be, but it doesnt make sense.
Can It still be suspension related if it goes away when u hit the brakes?
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
