E46 Xi Forum
Old 06-22-2013, 06:52 PM   #1
TR4G-
My Ride: '01 325xi, '90 325iC
Looking to Buy some wheels: need your thoughts XIers!
Ok. so this thread will probably have a bunch of questions from me over the next week or so.
Here is my first: is this a genuine BBS wheel? I think it would be pretty nice to have 15 inch 2-piece BBS wheels on my e46, but Im not sure what exactly these are. Are these BBS RS wheels?
the more I look at these, the more I want them.
Specs: 15x7 with an offset of 11. Now that spacing should work. It increases clearance on the inside of the wheel and extends the ouside. Will these clear the tierods?
TR4G- is offline   Reply With Quote
Old 06-22-2013, 09:02 PM   #2
e46alfonso
My Ride: 330xi MT, mustang gt
they're not for our cars, keep looking.
I like offset et35-40.
Old 06-22-2013, 09:05 PM   #3
TR4G-
yeah, after checking out how offset and wheel dynamics work, its not reasonable to do. Wouldn't fit properly without modification and thats out of the question. Welp.... Ill keep looking around for wheels. Definately want a mesh look though
Old 06-23-2013, 02:34 PM   #4
TR4G-
How do you guys feel about this wheel? It's a 17inch ASA Revolution of some kind. Not sure how I feel about the black inside pieces. Would this look to unnatural? The tires are crap budget tires ill probably replace. Click image for larger version
ID:	512622Click image for larger version
Also, just because I'm asking your opinions doesn't mean I will follow them. Just in case you think that I'm needy or looking to please other people. In the end it's what I think that matters.
Old 07-01-2013, 08:06 PM   #5
xDLXSFx
My Ride: 2002 325xi
I was just going to say; we all perceive our BMWs differently; what one person thinks is sick, the other could hate it.
My opinion; 15's wayy too small even though the basket weave is cool. Those 17" machine faced wheels would give it a nice touch; also depends on what you want out of the wheels. Going for just looks? Then the possibilities are endless! You can always plastidip too if you dont like the color - cheap DIY. Im aiming for some nice looking light weight wheels. I think the style 73's are the best stock option for any 3 series, and the 135's!
xDLXSFx is offline   Reply With Quote
Old 07-01-2013, 08:38 PM   #6
Foxtrot_Uniform
My Ride: 325Xi
Just buy CSL reps for $600... 18X8...
Foxtrot_Uniform is offline   Reply With Quote
Old 07-01-2013, 08:57 PM   #7
TR4G-
Ok. So I ended up buying one piece style 5s (fundo, not bbs, boo ). They came with 225/55s on two and 235/55s on the other two. The difference in size seemed negligible so I picked them up for $300. The tread has about 60-70% left. Had to hike my KWs up the highest setting in the back for them to work. Fronts were fine as they were.
I tried on some BBS 1 piece style 5s with 235/60s all around and they were WAY too big. That set had all 5 wheels and center caps for 300. Shame they weren't 225s.
I'm still a bit nervous though, bc initially I thought I had the rears set well, but they settled like Mfers and started rubbing... but, I had a 2.5 ton floor jack, old school steel jack stands, and my 4 stock rims in the trunk...so that may have played in. But still, that would mean with 4 people it would rub, and I don't want that. So I jacked it up even higher and it seemed to do that trick. Here is a shot at how the rear wheel settled the second time (center caps are not on, but I have em)
Right after redoing spring perch setting:
After a somewhat spirited drive around the block:
....settled a fair amount. Haven't tried with all that weight in the trunk, but it seems like that gap should give me enough room for a full load of people.
Here is a shot from before I redid the rears:
I really like how far out the wheels stick. Offset is 23
I'm hoping the springs don't settle anymore. I feel like this was a pretty good buy considering the life of the tread and the total cost
Old 07-02-2013, 07:48 AM   #8
jjp735i
My Ride: 05 545i & 03 325xi
The tires just look to big. Nice wheels though
jjp735i is offline   Reply With Quote
Old 07-02-2013, 03:21 PM   #9
chilone
My Ride: 04 330xi, 97 Miata
What ever floats your boat. Not for me though.
chilone is offline   Reply With Quote
Old 07-03-2013, 10:43 AM   #10
DavidDee
My Ride: 2004 325xi
LOVE IT! I think the tires are the perfect size for the wheels.
"It has a radio and speakers but it's kinda hard to hear over horny bitches moanin in the back when I start it up.."
DavidDee is offline   Reply With Quote
Old 07-03-2013, 09:14 PM   #11
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
Question, what size were the wheels you picked up? the E46 325xi's came with 16 inch wheels and tires, not 15 inch and 15 inch would not clear the brake calipers. On the tire sizes that were mounted on the wheels, there is a difference and the difference that you have between those 2 sizes will have a different overall diameter difference which is not good for a 4 wheel drive system (it is possible to get the right combination for an off-set/staggered tire set from front to rear and have the same overall diameter), the best tire wheel set up for an XI is a "square" set up, meaning that all 4 tires are of the exact same size. No big deal going Plus 1 in wheel and tire size, that's going from 16 inch to 17 inch, wheel and tire weight combined will be just about the same, and the stock rotors will fill most the the wheel center and the wheel will look nice on the car. Going to Plus 2, which in this case would be 18 inch, now your side walls will be even smaller, the ride a bit rougher and the chance to flat spot, bend or break a wheel will increase, plus the stock rotors will not fill the wheel center and it will look odd. Wheel offset also has to be considered so that tires do not rub the fenders, you can always tell some one that really lowered a car and didn't spend the money to have the fenders rolled, as their fenders are all bent up and pushed out of shape from the tires hitting the fenders over bumps. Money is always a factor, but Beyern makes some very nice wheels for the BMWs that are hub concentric and they are of the proper outset.
tomoyer is offline   Reply With Quote
Old 07-08-2013, 12:35 AM   #12
zoompastu
My Ride: 330xi
He bought Style 5's from a E34. http://www.bmwstylewheels.com/bmw/5
Keep in mind, sport package xi's (like my car) came with 17x7's stock. The E46 M3 comes with 18's stock
2002 330xi ZSP, ZPP, 16:9 Nav, HK, Koni Sports, Powerflex CAB, Eagle Eyes, Recaro Child Seat
2004 X3 Hers
2006 VW GLI 2.0T Stage 2 - For Sale
1993 325is Moded Sold
zoompastu is offline   Reply With Quote
Old 07-08-2013, 12:38 AM   #13
mo_b
My Ride: 320cd
Not the biggest fan of the bbs on that e46. What about the old m5 alloys??
mo_b is offline   Reply With Quote
Old 07-08-2013, 12:41 AM   #14
zoompastu
My Ride: 330xi
Which M5? E28 E34 E39?
2004 X3 Hers
Old 07-08-2013, 12:51 AM   #15
mo_b
My Ride: 320cd
E39. Was going to try it on my coupe but I've had to go to standard 17" because of the cost of tyres. 500 mile weekly commute and apprentice wages unfortunately.
Old 07-08-2013, 01:10 AM   #16
zoompastu
My Ride: 330xi
The E39 M5 wheels are beautiful! Still one of my favorite cars. I so wish I had your diesel! BMW is finally bringing a 4cylinder xdrive diesel to the USA in 2014...
2004 X3 Hers
Old 07-08-2013, 09:18 PM   #17
2002GreenBMW
My Ride: 2001 325xi
I just bought the alzor m3 replicas 18x8 square setup for my 325xi and they are sick, they fill up the well so much better and I have gotten so many compliments on them, for 400$ on ecs I don't see a better option..
2002GreenBMW is offline   Reply With Quote
Old 07-09-2013, 10:26 PM   #18
CK325
My Ride: 323Ci, 325xi
well about a month or so ago i picked up my csl reps, 17x8 all around.
yesterday i picked up m-parallels but a staggered set up so I'll have to see if I can make the tires work and if I can even fit the 18x9.5 in the rear lol
CK325 is offline   Reply With Quote
Old 07-10-2013, 01:39 AM   #19
zoompastu
My Ride: 330xi
Here, use this tool to figure it out... I've used this for nearly a decade now.
http://www.miata.net/garage/tirecalc.html
2004 X3 Hers
Old 07-10-2013, 12:48 PM   #20
CK325
yup I think I got it from another thread you posted it in
